Projects Better late than never , 29 AV8 roadster build
Discussion in 'Traditional Hot Rods' started by Cody49Ford, Dec 27, 2016.
  1. Cody49Ford
    Cody49Ford
    Better late than never, i know a lot of people asked me to post photos of the build of the 29 Av8 Roadster once it got up in going, the truth of that matter is once i (finally) got started on it, i didn't think about anything but finishing it, so heres what kept me busy last month.. since completion last month , Ive been driving the car daily now ( good ole san diego weather permits that even in winter ! ) Thanks to Titus , a lot of the hard work was done, but being my first build I still got to learn a lot ( also with the help of Jay dean at nostalgia ranch ) , yet wasn't too overwhelmed with the work that had to be done to get it finished . Before it made its journey to california from titus' place in MN , he had done the driveshaft , put the F1 crossmember in it , new sub rails , and more that I'm sure I'm missing, but you get the point! Heres a few photos of the car when i first got it, before the tear down and assembly
    It had a great start to it , which kept me motivated even though it was still a lot of work in my eyes it was at least close enough that i could see the end results , and i was very eager to enjoy these results! Next step was taking it to a good friend , and hell of a hard worker to give me the hand i needed and the advice and " point in the right direction " to keep the forward progress going! up to nostalgia ranch it went where immediate tear down and rebuild began...
    We pulled all the front end apart , rebuilt all the suspension front and rear , cleaned everything up , got all the juice brakes cleaned and true and painted up , king pins , f1 shock mounts etc etc , separated the front end , rear end , body , motor and trans , and frame into its own areas to focus on each individually . Of course theres lots of little odds and ends that had to happen but i won't bore you with touching on every little detail.. again ...you get the point!
    Once everything was apart it was time for major rebuild , clean and paint!
    Fast forward a bit , and its time to drop the motor and trans back in after lots of cleaning , pulling the trans apart and replacing clutch , got the OG tattecrsfield intake mounted on the 34 flathead and she's looking purdy IMG_4006.JPG
    We had all the brake parts on hand to rebuild the brakes front and rear , get the big and littles on it and let it touch down back on ground for its first roll.
    Once we had the chassis the way we wanted , bled the brakes , and continued to dial things in , it was time for the body to go back and and to continue moving forward... As you will see the body still needs it attention but for the time being I was really excited to get to enjoy this little rod , the body work and finish will come with time, i assure you of that!
    Once the body was on and all bolts and mounting wood were set in and made sure it all was a good fit , it was on to the floors, measure twice cut once, stain , install .. it felt great not to see the ground under my feet when sitting in it for the first time!
    After doing the floor , mounting my Tanks inc. Tank which worked out awesome and is a 16 gallon tank , we moved onto some wiring , lights , radiator and shell, and some more cosmetics ! IMG_4081.JPG IMG_4077.JPG
    Now time to drop the actually radiator in knowing that everything will mount up and be clear of one another.. get some fluids in it , plumb and wire the rest of the motor and see if shell run!
    By this point the camera stayed in my pocket more often because it was so close i could taste my first drive in the darn thing! Change all the fluids , and fire it up! She fired right up , took it to get the exhaust done, mounted the seat , wired all the gauges up to make sure i could keep and eye on it , and the rest has been to the streets! I love driving this car , and am so thankful I had a good group of people to help and offer advise when it was needed! Thanks hamb for taking the time to see my dream become a reality!!
  2. Spooky
    Spooky
    Gawdamn that is a beaut!
  3. Cody49Ford
    Cody49Ford
  4. waxhead
    waxhead
    from West Oz
    Very nice. Feel free to post some interior pics now that she is up and running.
    Cody49Ford likes this.
  5. Nice car, I like the front wishbone mounts, have you seen that done before? that may be a better way of splitting the bones.
  6. Better late / than ever [emoji106]. Very nice car , looks like it drove right out of the "50" well done , I like your no nonsense build & thread Good job
  7. brady1929
    brady1929
    Damn that's nice
  8. qzjrd5
    qzjrd5
    from Troy, MI
    Great build. Thanks for the summary.
  9. spurgeonforge
    spurgeonforge
    That's sweeeeeet!!!
  10. Cody49Ford
    Cody49Ford
  11. Fine looking little roadster,thanks for the pics.
  12. pumpman
    pumpman
    Nicely done, nice to see an A with a correct A radiator shell on it. Looks great!
    brEad and Cody49Ford like this.
  13. Binger
    Binger
    from wyoming
    I am liking this build too! Subscribed!
  14. Cody49Ford
    Cody49Ford
    Thanks @pumpman , I thought about putting the 32 shell on it that i have , but once i had this one it just looks the right part for what I'm after at the time! Thanks @Binger appreciate it! Ill try to add photos from time to time.. The interior might be a ways away.. its got the good ole "caravan rear seat, mexican blanket " combo working for it currently haha @waxhead
    brEad likes this.
  15. Raiman1959
    Raiman1959
    Man, that is a wonderful project....totally & 100% groovin' on the way this is going....There is something really special about a project car that looks as nice as your car in all the different stages of a build...very nice car, man! ...it's gonna be a sweet ride and a nice inspiration to the rest of us!;)
  16. I like it!!!
  17. Flathead Dave
    Flathead Dave
    from So. Cal.
    Very nicely done. What made you go with a wooden floor?
  18. Excellent thread, cool car, good times ahead!
  19. Cody49Ford
    Cody49Ford
    Thanks @Raiman1959 I really appreciate the words! Its been a blast and keeps getting better !
  20. wheeldog57
    wheeldog57
    Well done sir, looks great!
  21. Stogy
    Stogy
    Congratulations Hamber Cody Lots of inspiration in that workshop. Your capturing the vintage feeling nicely. Enjoy your pride and joy. Thank you for the detailed journey.
  22. e z i
    e z i
    Now that's a bitchin ride Cody..
  23. Cody49Ford
    Cody49Ford
    Thank you very much ! The question now is do I get an A coupe to build and compliment the roadster !?
    kiwijeff likes this.
  24. tinkirk
    tinkirk
  25. tinkirk
    tinkirk
    Cody
    Now that you have been driving it a while how do you like the wood floor?
    I am also working on a 29 roadster and was looking at putting a flat floor in and, after seeing your pics, if you don't mind I'm thinking of copying what you did (if you don't mind)
    Tinkirk
  26. RODIST
    RODIST
  27. e z i
    e z i
    I know this guy that's got a real nice 31 coupe, but, Naw, you don't want one of those..:p
  28. Cody49Ford
    Cody49Ford
    @tinkirk it's been my daily driver and to be honest I love it . If I had to build the car over again , I would use wood once again. And yeah of course , I don't mind one bit !
    e z i likes this.
  29. lodaddyo
    lodaddyo
    Looks great man! Nice job
