Technical Cleaning up a old 350 sbc
Discussion in 'The Hokey Ass Message Board' started by toxicctom, Dec 14, 2016.
  1. toxicctom
    toxicctom
    im planning on building a better motor later, after I get everything figured out and the body work on the car done.
  2. squirrel
    the letter in the VIN you're looking for is not on the engine, it's on the car it came from.
  3. toxicctom
    toxicctom
    car is nonexistent lol, anyway to figure out if that 100 dollar cam and timing chain will fit my motor?
  4. squirrel
    I think you can swap them over without any trouble....they used flat tappet cams in the truck motors those years, same block.
  5. toxicctom
    toxicctom
    Any tips for picking the right cam shaft for my motor? sorry for so many questions.
  6. squirrel
    The cam needs to match the vehicle, and it's intended RPM range. If you are using a stock transmission and gearing, then a stock or almost stock cam is right. If you are adding a high stall torque converter, steeper rearend gears, etc and you'll be running headers, then a longer duration cam will let the engine make more power at higher rpm, and you'll have a quicker car.
    So, figure out what exactly you want the car to do, then pick the right cam for that. And beware that as the cam gets "bigger", you also want to change other things in the engine to work with it...such as better flowing heads, more compression, higher rpm range intake and carb, stronger bottom end to live at the higher rpm, stiffer valve springs, etc.
  7. oldolds
    oldolds
    Maybe stop a a machine shop that builds race motors. They may have a used roller cam from a recent build so no rust. I know most guys don't like used cams, but budget builds require sacrifices. I know the machine shops by me usually have a lot of "good used ****" laying around. Sometimes they are happy somebody makes use on it.
    squirrel likes this.
  8. read this for what you can do on your own with limited mechanical experience. Then let me know if you have questions.
    http://jalopyjournal.com/forum/threads/tear-down-and-inspection-is-this-still-tech-week.679583/
  9. toxicctom
    toxicctom
    Hey so my buddy has this old chevy box van and said I can take whatever parts off it I want, I was thinking I could take the radiator, Distributor (till i get a new one) Alternator and brackets, maybe the flex plate if it will come apart. Anything else yall think I should try and grab?
  10. bobss396
    bobss396
    I've done a few stock car engines on the cheap, bought most out of junk cars since I ran in a claimer cl***. We would clean up the engines more on the outside to get someone to try to claim it for $800. New paint, move over the go-fast parts from the previous engine that was too tired to use. They would last a whole season at times... or go up in a cloud of smoke, just pray we could use the camshaft again.
  11. squirrel
    I don't know what you are planning to do with the motor, so I have no idea what parts you'll need.
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    No one can make a shopping list but you. Getting the wrong thing, forgetting something and making mistakes are all part of the experience. Good Luck
