Hot Rods THE INDUCTION THREAD
Discussion in 'The Hokey Ass Message Board' started by mad mikey, Dec 9, 2016.
  1. mad mikey
    mad mikey
  2. bobbytnm
    bobbytnm
    Great thread!
    Subscribed
    falcongeorge and mad mikey like this.
  3. falcongeorge
    falcongeorge
    from BC
    Yes, but the bottom side is where the action is. I don't have enough hood clearance for the whole ****aree, so I just bought the shear plate itself, laid a open plenum holly gasket on the bottom of the shear plate, tapped around it with a small hammer, cut the gasket on the line, then blued the carb mounting face on the intake, flipped the gasket over, and scribed the mounting face on the modified gasket, and rolled the carb mounting flange back with a grinder to match the gasket.
    loudbang and mad mikey like this.
  4. saltflats
    saltflats
    from Missouri
    So is the bottom of the shear plate super secret or is it just a 4 hole spacer?
  5. falcongeorge
    falcongeorge
    from BC
    Go into the "online store" on the Reher-Morrison website and you can see the bottom side. That's where the action is. I would use these where you have a booster signal issue, which will usually be indicated by a drop in torque with a corresponding drop in BSFC. In other words, the torque is dropping because the engine isn't pulling enough fuel through the booster. If you see a drop in torque with a RISE in BSFC numbers, then it's usually going to be combustion related, but if the BSFC drops along with the loss of torque, then I would look for a booster signal issue, usually related to something in the intake, or the intake closing point being REALLY out of whack. But I have seen the loss of torque, in conjunction with a dropping BSFC in a number of clevelands, with different cam timing, so I think it's an intake design issue. I think I know what it is specifically, but I am staying mum on that.
    As an aside, but totally funny, every time I type BSFC, my daughters iPad changes it to "Barcelona", and I have to re-type it! Man, this world is sure getting dumbed down!
  6. falcongeorge
    falcongeorge
    from BC
    Hell no!:p Check in the online store, and you can see the underside. No, it is definately NOT a 4 hole spacer!
  7. saltflats
    saltflats
    from Missouri
    I will try again...The only picture on there page was the same image as above.
  8. saltflats
    saltflats
    from Missouri
    Deuces and loudbang like this.
  9. saltflats
    saltflats
    from Missouri
    Wonder if my buddy with the 3D printer can pull this off.
  10. falcongeorge
    falcongeorge
    from BC
    The Reher-Morrison open spacer that comes with it will match up with the line around the edge. If you don't have the hood clearance for the whole package, you want to do what I outlined above in post#305. Ideally, you want to blend the cut at least 1/2" down into the plenum, and use the customary 1/2" minimum radius at the bottom of the cut.
    mad mikey and saltflats like this.
  11. saltflats
    saltflats
    from Missouri
    Got it.
    Makes me think about my opened up 881.
    But the big plan is to cut one up and make it single plane and move the carbs more inline with the ports.
    And that will give me the ability to run 4150 carbs.
    I have seen this done and believe I can pull it off.
    mad mikey and falcongeorge like this.
  12. falcongeorge
    falcongeorge
    from BC
    Do you have pipemax?
  13. saltflats
    saltflats
    from Missouri
    No but I have read some stuff from people that have it and... think I just may have to have it for Christmas.
  14. falcongeorge
    falcongeorge
    from BC
    It's pretty useful, unfortunately it's on my regular computer, which has s being worked on right now.
  15. mad mikey
    mad mikey
    Interesting stuff, thanks george.
    loudbang and falcongeorge like this.
  16. zorro4153
    zorro4153
    from Pa
    Stebo27, Deuces, exterminator and 3 others like this.
  17. mad mikey
    mad mikey
    Is the 2 port converted to electronic?
  18. looks to me like it is - see the throttle position sensor on what looks like a metering valve? Plus the injector hoses don't run to the metering valve...
  19. mad mikey
    mad mikey
    Thats what I see as well. I would like to here some real world results good or bad of running a 2 port electronic on the 471. I may go that rout in the future, they are pricey though.
  20. bobbytnm
    bobbytnm
    Currently fabricating some air cleaner ***emblies to fit these 2 Stromberg WW on an old Weiand intake for my buddy's 58 Packard
    Stebo27, Deuces, falcongeorge and 5 others like this.
  21. Flatred53
    Flatred53
    from Sweden
  22. mad mikey
    mad mikey
    Stebo27, Deuces and loudbang like this.
  23. mad mikey
    mad mikey
  24. loudbang
    Let's finish off my supply of FE stuff.
    Moonlighter injected
    Holmann & Moody cross ram
    Ford FE with Mickey Thompson Hemi heads and cross ram
    Mickey Thompson power ram
    Tunnel port ? Injected
    Webbers? on FE
    Webbers on Cobra
    1947knuck, Stebo27, Deuces and 3 others like this.
  25. hotroddon
    hotroddon
    That is really disgusting. Nothing Studebaker about it - an LS motor with fake injectors and a poor old Magneto that has been cannibalized and mounted to that plate
    deadbeat, Dean Lowe and loudbang like this.
  26. hotroddon
    hotroddon
    Nope, not Weber's. That is an Imagine Engineering Fuel Injection setup
  27. mad mikey
    mad mikey
    Now that is a Great FE. Big $$$$$.:D
  28. hotroddon
    hotroddon
  29. Flatred53
    Flatred53
    from Sweden
  30. George Klass
    George Klass
    If someone is running a BB Chevy and is considering EFI, we (Accufab, Inc.) offer a complete EFI intake manifold system, which includes an Edelbrock Tunnel Ram, a custom aluminum top plate, billet fuel rails, a pair of Accufab 6500 series Throttle Bodies (4500 Dominator bolt pattern) and attaching bolts. The Throttle Bodies each flow 2,656 cfm and have progressive linkage. Surprisingly enough, even with a total of 5,312 cfm, we have customers that confine all their driving to street use (that's the neat thing about EFI). The entire package is $2,620. Add your own fuel injectors and you have a complete EFI induction system...
    Stebo27, Deuces, desotot and 3 others like this.
