  1. Took some digging, but found an image.
  2. JD Miller
    JD Miller
    DOH ! ! !
    Bomb likes this.
  3. Depression Era wrecker?
  4. Uh, it was just supposed to be a tune-up!
  5. JD Miller
    JD Miller
    Id think this tow driver would get fired for doing that. Scratching up and damaging the Tow Truck
    C. John Stutzer, Dave Mc and loudbang like this.
  6. Bleach
    Bleach
  7. Alrighty boys and girls, this time I got you a REAL winter machine!
  8. joemac05
    joemac05
    He is using a twin post hoist. You can lift the car and support either end or the whole car with the jack stands that come with the hoist. With the jack stands in place you were clear to work on whatever without the hoist being in the way. They used to be THE hot ticket and I worked with them for about 40 years. Time has passed them by......
    BornBuick and loudbang like this.
  9. joemac05
    joemac05
    They use air over oil. A large oil tank is pressurized with air and the oil is let in and out of the rams. The oil is metered through an orifice so that the rams can only move so fast. However, every now and then the tank would spring a leak so that you did in fact use air then shit did happen. If you were asleep at the switch and did not notice the tank was filling up with WAY too much air the next act was dramatic. I had a 68 Eldorado clear the hoist (like in the air) by a foot. Never lost one or had any damage though. Then the hairy part, trying to let it back down. You would start bleeding the air out and you never knew when it was going to start to drop, or which end would go first. When one did drop it would be about 3/4 of the way and then the air spring affect would shoot it back up again. During that episode the other end would start in. Once safely back on the ground it was time for a trip to the locker room for fresh underwear.
  10. woodbutcher
    woodbutcher
    :D I well remember the day a guy brought his Rambler into a shop with a two post lift.They got it about 18" off the shop floor,THEN it folded in the middle.
    On the grocery stores.How Many remember the Great Atlantic and Pacific Tea Company stores?Don`t remember those?How about the A&P stores.The first aroma that hit ya going in was FRESH ground coffee.8 O`Clock brand.YUMMMMMMMMMMMMM.
    Good luck.Have fun.Be safe.
    Leo
  11. loudbang
    Lusso
    Miss Moon
    once more
    Missile PILOT LOL
    Mr Speed AMT model kit
    "Poison Ivy" Jimmie L. Holmes 1954 Ford
    Captain Kirk tries on Gene Winfield's Reactor for size.
  12. hotrodA
    hotrodA
  13. DJCruiser
    DJCruiser
    from CT
    Not twin cam models, missing the unique badging and wheels.
  14. tb33anda3rd
    tb33anda3rd
    yep! that's a good description. i remember lifting a caddy once and the angle of the lower control arms slid the outer slides in and the car dropped a little. we chained the slide to the lower arm and brought the car down. that was the only problem i ever remember with one of those.
  15. I sure do. For years I bought Eight O'clock Bokar in the bean and grind it at home ( I was so elite!!) with a little Braun grinder.
    My Mom was an A&P gal, her sister was a Kroger's devotee.
    loudbang and Bomb like this.
  16. Bleach
    Bleach
    Don't need no stinkin' lift.
    loudbang and biggeorge like this.
  17. Bleach
    Bleach
  18. Bleach
    Bleach
