Technical ***December 2016 Banger Meet - Dear Santa, A new C block***
Discussion in 'Traditional Hot Rods' started by Jiminy, Nov 30, 2016.
  1. V4F
    V4F
    from middle ca.
    nice body work !
    without checking clearances its all a guess
    Dannerr likes this.
  2. BCCHOPIT
    BCCHOPIT
  3. V4F
    V4F
    from middle ca.
    damn nice work as always
    BCCHOPIT likes this.
  4. GASSERBOB
    GASSERBOB
    from USA
    Beautiful work. Bob.............
  5. Sometimes a worn or outta size cam gear with cause a knock ("Been there..Done that")
  6. Bluto
    Bluto
    Good to see your still kicking John.
    Merry Christmas and the best NEW YEAR to all of you
    This morning I remembered an engine noise.......
    One day driving the engine developed a loud t******* noise. This got worse and was loudest at idle. Soon it was followed by an intense vibration...... the thump and shakes subsided with more revs. "Oh Well! I've a piston collapsed and t*******. The noise was forward and high up in the engine. The thump you could feel in the clutch peddle! I got home opened the hood and started looking around for the source. When I couldn't see anything I shut the engine off and looked again. I was running a thick/wide fan belt. As luck was on my side it stopped in a place where I could see I had lost about a 4 inch piece on there underside of the belt. Cut the belt and started the engine..... NO NOSE anymore. No later pump turning either so shut it down quickly and fitted a new belt. I am still driving on that belt but now I carry a spare under the seat........
    There is no liquid solution to proper diagnosis and repair.
  7. RussTee
    RussTee
    Merry Christmas every one from down here in New Zealand where it is a warm sunny summers day
  8. 97
    97
    And every now and then the earth moves for ya:eek: ... just a little summer shake up , eh Rusty? I forgot to tell you I was on my way home from a southern trip , staying at Bob's place in Kaikoura on November 14, didn't get out for a month. I should have just visited with you and stayed in Christchuch for a few days.
  9. RussTee
    RussTee
    You would have been very welcome and could have helped get my motor tuned I have a feeling my plug leads are braking down
  10. green73
    green73
    It's been an educational experience tinkering on the A since I got it. I had (past tense) it running pretty good after rebuilding the carbs, putting a new head gasket on, and electronic ignition. Something happened along the way and started getting gas in the oil. After a bit more tinkering, I found the back carb has a vacuum leak, and parts are on the way for a re-rebuild. I am also giving in on the plugs and going with modern 14mm plugs. I also need to plumb in the fuel pressure gauge and run a compression check. Hopefully the gas in the oil problem hasn't caused problems necessitating a rebuild. I still want to drive it a bit before going with the 8BA. After I do that it'll live on in a friend's car who's planning on using my engine in his build. I want to p*** it along to him running it's best though.
  11. Bluto
    Bluto
    RussTee
    Try one of these ..... It will tell you the KVA in wires and a bunch of other things too :)
    I'm sure you can get them local to you. I've used one for years
  12. RussTee
    RussTee
    Thanks Bluto just waiting till things open up after the christmas new years break then will put it on a rolling road and can really see whats going on got to sort the electrics then tune the winfields its running but breaking down under load I suspect electrics but its all fun aint that why we do this would be boreing if things just went every time the challenge is to sort them even though age is catching up with me I hope to never finish this thing still its nice to have it on the road
    Dannerr likes this.
  13. Bluto
    Bluto
    Spark plugs fail under compression also
    If you hold the crop next to your year sometimes you can hear it ark ....... NOT TOO CLOSE TO YOUR EAR, PLEASE!!!!!!
  14. V4F
    V4F
    from middle ca.
    I'm using the "E3" spark plugs & they burn much cleaner than regular plugs in my car
  15. RussTee
    RussTee
    Unfortunately my plugs are the very small diameter ones I dont think ideal for the job but someone wiser than me may be able to advise
  16. Garpo
    Garpo
    Hi Russ, Close inspection of the plugs and the motor will tell you what it wants. Trouble with that is carb settings and timing tend to cloud the issue.
    Can find lots of plugs and old style HT lead and fittings if you need it.
    Garpo
  17. green73
    green73
    Think I stumbled onto my issues. Doing some tinkering, i ran plumbed in a fuel pressure gauge. 1.5 psi. Still waiting on 1 pair of plugs, but I was able to run a compression check with the adapters, 120 psi on all 4 cylinders. Hmm.. Confused, really confused. Took a step back and thought for a few more minutes. Started looking more closely at my linkages and return spring set-up while swapping the carbs positions. once it was all back together and all linkages set to a better neutral, BANG it started running good again. Seems as though I didn't fully lock something into position after the first carb rebuild. I'll be refining the linkages in the next couple days. Happy to have it running good again.
    Dannerr and ROCKER77 like this.
  18. Jiminy
    Jiminy
  19. V4F
    V4F
    from middle ca.
    thanks john ..................... happy new year
