I will try to list a range of products that we will give special pricing for HAMB'er. Please message me to work out shipping cost, I can absorb some but some heavy items might be cheaper to buy local. Any one that buys from me can call or text me if you have any issues. 4:1 Acrylic Urethane most colors $120/gal 3:1 Polyurethane most colors $120/gal Acrylic Enamel most colors $120/gal Base coat (2:1) $135/gal Enamel $65/gal Vinyl Lacquer in Satin or matte $120/gal Quart of Hardener Universal $35 Quart of low VOC hardener $40 Any Satin Hot Rod color ready to spray $95/gal Matte Black lacquer for ch***is / Radiator $45/gal 1:1 Epoxy black/Gray (makes 2 gallons ) $150 Candies must message first Gallon Urethane Reducer 860,870,885 $29/gal USC Body filler 15310 lite weight $12.50/gal Premium body filler $35 gal Custom filled aerosol cans $9.75 ea 3/4 masking tape $1.99 roll 1.5 masking tape $3.99 roll Premium clears $105 kit and up Economy clear $55 kit Lacquer primer $35 gallon 2k urethane primer high build $85.50 kit 2k urethane primer regular build $85 kit Epoxy bedliner with gun $135/gallon kit Urethane Bedliner no gun $95/gallon kit Gold premium sandpaper 6" psa sticky 80-600 grit 100 sheets to a box $26.50 80-800 grit 50 sheets to a box velcro $19.99 box We also custom build coatings, private label etc. If you need a specialty Paint made or an idea for one let me know.
I have 6 gallons of lime green acrylic urethane that we mixed that was the wrong color for one of our local customers. If anyone wants to buy $50 gallon, activator is $35 quart plus shipping. If you want all 6 gallons I will sell all 6 with activator for $300. That's enough to paint your house! I am going to list some of our older stuff that we need to move. Any questions call or reply. Thanks Quality Coating Supply 6789827820 Sent from my SM-N920V using The H.A.M.B. mobile app
