Technical The Allure of the Quick-Change Rear End.
Discussion in 'Traditional Hot Rods' started by Jive-Bomber, Dec 6, 2016.
  1. Jive-Bomber
    Jive-Bomber
    MODERATOR
    Jive-Bomber submitted a new blog post:
    WC145, 50John, Ron Funkhouser and 6 others like this.
  2. hotrodA
    hotrodA
    Yep, had to have one. Converted it to late model 28 spline axles and bearings per some old R&C articles. Having to pay $75 for the center section made it a lot easier.:D. Been on the road since '87. Yes, it's noisy.
  3. Paul
    Paul
    Editor
    Not as strong as the old 9" and no limited slip are pointless arguments up against the cool factor of a quick change rear in an early hot rod
  4. typo41
    typo41
    When the Salt Circus was built, it had a quick change, but now it has a 9 inch which is better for racing. QC eat 30 to 40 HP, but, I wish it was still with the car as it made it more hot rod then land speed. Why is it gone you might ask? Well it was built in the 80's and George threw in a early ?Culver City Halibrand and the PO kept it for a street hot rod project.
    ima33ford likes this.
  5. Blue One
    Blue One
    from Alberta
    Then you have the new Winters nostalgia quickchange that I bought and installed in my RPU.
    Wedge lock differential and plenty strong.
    And really pretty too. :cool:
    And yes, I had to have it :D
    Deutscher, Woogeroo, Outback and 18 others like this.
  6. louisb
    louisb
    I have a perfectly good '36 rear with a later 3.78 gear set for my AV8 project. Yet I still covet a new Winters V8 QC. Saving my nickles and dimes.
    --louis
    Outback and Ron Funkhouser like this.
  7. Truck64
    Truck64
    from Ioway
    Nice socks
    rpm56 and 49ratfink like this.
  8. brett4christ
    brett4christ
    I lucked into a Culver City center with cover a year or so ago. It sat, nose up with no input shaft, for several years out in the weather before I saved it. It was originally set up, I think, for a dirt racer...it had late axle tubes welded into the banjo bells with late splined axles and weird brackets all over. Plans are to try to get it clean, then use the '40 banjo I saved from a basketcase sedan I parted out to ***emble a budget quickie for the Tudor!
    This article should be a big help when the time comes to get on it!
    Outback, chaddilac and Ron Funkhouser like this.
  9. alchemy
    alchemy
    Ive got a couple for B rearends, and a champ size one as well. No V8's, but some day I'll find one I can afford. None are in cars yet, but I've got big plans!
  10. Nailhead Jason
    Nailhead Jason
    You don't want that old roundy round axle Brett.....Ill just take it of your hands this weekend, shoot ill even bring you another rear.. You want an 8 inch or a 9 inch?
  11. Pewsplace
    Pewsplace
    I am a believer that a hiboy coupe/sedan and roadster all need a Quickchange! They are just right and if your old you can't hear them anyway!
  12. brett4christ
    brett4christ
    If we finish the motor mounts this weekend, maybe we can put the article to good use! :eek::D
    Don't forget the pedals!!! ;)
    Outback and Nailhead Jason like this.
  13. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    There are numerous articles right here on the HAMB about QCs.
    As Blue One said, the Winters is as good as it gets for V8 Quickies. (They are better than the original Halibrands,,,,,,,,,BLASPHEMY!!!!!!!!)
    If you want to stay traditional, it will cast more money, but they can be built to be reliable and quiet.
    I'd like to see the do***entation on a 30 -40 HP loss with a QC. The QC ring and pinion was is a bevel type and the 9" a Hypoid, there is less drag on the QC R&P, but the change gears cause some power loss to the rear wheels. About a wash as far as I can tell.
    Smokey claimed 10 HP lost through the QC gears.
