55 210 Wagon Progress
Discussion in 'Off Topic Hot Rods & Customs' started by MP&C, Mar 24, 2013.
  1. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    I always run into the issue of either removing or working around something that is behind at least part of the seam to work out the distortion. And it always takes 10 times longer than the customer thinks it will! lol But I guess that's why plastic filler or lead is near by:rolleyes:. Always informative as usual Robert . Even for those of us who think they Know it all:rolleyes:. Larry
    loudbang and MP&C like this.
  2. bengeltiger
    bengeltiger
    Thanks for taking the time to demonstrate this since this effort obviously doesn't pay the bills. I've been following this thread for quite some time and your willingness to stop and do***ent a process has had a tremendous influence on my skill set.
    bct, Johnboy34, loudbang and 4 others like this.
  3. MP&C
    MP&C
    Thanks for the comments guys!
    With the rockers and inner quarters covered with some SPI epoxy primer, tonight we'll get the quarter panel baffles welded in place so we can install the wheel wells.
    Here's our home-made baffles:
    Primer cleaned off for the plug weld holes..
    Kyle plug welding:
    Now plug welded in, we'll clean up these welds tomorrow evening, epoxy prime and seam seal around the top profile of the baffle inside the window extrusion area.
  4. MP&C
    MP&C
    When we fabricated the quarter panel baffles we trimmed the upper profile to leave about a 1/16" gap, so that any possible body flex would be less likely to rub paint..
    Plus, it gives a good anchor for the seam sealer....
    Then we used masking tape to mark off the edges of the flange so we could transpose these to the wheel well for drilling plug weld holes...
  5. bobss396
    bobss396
    Staggering build... you have conjured up a new '55 Chevy wagon.
    lothiandon1940 and MP&C like this.
  6. dcs13
    dcs13
    Robert, I am always in awe. Thanks for sharing..
    MP&C likes this.
  7. MP&C
    MP&C
    Thanks guys!
    Fitting up the one piece wheel well into the p***enger side quarter. Once fitted, the edge is marked with tape, wheel well removed, and the width available beneath for plug welds is noted. Then holes are punched in the wheel well to match, and it gets refitted. We started at the front so we could use vise grips to clamp, and worked progressively toward the back.
    We did have a few plug welds that were contaminated from the epoxy primer, so we'll grind everything smooth, fix those areas, redress the welds and finish any bare areas with epoxy primer. One step closer to the Line-x coating on the underside...
    Here we are all tacked in place:
  8. MP&C
    MP&C
    All plug welds completed and dressed. Now for the other side and we'll epoxy prime again..
  9. 41 coupe
    41 coupe
    from bristol pa
    All of that fantastic work and it is going to be hidden away!!!
    Bowtie Coupe and loudbang like this.
  10. MP&C
    MP&C
    Can't wait to sling some mud on it!
    Bowtie Coupe and lothiandon1940 like this.
  11. low budget
    low budget
    from Central Ky
    This thread will be 4 years old in march and you said you had worked on it for years before that, and it will probably take a few more, It should be nice but I hope the lady that owns it can afford it and is still young enough to enjoy it when its done:)
    loudbang and flatford39 like this.
  12. MP&C
    MP&C
    That's the pitfalls of being a part time car fixer upper and having a day job that involves FAR too much travel..
    loudbang, JOYFLEA and lothiandon1940 like this.
  13. MP&C
    MP&C
    Tonight we worked on getting the driver's side wheel well installed. To help eliminate the contamination issue from the close proximity of the primer, we used these piloted burnishing brushes to remove the paint around the plug weld holes on both front and back sides...
    That did the trick, no volcanoes this time...
    Next we'll need to dress these welds and epoxy prime the bare spots.
    JUNK ROD, D-Russ, JOYFLEA and 5 others like this.
  14. JOECOOL
    JOECOOL
    It seems I always have so many question s, thanks you for answering them . I am currently welding up my door edges to establish proper gaps . I only do it in very small increments.A friend of a friend was over and said I should hit the welds with an air hose to quickly cool the welds . Is this a good practice? thanks again .
  15. MP&C
    MP&C
    Joe, unless you are doing some torch shrinking, I see no benefit to artificial cooling. On torch shrinking the forced cooling allows you to see the shrinking effect more quickly for addressing the next spot. For welding, a gradual cooling IMO leaves the weld softer for an easier task of planishing. Let it cool on it's own and see how it works out for you.. I feel the weld is going to shrink regardless of what voodoo method used to combat the issue, just let it do what it's going to do and planish the shrinks afterward.
    Here's the path we took on the seat risers....it's been a while now that GM has used wood in the vehicle, no sense in us bucking that trend! Started by fabbing up some 14 gauge steel into a hat section and left some longer ears on the ends to fold down and close the ends off..
    Stainless hex nut welded inside for the seat frame hardware..
    Missed getting these pics on the other end, but cardboard templates were transposed to steel fillers, cut out and welded in place, along with the flanges around the perimeter.
    Finished up the plug welds on the driver's wheel well. We'll get a few more parts prepped for epoxy and address those bare spots at the same time.
  16. MP&C
    MP&C
    Seat riser bracket number two fabrication, got more detail pictures this time..
