History Most Beautiful Flathead Manifold - Eddie Meyer it is!
Discussion in 'Traditional Hot Rods' started by Bored&Stroked, Nov 11, 2016.
  1. Eddie Meyer
    41.9%
  2. Edelbrock
    10.3%
  3. Navarro
    8.1%
  4. Offenhauser
    3.7%
  5. Sharp
    3.7%
  6. Weiand
    2.9%
  7. Evans
    2.2%
  8. Edmunds
    7.4%
  9. Thickstun
    13.2%
  10. Cyclone
    0.7%
  11. Other . . .
    5.9%
  1. someones Photoshop, too many bolts and intake runners, maybe on a Lincoln V12
    Jeff34 and LOU WELLS like this.
  2. dwollam
    dwollam
    Wow! That's some sweet stuff being reproduced! Spendy but oh so cool! I like the OP's Eddie Meyer probably the best but I have a soft spot for the tall Thickstons as I ran one of those for years as a kid on a '39 Coupe. Had the original Thickstun air cleaner too. Paid $8 for the air cleaner in 1972.
    Dave
  3. Hankster32
    Hankster32
    Yes I have one like that and a 3 carb Sharp but don't have any doubles. You see I had 280 manifolds but I sold 80 doubles to young guys that want to keep the history going of early hot rods ( most for less than I payed for them to help the young guys.) Several H.A.M.B. members responding to this thread have better and bigger collections than me ask them.
    LOU WELLS likes this.
  4. Get your votes in Gang . . . one day to go!
  5. Thanks for all the votes and the cool pictures of other really cool manifolds. Truth be told, I would love to have dang near every one posted on here.
    Happy Holidays HAMBers . . .
  6. ct1932ford
    ct1932ford
    You know how I voted!:rolleyes:
  7. dumprat
    dumprat
    from b.c.
    Wonder if they ever made a Meyer intake for a Plymouth six?
    If not I will have to save my pennies for a tattersfield.
  8. Bud Crane
    Bud Crane
    IMG_1075.JPG IMG_1074.JPG I think that Eddie Meyer intakes are a**** the best ever made. I also like the looks of the Alexander. I have examples of each in my stash. I've used them. But when I mash the throttle, the Edelbrock Slingshot looks the best.
    The Eddie Meyer and the Alexander are not particularly good designs, functionality.
    My vote goes to the Edelbrock Slingshot.
  9. Fortunateson
    Fortunateson
    Did anyone mention the Fenton for three deuces?
  10. revkev6
    revkev6
    from ma
    its interesting to me that in a manifold test done by one of the magazines several years back the slingshot tested very well. One of the best 2x2 barrel intakes. it tested better than any single 4 barrel by a fair amount. The magazine tried to claim that the reason was the central location of the 4 barrel made it harder for the mixture to get to the cylinders. i'm having a hard time seeing how the slingshot is much different than the single 4 barrel in that regard besides runner length.
  11. Given how well my Eddie Meyer runs on the 284 cube motor in my 32, I think it is related to the high-rise runner length (like the Slingshot and the Thickston). My guess is that since these engines tend to be torque monsters (not high-rpm), I think there is an increased velocity/ram effect of the intake charge coming down the risers - maybe this helps the charge reach the outer cylinders more effectively? My particular manifold is extensively ported - to match the extensively ported block. One great benefit of the removable tops is that you can get in all the places you want/need to port - unlike a Thickston or Tattersfield high-rise.
    My combination 'in theory' should have been a dog on the street --> huge roller cam, 1.72" intake valves, aluminum flywheel, 25T Zephyr gears, etc -- but it isn't. My hunch is that the long runner high-rise manifold is really helping me on the low-end of the RPM range.
  12. revkev6
    revkev6
    from ma
    your cam was a custom grind if I remember?? possibly more to it than just lift. also, only having two carbs instead of the three or more that really would have been run on a motor that wild helps to tame it on the street. I agree with the possibility of port length having a possible effect.
    what ratio do you have out back??
    I'm sure you have read the article on the manifold dyno runs?? they didn't do an eddie meyer but the slingshot pulled a lot of power and the most torque of the 2x2's they tested. the H&H test motor was a 1/8 bore by 4 1/8 stroker with 1.5 valves and the cam was 280 degrees advertised duration, 0.380-inch lift, and a 111-degree lobe-separation angle, H&H’s custom solid cam was plugged in straight-up. It came up just shy of cracking 200hp with 3x2's... that's a serious flathead. the slingshot was 177hp and 244ft/lbs of torque
    http://www.hotrod.com/articles/hrdp-1301-flathead-ford-intake-manifold-smackdown/
  13. sloppy jalopies
    sloppy jalopies
    Nowhere near as pretty as the meyer stuff,
    but i used to buy edmunds super dual intakes and heads, then ordered alum block letters from a local stove shop, a couple slight drill dimples and some J B Quik and i could name my own speed equipment... painting helped fill the letter to alum gaps, then filed the top sufaces to alum......
    did a STREET KING manifold [volume #12 of MAG-NETO], and a pair of COLUMBIA, NAVADA V8 and SMITTY'S heads...
    ... no limits....
  14. 3blapcam
    3blapcam
    That's really funny! I'm sure you just threw a few collectors into a tailspin! They're running out to their garages checking to see if any of their stuff is just modified junk at this point!!!
  15. Elco Heads
    Elco Heads
    IMG_0807.JPG Flathead V8 471 Blower intake i made awhile ago.
  16. Nice looking manifold, but I must say . . . having 'MUNRO' on it did make me chuckle. You guys from OZ don't normally wave any flags for the KIWIs! Especially when the All Blacks come to town . . . LOL
    hotcoupe likes this.
  17. Elco Heads
    Elco Heads
    Hi Bored & Stroked. I loved your comments about Kiwi's and Aussie,s and yes the All Blacks are the BEST. I am waving the Flag as i am a " Kiwi " been living here in OZ since 1988.
  18. Dale ... your awesome .. great reply
    Cheers
    Tony
  19. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    Here's my vote of course. ;).
  20. the37thstreet
    the37thstreet
    Hands down the pre war water heated Eddie Meyer has it. 20161221_145753.jpg 20161221_145725.jpg
  21. Bandit Billy
    Bandit Billy
    ^^^^That is simply wild! Water heated? That is new to me, explain please.
    paintslinger805 likes this.
  22. Is just the bottom plane water heated?? That one *****in motor. I would have to say both the high rise E.M. Intakes are the best looking along with the edelbrock slingshot. Dales with the way it's polished has to be a winner.
  23. V860too
    V860too
    Not a V12 they only have 4 Intake ports per side.
