Projects '51 Nash Statesman engine swap
Discussion in 'The Hokey Ass Message Board' started by mzweig, Mar 2, 2014.
  1. MARKDTN
    MARKDTN
    Cool looking car! Not sure I would have run the battery cables with the fuel line though.
  2. mzweig
    mzweig
    Bought them from a supplier in Seattle. Better cooling
  3. mzweig
    mzweig
    Underside of the Nash. Exhaust goes on Monday.
  4. mzweig
    mzweig
  5. mzweig
    mzweig
  6. Rusty O'Toole
    Rusty O'Toole
    I'm not saying it's bad. I'm saying it's been done a million times over the last 30 years although not often to a 51 Nash 4 door.
    I was a little ticked about wasting my time but I got over it.
  7. You're not going to run that Antique license plate on that car, are you? Those are legal for preserved original cars or restored ones, not street rods.
  8. jimmy six
    jimmy six
    Nice installing of everything I'm sure it will be dependable and fun, but all old cars look better whith a Chrsler Hemi under the hood. After seeing the Hilman with one and a buddies Valiant with one any things possible. Great write up Thanks.
  9. amadeus
    amadeus
    mzweig likes this.
  10. mzweig
    mzweig
  11. mzweig
    mzweig
  12. mzweig
    mzweig
  13. mzweig
    mzweig
    These pics show the exhaust system under construction and completed. It has electric cutouts that byp*** the gl***packs and run all the way out the back.
    Hnstray likes this.
  14. mzweig
    mzweig
    Give me a break. This is the tag that was on the car before we did anything to it. The car does look stock other than slightly lowered--even down to stock wheelcovers.
    mcnally351, vtx1800 and Hnstray like this.
  15. mzweig
    mzweig
    Hemis are nice but this one barely fit as it was. You should build one with a hemi--it'd be cool!
    Hnstray likes this.
  16. mzweig
    mzweig
    Exactly. It hasn't been done a million times to a '51 Nash Statesman. It posed some challenges!
    Hnstray and biscaynes like this.
  17. cfmvw
    cfmvw
    I've had my 1960 Bug registered as an antique here in Maine for years, and it's far from stock!
    Really enjoyed following the Nash buildup...looking forward to seeing some finished pics of it. You put a lot of thought into the design and execution of the swap and upgrades. That car is a real sleeper, the exhaust tips are the only real giveaway that things aren't what they seem.
    Hnstray and mzweig like this.
  18. biscaynes
    biscaynes
    nice clean build, thanks for sharing it!
  19. mzweig
    mzweig
  20. rusty rocket
    rusty rocket
    I dig it. Kool *** car if you ask me.
  21. mzweig
    mzweig
  22. mzweig
    mzweig
    This is the dash in my '51 Nash. We removed the "glove drawer" and installed this early T-bird replica hang-on air in the hole. That worked out great. Converted all stock gauges to work in the 12-volt system we now have. Had the radio converted to AM/FM with 40 watts per channel a IMG_20160527_113700.jpg IMG_20160527_113655.jpg IMG_20160527_113655.jpg nd blue tooth. Also if you look to the left you'll see IMG_20160527_113655.jpg the shift indicator lights--really necessary as we hooked the automatic to the stock column shifter.
    Shadd Schutte, cfmvw and Hnstray like this.
  23. mzweig
    mzweig
    Cars and Coffee in Springdale, AR, this morning..
  24. arkiehotrods
    arkiehotrods
    I have seen Mark's Nash several times and if the hood is down, the only clues that it isn't stock is the lowered stance and the four exhaust tips out back. Looks old, drives new, way cool!
    Sent from my SAMSUNG-SM-G900A using H.A.M.B. mobile app
  25. bchctybob
    bchctybob
    Nice build! I like the dash in the Nash. But I have to say those cars are ug..uh, homely. Especially the four door. Makes for a great sleeper though.
    mzweig likes this.
  26. southerncad
    southerncad
    OK, I asked before, now where are the pics of a smokey burn-out!
  27. tinsled
    tinsled
    I had a car exactly like this one, 1951 Statesman - It has coils on every corner and torque tube.
    Do not know if the earlier Statesmans were different, but for 1951 no leaf springs fer sure...
    Mine was also survivor, factory stock. But it was fitted with factory installed B&W R10 overdrive, which made a world of difference. This tub is not exactly what you'd want to be a road rocket, but with the OD it cruised happily 60-65 mph all day long.
    I tuned the engine up and enjoyed the Nash as it was. Then I came in the point with too many toys and let it go...
  28. stevenlesser
    stevenlesser
    Hi I have a 50 airflyte Nash ,the engines out and the rear axel Twisted out of place unloading it ,so basically I have a fair body in the driveway ,with so much missing I was thinking of setting it on a as complete as possible s-10 crew cab ,83-98 minus the body .the airflyte is 121 " wb I hear the a-10 is 123" any advice?
  29. mzweig
    mzweig
    Different project from mine altogether. I would imagine that the car wont sit low enough on that ch***is. You will also probably have a lot of issues related to inner fenders and front track of the S-10. The Nash is about 49 inches which is how you can steer it with the enclosed wheel wells it has. But I don't know...
  30. mzweig
    mzweig
    Nash update. The car is being painted in its original color scheme. Should be done this week. Also had bumpers, hood ornament, and trunk escutcheon all rechromed. Last will be interior shop. Then done! Currently building a Model A Tudor with a flathead and 5 spd T-5 trans.
    kiwijeff likes this.