    Used the Tipping die in the Lennox to thin out the crease line, makes for a more crisp bend, especially given the 14 gauge steel we're using...
    After bending in the Diacro manual press brake using the gooseneck die...
    Fitting and t******* the end transitions while matched to the floor...
    Ready for the TIG
    JUNK ROD, wraymen, D-Russ and 4 others like this.
  17. Those seat risers look a bit light to me.... By the '50s, pretty much all front seats were anchored at the back through the floor and with either additional reinforcement under the floor or actually attached through a frame member. The idea being that in the event of an accident, any back seat p***engers or just the weight of the seat wouldn't tear the seat loose and pin the front seat p***engers into the dash. If that tack-welded nut pulls through, the seat becomes a projectile...
    rtp likes this.
  18. MP&C
    MP&C
    The risers are made from 14 gauge cold rolled steel and will be plug welded across the back end and front end through the floor pan into the floor cross-member, as well as down both sides into the floor pan. The 5/8-11 nut at the rear (3/8-16 used in the front) was tack welded at the top merely to center it within the hole. Once this was complete it was then Tig welded to the riser on the under side. I'd prefer to have through bolts with a reinforcement plate beneath, but given the need for risers to get the seat in the air a bit, that became less of an option and still look halfway decent.
  19. Maybe a piece of tubing extending down through the floor (to prevent crushing the riser) and a longer bolt....
  20. MP&C
    MP&C
    Today the p***enger bucket seat was test fit onto our riser. It could be brought a bit tighter to the floor.
    Next, looking at the cross member, the rear flange (red arrows) didn't match up to the rear flange of our riser.
    The blue tape shows the rear flange of the cross member below...
    Here's our updated riser, half as tall, and once trimmed the flange will match to above the cross member..
    JUNK ROD, 1959Nomad, brEad and 5 others like this.
  21. MP&C
    MP&C
    More details on the seat risers, here the 5/8-11 hex nut is welded inside. The tacks at the top are merely to hold it centered within the hole to maintain our correct C-C hole spacing. It gets welded inside as well to keep things anchored in place.
    The 5/8 hardware was chosen as the factory seat bracket on these 2002 Monte Carlo seats had a hole that large existing already. The front of the seat bracket actually had another bracket underneath that was held in place with a solid rivet. We drilled out the rivet to remove the obstacle (so the rail was flat across the bottom), and opened the hole up for 3/8 hardware.
    Test fit....
    Still need to fill in the flange corners on the front and this one will be ready for SPI epoxy primer to coat all the surfaces before it gets welded in place..
    JUNK ROD, tomkelly88, JOYFLEA and 4 others like this.
  22. Johnboy34
    Johnboy34
    from Seattle,Wa
  23. MP&C
    MP&C
    Thanks!
    Moving on to the outer risers, these ones will be a bit taller due to the recess where the original seat frames bolted. We started out with using the tipping die in the Lennox to thin the 14 gauge cold rolled steel at the bend line for a more crisp bend.
    Next, after making the inside bends, the Fasti-werks bead roller is used with a skate board wheel to add a radius to the outer "leg" of the riser.
    Next time in the shop we'll get the ends closed up.....
  24. JOYFLEA
    JOYFLEA
    Robert
    Nice work as always . I need to bring my pencil to cl*** .
    Got to ask , what do you use the big chain for that is around the front leg of the Lennox ?
    Thanks for taking us along this journey.
    Blue
    Bowtie Coupe and MP&C like this.
  25. MP&C
    MP&C
    When we moved the machine in the shop the first time we added that as we dragged it with the tractor/bucket for final positioning. Never took it off in case we had to move it out from the wall for a larger panel....
  26. CBurne7
    CBurne7
    Man your attention to detail blows my mind. I don't have the patience to do stuff like that, but I also know how the****utic it can be to spend time on the details.
    lothiandon1940, Bowtie Coupe and MP&C like this.
  27. MP&C
    MP&C
    Thanks for the kind words!
    Moving on to closing up the ends of the outer seat riser... Quite a bit of stretch to get this corner to match up to the seat riser...
    Then the corner was Tig welded in place and another test fit with the bucket seat..
    tb33anda3rd, D-Russ, loudbang and 4 others like this.
  28. alchemy
    alchemy
    Are you going to chrome those seat risers? ;)
    MP&C likes this.
  29. MP&C
    MP&C
    Unfortunately we wont be using them at all...
    Well, let's back up and punt one more time. The owner of the 55 stopped by about a week ago and sat in the mocked up bucket seat. She said it sat too high, so our version 2 seat brackets were out. Cutting the floor pan was over-ruled (for recessing the brackets) so we opted for a 14 gauge flat seat pan directly on top of the floor, which also gave us a shape we could eliminate the "step" in the floor.
    Next is to add the wedges to the rear ramp for attaching the rear of the track slides...
    JUNK ROD, hotcoupe, brEad and 4 others like this.
  30. MP&C
    MP&C
    Final design on the bucket seat brackets... and owner approved today as well. One down, one to go.. This is made from 14 gauge cold rolled steel and puts the seat about as low as we can go without cutting the floor pan..
    Video of the seat bracket:
    Seat test fitted:
