Technical Extended cab Model A truck out of a Tudor Sedan?
Discussion in 'Traditional Hot Rods' started by txoldrodder, Dec 1, 2016.
  1. txoldrodder
    txoldrodder
    Has anyone built an extended cab pickup out of a Model A Tudor Sedan? If so let me know! How to pic's, Information, Etc!
    Hdonlybob and irishsteve like this.
  2. verde742
    verde742
    lots of them...:)
  3. That's been done several times different ways. To me the Crew cab thing just looks wrong. If I were going to do one I'd lengthen the doors to make a better profile and make more leg room. Just my .02 worth.
    The Wizzard
    clem, -Brent-, barrnone50 and 2 others like this.
  4. john dioli
    john dioli
    A Vicki with a bed
  5. Blues4U
    Blues4U
    from So Cal
    I agree that the extended cab usually just looks wrong, but I have seen some, a few, nice ones. One that worked well was made from a coupe.
    Stogy likes this.
  6. Why not a Model A 'Fleetside' instead? Shorten the roof, but keep the Tudor body sides...
    southerncad, Stogy and vtx1800 like this.
  7. I like that idea. Kind of like a semi Ute model. That could work. Someone should photo shop that.
    The Wizzard
    Stogy likes this.
  8. KiwiGlen
    KiwiGlen
    A C Fibregl*** here in New Zealand produces such a body based on their 1930 Coupe.
    The photo shown is from the "Standard model A and T quote" they sent me a year or so ago when I enquired after their T roadster price. It looks ok but this is the only one I've ever seen, I've never actually seen one built up.
    http://www.acfibregl***.co.nz/
    Glen.
    Stogy, vtx1800, Hdonlybob and 7 others like this.
  9. I wouldn't do a pick up out of it but,,,,,
    Would you put it on a longer frame or run a short bed?
    stanlow69, Dean Lowe, Stogy and 7 others like this.
  10. Scooter built a pretty slick ride from a 4 dr.
    Here's were you decide if your running a short bed or a longer wheel base frame.
    Just like today's trucks, an extended cab is longer wheelbase frame vs standard
    Okie Pete, Stogy, Just Gary and 7 others like this.
  11. bigloser
    bigloser
    from Mesa,AZ
  12. 57tailgater
    57tailgater
    from Georgia
    I think the trick would be the proportions of the rear side window to the window. Needs to be similar to a '32 5 window IMHO. :cool:
  13. Just Gary
    Just Gary
    ^^^^This one looks like a truck back panel with a 4dr roof section.
    Was that a photo shop ?
    A 2 dr has a big return after 1/4 window before it goes around the roof.
    That's going to give you problems on a pick up.
    And no- It's not a Vicky with a bed
    Expand the lower quote
    Here's a teaser.
    Stogy likes this.
  15. Squablow
    Squablow
    The green one seems to work nicely but I think it's because it isn't chopped. The height of the cab makes up for the unusual length. The chopped and channeled ones look odd to me.
    I sold some 4 door sedan quarter window sections to a guy in California that grafted them onto some other A pieces to make an extended cab pickup body, his looked pretty good.
    A Tudor sedan seems like the most difficult body to make this out of. Extending a pickup cab to include quarter windows, or eliminating the back doors of a 4 door, or even taking the quarters off of a coupe, all seem like they'd be easier/cleaner.
  16. bartmcneill
    bartmcneill
    from Ada, OK
    This is PHOTO/CHOP. Pretty bad but to get the bed stock size you would have to really cut the back window vertically.
    Okie Pete and Squablow like this.
  17. Extended cab trucks have a longer wheel base.
    Set that up the With stock bed length & longer WB.
  18. There's always the crew cab too
  19. sko_ford
    sko_ford
    I'm thinking ext but outta this fordor carc***
    Okie Pete and chryslerfan55 like this.
  20. coupe33
    coupe33
    I like #10 post of a 4 door to extended cab.
  21. 38Chevy454
    38Chevy454
    It's not a Model A, but here is a pic of my 37 Ford Ute just for ideas. It has a shorter rear quarter window and a more vertical back window than a coupe. I can't tell you how many people here in USA think I built it out of a coupe/sedan/delivery. I tell them body is 100% as Ford Australia built it. It's no longer this color, and has been off the road in paint jail for about 7 years now. I really need to get it back on the road. DSCF2042.JPG
    Okie Pete, Stogy, Just Gary and 3 others like this.
  22.
  23. tub1
    tub1
    from tasmania
    I remember your 37 ute when it had no floor and was bare bones here in tasmania
  24. scrap metal 48
    scrap metal 48
    I believe I would just put a delivery door on the sedan.. A lot less work and everything is enclosed.. But trucks are cool too....
    Stogy and lothiandon1940 like this.
  25. Tri-Power
    Tri-Power
    from Memphis
    Here's mine, started 13 years ago, now with 6500 miles under its belt. Started with a 1930 Sedan. 128" wheelbase, handmade bed curved to fit the body. It looks very similar to the op's first pic.
    coupe33, Okie Pete, Stogy and 4 others like this.
  26. jvo
    jvo
    Here's my old truck which I no longer have. I stretched it 4 inches in the doors. Before I did anything, I drew it up on graph paper as closely as I could, with quite a few variables such as extended cab, and various top chops. 100_3930.jpg 100_3942.jpg 100_3949.jpg I just didn't like the extended cab version. Thus, I went with this. Only problem was, the 4 inches I gained, I then lost cause I reversed the firewall, which was protruding about 2 inches into the engine compartment, and when turned around, made a total of 4 inches of lost foot space at the pedals. I lost what I thought I had gained in foot room because of it. Cab was chopped very badly when I got it, 4 1/2 inches on one side, and 4 1/4 inches on the other. I mocked it up before I did anything and my head was touching the underside of the roof. Put it back to stock height for that reason, and I'm only 5' 9" tall. With the doors stretched, it gives it the illusion that the top has a slight chop, which it does not.
  27. Atwater Mike
    Atwater Mike
    Interesting proportions here, I'd definitely stop and take a second look...
    Understand about the firewall reversal, made that discovery on my customer's '30 pickup.
    Had everything in place, set the firewall and customer came to check 'fit'.
    Turned out he didn't. (fit!) Firewall was then fabricated from A-K 18 ga. steel.
    Live and learn...
  28. Atwater Mike
    Atwater Mike
    There was a '34 pickup in Farmersville (Speed Frame Engineering) A F.E.D. racer took the '34 and added an extra door length (from 2 cabs) and bed was shortened to 5 feet.
    Looked factory, and yes, wheelbase was stretched. (130"? Not sure, but around there)
    His friend did a '57 Ranchero Crew Cab, added a door, also 'factory looking'.
    Both were excellent, in profile and finish.
  29. rusty rocket
    rusty rocket
    That truck just looks right? Extended cabs don't looks correct.
    RidgeRunner and chryslerfan55 like this.
  30. 31Apickup
    31Apickup
    That surprisingly looks good, I could use that 4” in mine.
