Event Coverage Welcome to the 2017 Meltdown Drags
Discussion in 'The Hokey Ass Message Board' started by Okiedoker, Oct 6, 2016.
  1. bigslim55
    bigslim55
    With the warm 50 degree day I got some things done on the 55'... Felt good to get after it again!
    Had to pull out fuel cell to mount new 10AN fitting. Mounted short 10AN hose & new McRobb inline fuel filter & removed old fuel filter. Connected to the 10AN hose I had previously ran along frame from back to front. Really looks nice & clean...
    Got radiator hoses & Radiator mounted up on mock up motor. Also mounted up water temp & oil pressure lines, so that's cool. Just need to get tunnel ram back & mount carbs, new McRobb fuel pressure regulator & small fuel filter. Then I can figure 8AN fuel line from McRobb fuel pump to Regulator... I'm curious to see where or how high carbs & air cleaners sit! Might be looking for another hood to cut up! LOL...
    Hope everyone else is getting after there builds too! The Meltdown will be here sooner than you think!
  2. Torkwrench
    Torkwrench
    Started on the rear end in my 55. Took the center section apart and it looks really good. Basically, the only part that broke last July, were the ring gear bolts. The ring and pinion look OK, as does the P-case, posi unit, and bearings.
    Since it was a 3 series posi, with 4:88 gears, I was using a spacer. This was actually a good thing, since about 95% of the damage was to the spacer, with basically no damage to the posi unit. The spacer was really chewed up by the snapped off ring gear bolts.
    Instead of just getting a new spacer and ring gear bolts, an (almost), NOS 4 series posi unit was bought......Along with a set of bearing cap girdles, and severe duty ring gear bolts.
    4 Series Posi A.jpg 4 Series Posi B.jpg Bearing Cap Girdles.jpg Ring Gear Bolts..jpg
  3. altered59lark
    altered59lark
    from cincinnati
    Anyone want to match race this little guy if it's finished in time [​IMG]
  4. saltflats
    saltflats
    from Missouri
    Man I would love too if I had something to pair up with it.
    That is bad ***!!!
  5. rawcjw19
    rawcjw19
    I would line up with you. I may be a little slow. That is cool
  6. Deuced Up!
    Deuced Up!
    REGISTRATION IS JUST AROUND THE CORNER...I GOT MY FINGER ON THE TRIGGER!
    Sent from my SM-G930V using The H.A.M.B. mobile app
  7. Saxxon
    Saxxon
    Yes !!
    Now git'r done and sorted out
  8. loudbang
    We should start a pool to see who get the coveted number 1 because they are faster on the mouse ****on than everybody else. :cool:
  9. altered59lark
    altered59lark
    from cincinnati
  10. GlassThamesDoug
    GlassThamesDoug
    Pre Registration is ON.......................
    loudbang and Saxxon like this.
  11. GlassThamesDoug
    GlassThamesDoug
    Cool Altered....
  12. GlassThamesDoug
    GlassThamesDoug
    Going to be bullet proof now... Hang on...
    cs39ford likes this.
  13. Saxxon
    Saxxon
    The Scout and the Prefect are pre-registered
    As Doug said - Meltdown 2017 is officially - ON !!
    The Manitoba cars - so far
    • My Scout
    • My Brother Paul and his daughter Megan with the Prefect
    • Larry Arnold with his blown injected alky sbc altered
    • Gary Misko with his 41 Willy sedan street rod (3rd appearance)
    Booking hotel rooms tomorrow
  14. GlassThamesDoug
    GlassThamesDoug
    28-Dec-16 IPHONE 042.JPG The Blower should make noise tomorrow night...... be nice to get some Test and Tune in Spring well before..... Have Carbs on the first version.
    55belairx2, Saxxon, loudbang and 2 others like this.
  15. saltflats
    saltflats
    from Missouri
    Well the Email is sent now we will see if they want me back.
    I saved the reaction time for the track.
  16. Junior Stock
    Junior Stock
    I just checked their site and it says preregistration is closed?
    They didn't fill up already did they?
