Technical 1934 Ford door latch
Discussion in 'Traditional Hot Rods' started by 31aford, Dec 13, 2016.
  1. 31aford
    31aford
    from az
    I have a 34 Ford tudor with the interior door handles in the middle of the door. The p***enger side you push the handle forward to unlatch the door. The drivers side you pull the handle to the rear to open. This doesn't seem right it seems like either they both push or both pull to open the door.
  2. 325w
    325w
    I did that when I put a rear door remote on the front of the 32 coupe. Was maybe a right on the left from a fordor.
  3. 31aford
    31aford
    from az
    Should the handle push forward to open. It seems like that would make more sense.
  4. Corn Fed
    Corn Fed
    Yes they should both either forward open or rearward open. From what Ive heard, Ford switched the direction somewhere mid year. I think it had something to do with them getting caught on the person as they entered or exited....of course this might be all hogwash. Anyway, you need to find anther latch to match one you already have.
  5. 31aford
    31aford
    from az
    Does any one know which way they should move to open forward or backward since I have one of each.
  6. Baumi
    Baumi
    I can´t help you , I have none of each... but I´m very interested since I´ll have to figure out something for my 34...
  7. Johnboy34
    Johnboy34
    from Seattle,Wa
    One latch was made by "Swiss" and one was made by "Ford". Why they made it two ways??, See the one on the right has an extra pivot. I'm in the same boat, one of each and did not notice till I had them all restored. Maybe we could trade one?
  8. rusty valley
    rusty valley
    on my tudor they both push forward to lock, pull back to open. rumor i've heard is they switched to this style so you could not accidently push the latch open
  9. 31aford
    31aford
    from az
    Mine are exactly like yours the same pivot on the driver's door. Too bad we didn't have the opposite latches I would trade instead of looking for a new latch
  10. Johnboy34
    Johnboy34
    from Seattle,Wa
    :( I'll keep looking also. I've been looking for a while now, good luck...
  11. stillrunners
    stillrunners
    from dallas
    not sure what I have.....pretty sure they were aftermarket made in the 80's.....picked them up at the old Pate swap meet in Cresson....will try and post some picks.....
  12. stillrunners
    stillrunners
    from dallas
    still not sure.....they were marked 34 Ford....... IMG_3193.JPG IMG_3194.JPG IMG_3195.JPG IMG_3196.JPG IMG_3197.JPG IMG_3198.JPG
  13. 31aford
    31aford
    from az
  14. 31aford
    31aford
    from az
  15. RB35
    RB35
    My early '35 front is push forward to open, pull rear to lock. Back doors are the opposite (and suicide style) All the parts ore original.
  16. Johnboy34
    Johnboy34
    from Seattle,Wa
    stillrunners, those are interesting. Sure looks close, looks to be three pair? The center pair has the forward handles. Interesting all have outside key lock on both sides.
  17. stillrunners
    stillrunners
    from dallas
    Well....there's more - just pics of the clearest ones - they should be repo's as they never any of them had the Ford paper tag on them ? They were swap meet stuff I got maybe late 80's ? Should I take the picture of the others - the one with the arm was the only one with one. They do have LF and RH on them.....some have the long body and the others are a short body.....
    Lawrence
  18. brady1929
    brady1929
    Sell them to 31aford, he is a good guy.
  19. stillrunners
    stillrunners
    from dallas
    here's maybe some help IDing what I have.....one pair the main body is 8 1/2 long and the other pair is 10 1/2 long....
    Johnboy34 likes this.
  20. Johnboy34
    Johnboy34
    from Seattle,Wa
    Your # 1 & 2 are the closest to mine, remote handle, Mine are 7 15/16 X 4 so could not be sure it would fit in the door recess without trying. Not sure about the others because they are the early forward handle style. Thanks
  21. 31aford
    31aford
    from az
    I just measured mine they are 8" tall and 4” wide. That is 8 tall not including the lever just the body of the latch mechanism. I can't get the picture to upload says it is too big.
  22. 48-760
    48-760
    from OH
    Ford P***enger car used a out side door lock on the RH side only, the LH side latch mechanism typically do not have the lock mechanism incorporated as some of the examples above. The rear doors of the deliveries have a lock also. The 33-34 restoration book list 3 different style latches for 33 early 34 and two for 34. The 34 latches have a shorter rectangular body than the 33 early 34 which is 10 1/2" tall. All three styles of the 33 early 34 latch would be also be the same height.
  23. 31aford
    31aford
    from az
    I would like to publicly thank stillrunners for the door latches. He was more than generous. I made a donation to the highwayman's y block fund gladly. I needed to p*** on the generosity and willingness to help a fellow car guy that was a total stranger. Thanks again stillrunner.
  24. brady1929
    brady1929
    Then I should publicly thank you Dale for all your help. Sorry for hijacking your thread. Haha.
  25. Dan Derby
    Dan Derby
  26. Dan Derby
    Dan Derby
    Hi I'm a new member and I would like to know if you have any more 1933 Ford door latch mechanisms left and right. I see you sold a set and I was just wondering if you have anymore. It's a two-door sedan suicide door
  27. alchemy
    alchemy
    Dan, that was eight years ago. But maybe…..
    stillrunners likes this.
  28. stillrunners
    stillrunners
    from dallas
    Just got rid of two sets on here a month ago in the cl***ifieds and one set of right side's is all I have left. They are listed in the cl***ified's with pictures as 33/34 Ford. Please send me a private message - thanks.
  29. Dan Derby
    Dan Derby
  30. deathrowdave
    deathrowdave
    from NKy
    Strange things , I didn’t understand between 32 3W latches and 34 5W latches . My 32 3W handles you lift up or back to lock , my Buddy’s 34 5W , the latches were the forward style and moved forward to lock , closing the door to hastily and you were locked out of the 34 . Was this correct operation of a 34 or what was the issue ? I had to help him many times free the locked door to enter .
