Hot Rods Jerry 's 32 5 Window Project
Discussion in 'The Hokey Ass Message Board' started by HomemadeHardtop57, Sep 7, 2016.
  1. gonzo
    gonzo
    So true.
    Looking great.
  2. 383deuce
    383deuce
    Looks great guys!! Can't wait to see more. Got the bars today Jerry, Thanks
    HomemadeHardtop57 likes this.
  3. HomemadeHardtop57
    HomemadeHardtop57
    Bill Flock likes this.
  4. Stogy
    Stogy
    Anti chatter...I take it that minimizes or prevents the shudder that happens when releasing the clutch from a start that if it happens shakes the **** out of everything? Sorry Jerry, I'm just ***uming what do they do?...o_O
  5. HomemadeHardtop57
    HomemadeHardtop57
    Stogy..Ford used them on most of their early V8 flathead cars for that reason and also as engine steady rods, preventing the engine and trans from moving forward and/or backwards and your fan eating the radiator I'm the case of mount failure. This was the main purpose for them here in my ch***is.
    The old Hurst mounts I'm using have a long slot where they drop on the biscuits and not a hole. The rods will help keep the engine steady as a secondary support to the tightened motor mount bolts.
    Believe it or not this happened years ago..Motor shifted from a loose mount and I trashed a radiator 3 hours away from home on the road. Not fun!
    Sent from my SAMSUNG-SM-G891A using The H.A.M.B. mobile app
  6. HomemadeHardtop57
    HomemadeHardtop57
    ls1yj, kidcampbell71, cactus1 and 4 others like this.
  7. madfish
    madfish
    With and without hood line. Decisions... decisions.
    HomemadeHardtop57 and Stogy like this.
  8. HomemadeHardtop57
    HomemadeHardtop57
  9. Runnin shine
    Runnin shine
    Jerry, are your plans to leave the lower panel semi-stationary when opening the hood? Or will it hinge outward from being mounted low by the frame rail?
  10. HomemadeHardtop57
    HomemadeHardtop57
    I'm thinking 3 piece with semi- stationary side panels attached to the grill shell and cowl with quick release fasteners. The top will be lift off style after the latches are undone. I want to make something where the top comes off easily if I want to work on the top end of the engine.
    Everything has been done so many times I want to try something sort of out of the box side cut wise but still looking decent and staying traditional.
    We'll see ..it might go in the trash..who knows! Ha
    Stogy, loudbang and Runnin shine like this.
  11. HomemadeHardtop57
    HomemadeHardtop57
    When pulling the stock exhaust manifold off the head, a small chunk came off with the manifold exposing a bad repair that was done a long time ago. It probably worked back the day but Wasn't good enough to for me. The area was cleaned and prepped and the piece tig welded and blended in. The hole was drilled out improperly back in the day too so a helicoil was fitted.
    ls1yj, loudbang and Stogy like this.
  12. HomemadeHardtop57
    HomemadeHardtop57
    ls1yj, wheeldog57, cactus1 and 5 others like this.
  13. Stogy
    Stogy
    Ho Ho Horsepower...had to say it...that is nostalgic art happening there...;)...that garage has built in photo editing. Got that old photo look going real good.
    brEad and loudbang like this.
  14. HomemadeHardtop57
    HomemadeHardtop57
    Threw the body back on. Sits nice but will drop when springs settle and the rest of the weight is on it. I have 550-16s up front and 700-16s in the rear. Need to fit the doors then the knife comes out
    ls1yj, brEad, Hendee and 4 others like this.
  15. HomemadeHardtop57
    HomemadeHardtop57
    She sits pretty low with the roof full height. I'm 5'9 and you can see where the roof sits right now
    ls1yj, Hendee, loudbang and 1 other person like this.
  16. Runnin shine
    Runnin shine
    Stogy likes this.
  17. HomemadeHardtop57
    HomemadeHardtop57
    I used a hole saw held in the steering mount with a piece of aluminum round stock to mark my hole. I sprayed some paint on the inside and marked my center hole. Looks like everything fits. Rod end and nut going into pitman arm is just for mock up to hold drag link on.
  18. trey32
    trey32
    That would not have gone that smooth with my junk.
    Nice
  19. HomemadeHardtop57
    HomemadeHardtop57
    Aligning the doors. They are about 80% there. Pushed it outside today
  20. Roadsir
    Roadsir
    Cool build, Ch***is came out great!
  21. HomemadeHardtop57
    HomemadeHardtop57
    ls1yj and Stogy like this.
  22. HomemadeHardtop57
    HomemadeHardtop57
    Got the top fully welded on today. Started fitting drip rails too. There was some cracking along body line under quarter windows that I also welded up
  23. brady1929
    brady1929
    Looks great. Man you move fast.
  24. HomemadeHardtop57
    HomemadeHardtop57
    4.5 inches coming out of back..4.75 out of A pillars..this a "rolling bones" style layout for the cut lines. Ken and Keith do their chops like this and I thought I'd give it a try. Cutting it this way eliminates relief cuts on the back of the roof near the crown. A seam gets moved to near the belt line and along side of the window openings on flat areas making for easier bodyworking
    Hamtown Al, ls1yj, brEad and 2 others like this.
  25. gnichols
    gnichols
    from Tampa, FL
  26. Stogy
    Stogy
    x2 on that...faster than my Like ****on.:D
  27. brady1929
    brady1929
    Are you SURE that you want to take 4.5 inches out? That's a lot. Mine is 3 and 3/4 front and 3.5 back. Not a lot of window to look out of.
  28. brEad
    brEad
    x2. You do really nice work and take fine pics. Thanks for sharing your build!
  29. HomemadeHardtop57
    HomemadeHardtop57
    4.5 out of the back and 4.75 out of the front and dropped her down. Have to lean the A pillars tomorrow and get stuff lined up but so far so good
    1483218067664.jpg 1483218073611.jpg 1483218082281.jpg 1483218089201.jpg 1483218098084.jpg
  30. Runnin shine
    Runnin shine
    Stogy likes this.