    GlassThamesDoug likes this.
  17. saltflats
    saltflats
    from Missouri
    I found that also but if you scroll down you will find an Email to copy and paste in your Email to send.
    loudbang and powrshftr like this.
  18. trailer-Ed
    trailer-Ed
    from JC, MO
    12:01, gotta my responding email at 12:02. Hopefully they will have me back!
  19. GlassThamesDoug
    GlassThamesDoug
    Previous Email on Required Info:
    There are some new rules on rim width, and type. RIMS have to be correct....... The First Year I had the wrong rims.....and "Yeah they were ugly".......still have them, and they are still ugly
    Rulea are for a good reason to get the Vintage Drag Look Correct. When you look at the # of spectators they have it right. Nothing is more exciting than pulling to the line with the stands full.......your heart beat goes up......hope nothing breaks.... and you don't miss a gear. :)
    preregister@meltdowndrags.com
    2017 Preregistration
    • Name
    • Address (street, city, state, zip)
    • Phone Number
    • Year/Make/Model of the car(s) you are bringing
    • Picture of the vehicle you are bringing
      The picture must be a side shot in which we can see the wheels on the car
      Car group or organization you are a part of
  20. Junior Stock
    Junior Stock
    I see they have changed it now to Green Light.
  21. ARNIE
    ARNIE
    I got confirmed @ 12.00 should be a low #!!
  22. Gammz
    Gammz
    from Lincoln Ne
    The kid and I have sent in the required information. This year we plan to NOT have the transmission in and out of the car 6 times the week of the event.
    powrshftr, saltflats and loudbang like this.
  23. Bugsy48
    Bugsy48
    Conformation E-mail @ 12:03, fingers crossed!
  24. Deuced Up!
    Deuced Up!
    Well I nearly set my email up to be sent automatically with Boomerang. Then I decided it just didn't seem right to do it that way. So I set my alarm for 11:50. Then I took my daughter to the movies, turned my sound off, forgot to turn it back on and the slept till 6 a.m. this morning. I got registered just behind Saltflats. Don't worry James I got your back.
    saltflats likes this.
  25. Skai High
    Skai High
    I also received a confirmation email at 12:00 am. Too bad an email time stamp doesn't show seconds..Or tenths of seconds.
  26. squirrel
    If you poke around on your email program, you might find an option to show the header, which does have seconds. But we all know drag races are won by thousandths of a second.
    MIME-Version: 1.0
    Received: by 10.28.230.93 with HTTP; Sun, 1 Jan 2017 22:00:03 -0800 (PST)
    Date: Sun, 1 Jan 2017 23:00:03 -0700
  27. saltflats
    saltflats
    from Missouri
    And that most of the time happens at the start.
    Deuced Up! and squirrel like this.
  28. Mikeszcz
    Mikeszcz
    from Winona, Mn
    I deliberately hesitated a few seconds...figured if I got number 56, I'd buy a lottery ticket.
    Deuced Up! and saltflats like this.
  29. Okiedoker
    Okiedoker
    from Wisconsin
    Quick update for you guys...
    about 60 people had their e-mails come in between 11:59 PM (RED LIGHT!) and 12:01 AM....
    We have received over 300 different entries as of noon today...
    The cool part is that many of the cars are new and have not attended in the past.
    Now I have some work to do going through everything and replying to everyone....
  30. Torkwrench
    Torkwrench
    Well, as bulletproof as a 55 - 64 Chevy rear axel can be. LOL. The posi unit came from Ohio, and the bearing cap girdles are from Alberta Canada.
    Also planning on freshening up the 301. It hasn't been apart since 1998, and could use some going through.....Especially, the cam and valve train. The cam and lifters are still the same 375 / 327 Corvette cam that was installed in about 1971. Have a new Crane "Blueprint Series" to replace it with.
    Also, have a NOS Isky 550 Magnum cam and lifters from the 1960's? Don't have any specs for the Isky, though. When I bought the Isky, I thought that it was a 550 Super Le Gerra.....At least that is what the cam card is for.