  14. Bruce Lancaster
    Bruce Lancaster
    Theory puts it about even with the excessive offset of the 9", but I read on article on the 2nd rank NASCAR late model series in which many cars use the big Champ QC. The article said that cars running the 9" on a fast track had to use a pump and cooler to avoid frying the gear oil, while QC cars were able to run without rear end cooler. That heat is directly lost horsepower caused by the friction in the deeply offset R&P of the 9". Remember, the early Ford R&P in the QC runs on center and so has much less gear friction than the 9.
    Outback and classiccarjack like this.
  15. DDDenny
    No need to be concerned about horsepower loss if you start with enough.
  16. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Spit whiskey all over my keyboard!
    Outback, ls1yj, stillrunners and 2 others like this.
  17. Kan Kustom
    Kan Kustom
    Sounds like you may need to go and make a quick change. :cool:
    Outback likes this.
  18. Kan Kustom
    Kan Kustom
    Where did you get those adapters for the Champ to 40 bells ? I like the better than the ones I have.
  19. Kan Kustom
    Kan Kustom
    Jive Bomber, cool thread, as usual !
  20. Paul
    Paul
    Editor
    I used a Rodsville version of the Halibrand V8 with '40 bells and '50 Mercury ends, axles and brakes in my '27 roadster,
    'got a couple thousand pain free miles on it so far..
    it's one of the parts I just had to have in it.
    here is the ch***is coming together last summer.
    rod1, curbspeed, 63fdsnr and 9 others like this.
  21. I, m using aWinters V8 and old style axles for my Modified ! Chevy 2 4 banger should'nt break keyways I hope
    Outback likes this.
  22. Bruce Lancaster
    Bruce Lancaster
    Some numbers from Ford engineering, about 1935. Book has a section on power losses between engine and rear tires.
    Each extra pair of gears turning (as in transmission in lower gears) costs 8%...(high gear straight through costs only 2%). I'd guess they are talking spiral cut gears, since discussing '30's transmissions, so QC with straight cut gears would likely lose a bit less here. The engineering principle here is of course that making noise costs less power than making friction.
    R&P and related bearings, oil, etc. lose around 10%. Again, since early Ford this would likely refer to an on-center spiral cut set. A 9" would lose more here since hypoid, and of course the 9 is about the most extreme offset there is before you get to a worm gear drive. Just a few numbers, so make some guesses, add and multiply, and we will have a reliable guesstimate.
    When discussing, say, a 135 MPH flathead street roadster at Bonneville in 1953...how the hell much power could it have lost?
  23. ago
    ago
    from pgh. pa.
    Nothing more traditional than a Quick Change and 3 pedals.
  24. jimmy six
    jimmy six
    Quick change noise is ok as long as you have a cam gear drive. Keeps both ends noises..
    Outback, LOU WELLS and Gabe Fernando like this.
  25. Gabe Fernando
    Gabe Fernando
    Strait-cut spur gears, on the street, is 50% of the cool. Always has been.
  26. primed34
    primed34
    I just got to have a QC one of these days. For some reason I think it would cooler under my '55 than my '34.
  27. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    The ribbed adapter plates are C.A.E. They are fairly rare. These may be repopped in the future. The center section in that photo is a Halibrand.
  28. ROBERT JAM
    ROBERT JAM
    image.jpeg image.jpeg Mine now under the roadster project. Running and driving now!
    rod1, LOU WELLS and Ron Funkhouser like this.
  29. Rocky
    Rocky
    Classified Editor
    34rear_2_11_15.jpg It started for me with wanting to use a Muncie close ratio 4 speed but starting off in 1st gear with a 2.20 low gear is an exercise in clutch slipping...soooo, I decided if I use a quick change I can use my 4.61s around town and be able to drive the car around town....then I can swap to my 3.25s for road trips and as a bonus I get to listen to the Q.C. whine.
    Outback, Just Gary, SlamIam and 6 others like this.
  30. Mike VV
    Mike VV
    from SoCal
    My Winters Q.C. under the back of my 54 Stude wagon. Has Chevy Truck arms holding it together that you can see if you look. The car is held up by a coupla jacks in this picture.
    At normal ride height all you can see is about the lower 1-1/2" or 2" of the gear cover.
    Mike
