Hot Rods Jerry 's 32 5 Window Project
Discussion in 'The Hokey Ass Message Board' started by HomemadeHardtop57, Sep 7, 2016.
  1. 383deuce
    383deuce
    Looking great Jerry & Andy...Keep it going as I know you guys will.
  2. 383deuce
    383deuce
    I am liking the old school hand cut ones the best....Everyone has the press style and ya just don't see the hand cut ones that much so that sets it apart from all the others.....COOL BEANS right there.
    Runnin shine likes this.
  3. HomemadeHardtop57
    HomemadeHardtop57
    Im working on getting the roof insert roughed in with the English wheel. Need to dial in the edges,trim, and then 7 rows of louvers.
    Sent from my SAMSUNG-SM-G891A using The H.A.M.B. mobile app
  4. HomemadeHardtop57
    HomemadeHardtop57
    ls1yj, AHotRod, Stogy and 1 other person like this.
  5. HomemadeHardtop57
    HomemadeHardtop57
    Got the roof insert edges fitted into the tack strip edge. Going to DA the whole thing with 80 grit then start my louver layout
    ls1yj, AHotRod and Stogy like this.
  6. HomemadeHardtop57
    HomemadeHardtop57
    I want to make a full bare aluminum hood for this one and I've been going back and forth with some ideas. I would like to try to do something a little out of the ordinary with this as everything has been done so many times before. Thinking I might do a 3-piece hood with a larger top section that extends down into smaller side pieces. When I louver everything I'll have the rows tie in one panel to the other. I did a quick sketch I'm no Pic***o. Haha 1481127999318.jpg
    ls1yj, Stogy and loudbang like this.
  7. loudbang
    Like this you mean :rolleyes:
    Stogy likes this.
  8. HomemadeHardtop57
    HomemadeHardtop57
  9. HomemadeHardtop57
    HomemadeHardtop57
    Chris at Grace and Co. and I put our heads together and came up with these cool air cleaners. Chrome with br*** goodies
    ls1yj, neilswheels, clunker and 6 others like this.
  10. brady1929
    brady1929
    Wow, someone needs to sell those to everyone.
    neilswheels likes this.
  11. Fortunateson
    Fortunateson
    Dear Santa, can I please have three of those air cleaners?
    54reno and loudbang like this.
  12. HomemadeHardtop57
    HomemadeHardtop57
    Rear suspension hung. I'm going with a 40 Ford banjo 3.77 gears
  13. HomemadeHardtop57
    HomemadeHardtop57
  14. HomemadeHardtop57
    HomemadeHardtop57
    Metal finishing my roof top edge and top insert before I louver it. Getting there. Makes the body work prep on the insert minimal after the holes are in 1481394856095.jpg
    ls1yj, Stogy, AHotRod and 1 other person like this.
  15. Kiwi 4d
    Kiwi 4d
  16. 383deuce
    383deuce
    Very nice workmanship on the top incert. It is fit to a tea....This is not easy to do as I have made one for my 3 window and it did not look this dam good. I covered mine with hartz material.
  17. HomemadeHardtop57
    HomemadeHardtop57
    ls1yj, Stogy and AHotRod like this.
  18. DDDenny
    There have been many of these done, the problem is some look like the guy just didn't want to pay the "professional" price and the end result showed. I'm sure this is not the case here because I've seen your work.
    One problem I've seen is the way the line of the formed body contour is thrown off by the lower seperation point of the hood sides. This may not be an issue for you, but I just can't warm up to the look.
    This channeled car has what (I think) you are proposing. It was built about 1947 by Malcolm Schutt.
    AHotRod likes this.
  19. HomemadeHardtop57
    HomemadeHardtop57
    I agree DDDENNY. Disrupting the flow of the body reveal line into the hood is so so. I'm not 100% what I'm doing yet..but things have to flow and look right
  20. AHotRod
    AHotRod
    Those hand cut louvers look amazing !
    Love your build.
  21. 51box
    51box
    from MA
    Those hand cut louvers do look great. Ch***is is coming out really nice, damn you guys work fast.
    Keep the pictures coming, enjoy following this build.
  22. HomemadeHardtop57
    HomemadeHardtop57
    ls1yj, Ron Funkhouser and Stogy like this.
  23. Atwater Mike
    Atwater Mike
    Love the way you linked up the '40 pedals. The ball bracket on the X leg is factory-like, how much did you take out of the cross ('Z') bar?
    Very sanitary...
  24. HomemadeHardtop57
    HomemadeHardtop57
    I wanted to mention again that Andy Kohler, thunderbirdesq here, is helping me with the ch***is. On top of that he's a pretty good dude.
    The front legs of the X member were pulled in a bit and the rear legs spread and 40 pedals were bolted in the stock location. That shaft was shortened about 2.5 inches to compensate for the squeezed legs so the geometry would be right to operate the clutch. The pedals were also heated and tweaked slightly.
    ls1yj and loudbang like this.
  25. chaddilac
    chaddilac
    Great work Jerry!! Looks awesome!
  26. HomemadeHardtop57
    HomemadeHardtop57
    Going with hand cut louvers that I do. I was hesitant at first because this style is a lot more work intensive. I have plans for a full louvered hood as well and maybe my decklid. I'm going to have tons of time in these on the whole car but what the hell.
    The way I do these is I first establish a center line for each row. I usually like to do 7 rows on a trunk lid and figured 7 would look pretty good on this roof insert. After I have the seven rows layed out I then draw a 1.5inch spaced line on each side of my center line. This gives me a 3 inch wide space to drawl my cut line for each louver.
    Each louver has to be cut one at a time with a die grinder and cut off wheel. Then each cut is lowered into my fixture and then hit with a small sledge...one at a time. After, each one requires some tweaking to make sure they are hit through at the same height. It's a process!
    Tonight I just took my time and got the layout set up. This step alone took a couple hours. Tomorrow I'll start cutting the lines and then smacking them.
    It's a very long tedious process but in the end it looks pretty cool. 1481685885052.jpg 1481685890128.jpg 1481685894174.jpg
    ls1yj, AHotRod, Stogy and 2 others like this.
  27. Hendee
    Hendee
    Watching closely and learning lots on this thread. Thanks for sharing what you do.
    Tom
    HomemadeHardtop57 likes this.
  28. HomemadeHardtop57
    HomemadeHardtop57
    The air cleaners from Chris arrived today. They are beautiful and really look right. Very well made..thanks Chris!
    ls1yj, clunker, AHotRod and 6 others like this.
  29. wagoon78
    wagoon78
    Love this build. Keep the updates coming.
  30. thunderbirdesq
    thunderbirdesq
    Hi guys, I don't have as much "internet time" as I used to but I just wanted to pop in and say how thrilled I am to have a hand in jerry's latest build. We have become pals over the years and when he asked me to help out with the ch***is on this car I jumped at the chance. He's got a great eye for detail and uses unique parts to build *****in cars that have a definitive style and I am really stoked to be a part of that process! This thing will be rolling and steering in a day or two so my job is just about done, glad y'all dig what we're screwing together here. Cheers!
