Technical ***December 2016 Banger Meet - Dear Santa, A new C block***
Discussion in 'Traditional Hot Rods' started by Jiminy, Nov 30, 2016.
  1. Jiminy
    Jiminy
    Here is the banger link list:
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    New Banger Block in the Works
    http://www.jalopyjournal.com/forum/threads/new-banger-block-in-the-works.616056/
  2. Binger
    Binger
    from wyoming
    Thanks for starting the new banger meet Jim. Checking in for the month. Not much car related going on in my garage right now. Building X-Mas yard art for the wife currently. No fear, I will be working on the interior for my car later this winter.
  3. denis4x4
    denis4x4
    from Colorado
    Back to Durango next week to finish the engine in the Zipper and get it ready for the Speedster Reunion in Lincoln June 20-23
  4. RussTee
    RussTee
    Windfield carbs are on and working fitting Mallory with pertronix thank to Pat Gary then a good tuneup and should be good for summer woo hoo
  5. V4F
    V4F
    from middle ca.
    winter here , car on jack stands , updated front end .... so now turn it around & do the back end
  6. stillrunners
    stillrunners
    from dallas
    here's hoping Santa brings your banger parts to all you kids that have been good this year......not much to report...been bad.....towed the my model A out of it's hole with my 8N because I was lazy......do have a new hot rodder I'm working on.....my great niece pulled my old mags from the recycle bin.........
    cactus1 likes this.
  7. waxhead
    waxhead
    from West Oz
    Just checking in. With any luck my new Miller OHV will be in the post next week. Probably won't make it to Oz in time for Xmas, but thats OK.
  8. Bluto
    Bluto
    Snowing waaaaaay East.
    A friend came to visit and helped take the latest little banger apart. We had to pull the oil pan, rods, and main caps all necessary to get the flywheel off. Seems Fiat engineers didn't think much and the bell housing shape doesn't allow flywheel removal otherwise.
    My hands are still shaking too much to do much. The radiant barn heaters do make workshop is cozy!
    stillrunners likes this.
  9. Dec? already?
    Well this year a bust, Bonneville made one decent run in 3 days @149 FM and 157 exit.
    ElMirage was fun, dropped valve but saved head and block.
    Nov Elmer injector problems, gotta quit rushing to get to race!
    Happy Safe Holidays to All, J
  10. blgitn
    blgitn
    Happy December! Hope your Turkey Day was fattening!
    Here's the latest progress on my shop. As soon as I get the new electrical panel in, I can take down the old walls inside and pour the floor. shop now.jpg
    This is what I started with in April:
  11. V4F
    V4F
    from middle ca.
    would like to talk with someone using a c-4 with their banger ............. thanks .. steve
    *** some one must know something about an adapter .
  12. Crazydaddyo
    Crazydaddyo
    I've been too busy with other things, so this still sits waiting for me to get back to it!!!!!!
    530sandman, Jet96, Jeff34 and 2 others like this.
  13. V4F
    V4F
    from middle ca.
    it will be there when your ready . like a dog being happy when you come home
    curious as to why you are a SP cl*** ?
  14. Thanks for the links, pretty neat that you guys have monthly updates. Guess ill start contributing. Building another racer for trog. Banger powered of course.. image.jpg
  15. Jiminy
    Jiminy
    Any pictures of the build?
  16. wright
    wright
    from illinois
    I don't know about a c-4, but i am running a 904 behind my riley 2 port model A banger. I would be happy to answer any questions you may have about my setup.
  17. Call Flat O Matic
  18. I'm waiting for an adapter kit to install one!
  19. V4F
    V4F
    from middle ca.
    where did you get the adapter ? ............... steve
  20. V4F
    V4F
    from middle ca.
    yep they make killer p/g shorties . I have been to their site ............. thanks john
  21. wright
    wright
    from illinois
    The adapter for the 904 is made by a guy in california. pm me if you want me to send you his contact info.
  22. There is a guy who makes one for the 904, he is, I've been told, in ill health so ' not giving out his contact info until he finishes mine. I realize that is selfish of me but at 80 I don't want to start looking again!! Seems like a Flat O kit would work for a C 4 with an A to 39 adapter. Would be like bolting up to 59A. If I were serious would call Flat O and ask!
  23. Found this on the sight! not cheap though!
    Ford Model A & B to Chev Auto $1195.00
    I'm so tempted to run an aluminum polished 2 speed Powerglyde on my next 4 banger hill clinb car build!
    http://www.transmissionadapters.com/Model A Install Inst.htm
  24. V4F
    V4F
    from middle ca.
    thanks joe . it seems the last week or so ive had my head in my ***
  25. Lol.
    It's John you need to thank, not me!
    I was thinking about a kit also, so I looked at the website he posted!
    Joe
  26. V4F
    V4F
    from middle ca.
    THANKS JOHN !!!!!!!!!!! you too joe
  27. 28dreyer
    28dreyer
    from Minnesota
    We politely call that a cranial/**** inversion
    Dannerr likes this.
  28. V4F
    V4F
    from middle ca.
    thanks 28 , I needed the confirmation
  29. Steve,
    You now require a "Cranial removal from ******".
    No worries, I have my best ideas when hiding from reality.......
    I have one of the Mod "A" to Chev trans plates in the race car. It is worth every cent paid for it.
    The full kit is expensive, but includes everything except trans and TC.
    I think that Iandola made the first 904 adaptors, and I think Art Moore still runs one.
    J
