Hot Rods Chopping a 35-36 Ford pickup cab, pros please weigh in.
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Dec 2, 2016.
  1. Roothawg
    Roothawg
    I am planning on chopping my 36 Ford pickup. I have had this truck since I was a kid. I drove it through high school. It's my keeper, never sell truck. With that said, I want to make sure I do this right.
    I am looking to do a mild chop. These trucks seem a little too heavy. Maybe 2-3" just enough to make folks wonder if it has been chopped.
    I would prefer not to split the top into multiple pieces if possible and I don't want the rear window to remain the same size. I do have an extra roof, if I do need parts to stretch the roof.
    I will post some pics from different angles. If you don't mind, give me your input on chopping the cab. I have chopped one car, but I want this to be perfect.
    Thanks
    IMG_1480722517.287767.jpg IMG_1480722540.819543.jpg IMG_1480722560.945441.jpg
  2. Mr48chev
    That's a nice looking cab.
    One of my buddies was showing how a guy he had worked with cut the middle out of the donor roof like a big filler panel for a coupe or sedan roof and then split the original roof so that everything fit up square and used that filler so he could weld it up out close to the edge rather than across the middle this way and across the middle that way. We did pretty much the same on my roof when I took that "80's" sunroof out and filled the roof back.
  3. typo41
    typo41
    Just a question
    Are you chopping it because it will improve the look?
    Or you chopping it because you have had it so long you are bored with it?
    36's are beautiful stock, like 40's. Oh you can chop them, but if you miss you miss big.
    blowby and Bandit Billy like this.
  4. Roothawg
    Roothawg
    No, I am not bored. I just think they are a little top heavy. I don't want a heavy chop, just a little.
    I was thinking, if I take 2.5" out of the center of the rear window, I could take the same amount out of the front. The question is, will it be noticeable if I lean the A pillars back?
  5. AVater
    AVater
    What did Gene Winfield do on his '35 Pickup?
  6. Roothawg
    Roothawg
  7. vtx1800
    vtx1800
    I too, think they are a little top heavy. I had a 36 back in the 80's, extra cab and a few other pieces, I took a picture of it and sliced it to get a feel for the look, that would be a cheap way to determine what would like good, to you, and you are the only one that matters.
    I sold it, not sure what happened to it.
  8. 117harv
    117harv
  9. hotcoupe
    hotcoupe
    this one looks good to me, i think it was done at austin speed shop.
    tom
  10. flamedabone
    flamedabone
    Here is my '36 stock. These things have a bit of a tractor cab from the factory.
    But 2 inches off the top gets them down where you can stand to be seen in it.
    I split my roof lengthwise to keep the original A pillar angle and ended up with about a 1 1/2 filler strip from left to right. Pretty basic chop, you can do it start to finish in a weekend.
    Good luck, -Abone.
    barrnone50, falcongeorge and AVater like this.
  11. flamedabone
    flamedabone
    You can kinda see the cut lines in this pic. Again, not much to it. It is two guys, most of a weekend and a little less than a case of beer worth of chop.
    -Abone.
    akoutlaw and falcongeorge like this.
  12. gearheadbill
    gearheadbill
    How tall are you? They don't have a lot of room in them stock..as you know.
  13. Roothawg
    Roothawg
  14. Roothawg
    Roothawg
    6'2" but they have a seat riser that can be easily removed to make up the difference.
  15. Are you scared of a 6" chop? ;)
  16. AVater
    AVater
  17. Flathead Dave
    Flathead Dave
    from So. Cal.
    Don't go wild with the chop. The truck looks good leaving it alone. A 2" chop will look good.
  18. alchemy
    alchemy
    Anybody have any pics of one of these with an extra half inch taken out of the front? I think they are a touch square, and wonder what a slight slant would look like when chopping.
  19. falcongeorge
    falcongeorge
    from BC
    Didn't Street Rodder do a good How-To on a slight wedge chop on a '35/'36 cab in the late nineties? Seem to remember that...
  20. falcongeorge
    falcongeorge
    from BC
    Its a 2" straight chop on a '41 with the posts laid back, they cut out the back window and kept it full height. If you think it will help you I can scan it and post it, fairly detailed.
  21. RidgeRunner
    RidgeRunner
    from Western MA
    1 1/2" to 2" max chop. Watch any lean back on the A pillars, don't let them get back much more than the angle of the grill.
    Just my 2 cent opinions, go with what looks good to you and fits your driving comfort. Individule varity is what keeps it all interesting.
    Ed
    falcongeorge likes this.
  22. belair
    belair
    2 inches sure looks right. I agree with RidgeRunner about keeping all the angles (grille, A pillars, etc.) the same.
  23. RMR&C
    RMR&C
    from NW Montana
    Anybody have pics of one with a 2" chop and the posts laid back?
    I may be doing a chop on one in the near future.
  24. The way I was taught by a MASTER metal man was to never lay the pillars back unless you can drop the back lower than the front IE.=cars. Trucks look funky if you try and drop the back lower than the front so we never leaned truck pillars back. If you just lean the pillars of a truck back and chop it 2-3" and then stand back and look at it, it looks like someone ****ed up. All the trucks we did at the hotrod shop we split the roofs. He had the best eye for kustom cars/trucks and always said to make it look like it came from the factory. Most all trucks we split into 4ths. Straight across the middle front to back and side to side. It's a lot of work but to me looks the best. Just my opinion, iv seen lots of jacked up chops.
    Also if you chop a truck a lot they look stupid if you dont shortin the bed. Again just my opinion. Don't want this to turn into a argument. Btw the ol man never leaned the A or B pillars back he always said it looked stupid. He made them look factory just shorter. Never cut off the drip rail or round the corners of the doors. Just my thoughts:D
    warhorseracing, akoutlaw and The37Kid like this.
  25. falcongeorge
    falcongeorge
    from BC
    FWIW, I also agree with not leaning the posts back on a truck.
  26. K13
    K13
    belair and Tman like this.
  27. And you shaved the drip rail!!
    Or is just hard to see?
  28. K13
    K13
  29. Roothawg
    Roothawg
    Thanks for the input. I was out of town all weekend, so a little slow replying.
  30. Jim636
    Jim636
    from Wyandotte
    I leaned mine back to. Better then that looooong weld a crossed the cab.
