Projects hemi water crossovers- whatcha got because this sucks.
Discussion in 'The Hokey Ass Message Board' started by 31Vicky with a hemi, Dec 22, 2016.
  1. This came up in another thread and it deserves its own.
    it's easy, it's available but it's oh so God awful ugly.
    That hose **** unit is supposed to replace this out of production unit from PAW.
    Now that's what I'm talking about !!! And there's no comparison.
    So did you do something cool? Make something? Looking for ideas?
    Have a PAW unit? Want to sell it? Want to get it copied?
  2. DDDenny
    Some years back a friend (RIP Terry) built a killer 354 Hemi for his gorgeous 57 BelAir.
    He was doing fine with my input on component selection(I thought) then another guy at work let him see a magazine article about hemis and let me just say it looked like his car was parked inside an exploding Hot Heads warehouse, yuck.
    Valve covers, Edelbrock carbs, air cleaners, crossover, etc.
    But the most hideous was the top mount alternator, omg.
    And who thinks chromed Hemi valve covers can be improved on.
    Sorry Vicky, rant over.
    brigrat likes this.
  3. Oh you're preaching to the choir my friend
  4. Hey, an alternator might be a good way to cover or distraction from that BS water crossover :p:D
  5. bostonhemi
    bostonhemi
    There's one for sale on the ebay. I think about 150.
    If u call HH and tell then you want it all silver they might do that for u. They did it for my intake remote thermostat kit. So whats wrong with a stock one?
    saltflats likes this.
  6. Marty Strode
    Marty Strode
  7. slayer
    slayer
    There was just two different aluminum crossovers on ebay last week. The cast one on the right has one day of bidding left! The polished one that looked like an original was mighty tempting.
  8. kaspar
    kaspar
    bantam, ottoman, dwollam and 3 others like this.
  9. 392
    392
    Factory unit is tried and true. And no bling.
    Andy, 73RR and Just Gary like this.
    Here's mine from hothemi heads. Looks and fits nice
    dwollam, Dog_Patch, mgtstumpy and 2 others like this.
  11. I'm going to appreciate any ideas, because they can spring board to other cool ideas. Especially like Marty's
    But let's not forget the Supercarger part. The Paw ad, supercharged.
    It works like this-
    Or this lame *** **** !
    Don Martin, mgtstumpy and dwollam like this.
  12. Roadsir
    Roadsir
    I've been thinking about these too, and trying to decide if I should use a the stock crossover, or the intake ports as similar to the pics above.
    The PAW one on EBAY is bid up to $308! and still going....The HH is similar just a front facing thermostat.
  13. fabricating a part similar to these , in a configuration that fits the engine and clears the obstructions would not be difficult.
  14. bostonhemi
    bostonhemi
    With your skills you could design your own and make a bunch of them. I'm sure they would sell.
  15. Thanks!
    I don't know, I get hung up on weird **** like this. To me it's unacceptable but it seems that the hose thingy is just fine and perfectly acceptable to the majority
  16. squirrel
    The only difference between the hemi and my 427 chevy, is that the chevy has 1/2" pipe threads on the old Weiand blower intake, that you can run hose barbs in, and heater hose to connect to the Offy remote thermostat housing. You can replicate this by making a couple chunks of aluminum plate, maybe 1/2" thick, cut to shape, with two bolt holes, and a 1/2" pipe thread hole in the center. Bolt the plates to the fronts of the heads.
    Then it would get done.
  17. Just Gary
    Just Gary
    My stock Chrysler crossover with a HotHeads intake. Once I decide how to mount an alternator, I'll probably trim off its unused ears.
  18. alfin32
    alfin32
    from Essex, Ma.
    image.jpeg Hot Heads unit, cut apart, and milled a new top to match the valve covers.
    69fury, Russ B, JLeather and 12 others like this.
  19. phat rat
    phat rat
    This is what I built for my 270" Hemi as I didn't like what was available. It's not finished yet as I had a couple of pin holes at first and wanted to make sure I'd cured them. I ended up using JB Weld around the seams to correct that. I still don't see the one Scotty posted on Hot heads site.
    vtx1800 and 31Vicky with a hemi like this.
  20. Top far left ****on.
    Their pic is polished and looks more round, scotty's pic looks flatter.
    Maybe they are different maybe it's digital illusion ?
  21. Just Gary
    Just Gary
    Here are some others to provide some ideas:
    Homemade:
    B***' Hemi coupe:
    Bobby Hilton-built: Blown, Nailhead A-coupe:
    mgtstumpy likes this.
  22. Marty Strode
    Marty Strode
    When I built this, I didn't want to use connecting hoses. Using stainless bends and threaded tube, after installing the threaded tubes into the thermostat housing, I completed the mountings at the heads and welded it up. The problem I had, was getting it tight, sealed and have the clocking and centers work out. I finally sawed it apart, and went with the hoses, it was the best I could do.
    6sally6 and BigDTexasKid like this.
  23. brigrat
    brigrat
    from Wa.St.
    Yes I know AirCraft fittings and hoses have been around a long time but,JMO the "hose thingy's" only look good if you have other "hose type thingy's" to complement each other (chrome, polish, bling, etc.) after a while it gets kinda Street Roddy looking. If it's the one and only "thingy" it sticks out like a donkey ****........................................
  24. Blues4U
    Blues4U
    from So Cal
    IME the JB Weld won't hold up long and it will start weaping coolant.
    Dog_Patch likes this.
  25. phat rat
    phat rat
    31Vicky, yes those are available for the Chrysler but not the DeSoto or Dodge Hemi. Also when I made mine I wanted a straight clean line not the hose sticking way up in the air like it would've if I had the thermostat mount horizontal instead of vertical like I made it.
  26. alchemy
    alchemy
    How about no crossover, and run two hoses to the top tank of your radiator? Ala' flathead Ford.
  27. That's also an option.
    I had my radiator built that way too.
    The problem arises with the thermostats and a housing. I hunted down the smallest body with biggest holes units as well.
  28. alchemy
    alchemy
    Flathead Fords (pre 1949) have the thermostat setting on top of the neck of the head, and I inserted a short length of pipe above it in the hose to hold it in place. No housing needed. Your difficulty may be finding a small diameter thermostat.
  29. phat rat
    phat rat
    Two hoses is the way mine was setup when I got it, see picture, trouble was no thermostats. When I had to have a new radiator built I wanted a thermostat so I had the new one built for one hose. Then built my piece for the thermostat
  30. saltflats
    saltflats
    from Missouri
    Would the hose and AN fitting work if they were all just black.
