Projects WHOA!! Give me a (Wilson Welding) brake!
Discussion in 'Traditional Hot Rods' started by flynbrian48, Dec 10, 2016.
  1. flynbrian48
    flynbrian48
    These are the bomb, if I do say so myself. I had to clearance the square spindles I have on the corners and lower kingpin boss, and pull the steering arm in a skosh, but doesn't this look better than stock? [emoji6]
    54reno, hipster, UNSHINED 2 and 8 others like this.
  2. Katuna
    Katuna
    from Clovis,Ca.
  3. brady1929
    brady1929
  4. prewarcars4me
    prewarcars4me
    from Bhc, AZ
  5. Those are gorgeous!!
    Want to use those on our 34 project I'm now collecting parts for.
    You get those directly from Wilson Welding?
  6. flynbrian48
    flynbrian48
    Yes, Bob Wilson. Great product, nice guy.
  7. BJR
    BJR
    That piece of brake drum missing in the second picture will cause it to be out of balance. You may get a vibration at speed.
    hipster and jvpolvere1 like this.
  8. bchctybob
    bchctybob
    I have a set just like yours sitting on the shelf waiting for me to get back to my RPU project. I really like the look but I was wondering; has anyone weighed them and compared that whole ***embly weight to the weight of the early Ford set up or the Lincoln backing plate version?? I wonder if there is any significant difference in the unsprung weight?
    I don't have any stock stuff to compare it with.
  9. Mr48chev
    Whoo Boy that is sweet.
  10. lowlid30
    lowlid30
    Bob has advertised on his website for years ... Brake Drums coming soon !! Does anyone know if these will ever be Manufactured ??
  11. rockfish
    rockfish
    Whoa! Are those the same Wilson backing plates mention in your build thread that you were not going to put on the car until the ch***is was painted to avoid getting them dirty??? They look great. I wouldn't have been able to wait either.
    Outback likes this.
  12. brigrat
    brigrat
    from Wa.St.
    Don't cheapen yourself, get a set for the rear also!
  13. flynbrian48
    flynbrian48
    I'm going to have broken one repaired. I don't think they're any heavier than the stock backing plates. I decided I had to trial fit them to make sure the steering arm cleared, which it didn't. So, my impatience worked out for the best! [emoji12]
    millersgarage and mad mikey like this.
  14. Brian,
    I put a set on the Winters QC with 9" big bearing ends in my late, sold, '32 roadster. I had Bob drill them for those housing ends. They fit great but I had to bring the axles out of the housing just a bit, so I put about a 1/2"spacer between the bearing and axle flange so that the axle flange would be offset outside a bit more. If you order rears look at brake offset carefully.
    Ended up couldn't get a 5-1/2" bolt circle on those axles. Had Moser make a pair with the offset and they said, can't be done. I said put a spacer in, they said why couldn't we think of that. Duh.
    Charlie
  15. flynbrian48
    flynbrian48
    Charlie, I'm prolly going to get a pair of the thin fake Buick covers and slide 'em over the '55 Chevy backing plates. The rears are hard to see and those will look fine at a glance.
  16. If you have a set of good drums but the linings are bad, worn out, or getting white fuze between the steel and aluminum here a place to get the steel lining replaced
    www.jgrelining.com
    flynbrian48 likes this.
  17. falcongeorge
    falcongeorge
    from BC
    is it ok if I say I would rather have chromed '39-'40 backing plates?
    IronFord, Chris, K13 and 1 other person like this.
  18. brigrat
    brigrat
    from Wa.St.
    It's not only OK it's expected from U, smiley face!
    falcongeorge likes this.
  19. falcongeorge
    falcongeorge
    from BC
    I'd been thinking it since about ten am this morning, took me this long to say it!:D
    Outback likes this.
  20. Speedwrench
    Speedwrench
    Now you have a subproject. Spending the winter polishing all that aluminum.
  21. flynbrian48
    flynbrian48
    I'm going to paint them and polish the fins. And, falcongeorge, if I had them chromed, it'd just make all the old chrome on the car look bad, so, no chrome for me! Plus, I can't afford it! This car will be shiny, but OLD shiny...;-)
  22. falcongeorge
    falcongeorge
    from BC
    I have some 45 fins and a VERY cherry pair of '39/'40 backing plates here for a future project, gotta buff the ever-lovin **** out of them and send them off to the platers. Then when they come back gotta paint the recessed area around the spindles. Mmmmmm, shiiiiiny!:)
    Outback and flynbrian48 like this.
  23. flynbrian48
    flynbrian48
    I have two sets of '40 backing plates, the gnarly looking pair complete, and another pair stripped and very nice, with holes neatly drilled for venting, but one is warped. It could be flattened in a shop press, but I like the finned Wilson ones, and opted for them, as opposed to rebuilding the '40's.
  24. seabeecmc
    seabeecmc
    George, no need to paint the recessed area. Remove the adjusters and you can well polish that area before installing replacement polished stainless adjusters & springs. Regards, Ron adj.JPG
    mad mikey and jackandeuces like this.
  25. denis4x4
    denis4x4
    from Colorado
    Here's a photo of the Hollywood Accessories backing plate cover. Polishing them is a real *****! MVC-014S.JPG
  26. falcongeorge
    falcongeorge
    from BC
    I WANT it painted, I love that look. Will polish that area prior to plating/paint, want to paint the centre of the I beam as well.
  27. I have 2 that I am building: 28 A 2 dr sdn with Wilson backing plates and 45 fin Buick drums front and rear using the Buick hubs (got adapters adapters from sanfordsotherson here on H.A.M.B.) on 32 rail with a hemi. And a 28 RPU ( a cheaper build) with stock drilled backing plates with 90 fined Buick drums front and rear with Buick hubs and a Y Block. I do not know which I like best.
    I also have a set of backing plates with fines that use wildwood calipers and disc brakes
  28. flynbrian48
    flynbrian48
    Both sides on, I REALLY like these!
  29. Max Gearhead
    Max Gearhead
    from Wisconsin
  30. jvpolvere1
    jvpolvere1
