Projects 1964 Falcon B/FX Build Thread
Discussion in 'The Hokey Ass Message Board' started by fiveoh108, Nov 29, 2011.
  1. seb fontana
    seb fontana
    from ct
    Fiveoh108 just teasing you with real experiences..:D..
    fiveoh108 likes this.
  2. loudbang
    LOL I became quite the expert at changing FE plugs as I started with a 390 64 Galaxie easy peasy, then a 67 Comet 390 not too bad, then a 67 Mustang and oh ****, and the worst of all a 69 torino Super Cobrajet.
    AND I used to change them every Friday on get ready for Sunday Drags day THE MOST IMPORTANT ADVICE START DOING IT WITH A STONE COLD ENGINE. If the engine is hot or even warm double or triple the amount of time to allow for blowing on fingers and thinking up new cuss words on the spot. But by the time you get the first side done the other side is cold already LOL :rolleyes:
  3. fiveoh108
    fiveoh108
  4. porkshop
    porkshop
    from Clovis Ca
    Cool Deal......
  5. loudbang
    Now your talking FE power.
    1947knuck likes this.
  6. seb fontana
    seb fontana
    from ct
    Brings back memories....
  7. fiveoh108
    fiveoh108
    Did the thunderbolt 427s have chrome pentroof or rounded baldy valve covers?
  8. Rounded baldy. The pentroof showed up in '65.
  9. fiveoh108
    fiveoh108
    Thank you!
  10. fiveoh108
    fiveoh108
    Found several cracks in the "freshly rebuilt" High Riser Heads. I guess these things were beat on like most race parts of the era. I don't blame the seller, he was just going by what the shop who did the work told him... waiting to see if they can be repaired[​IMG]
    [​IMG][​IMG][​IMG]
  11. seb fontana
    seb fontana
    from ct
    **** that ****s! Hope they can be saved..
  12. EXracer64
    EXracer64
    from nj
    Good for you that your keeping it old school. I know way too many people who just chop it all out. I would never buy a car that was chopped and had aftermarket suspension, but thats just me.
    That FE setup is a HUGE score!
  13. saltflats
    saltflats
    from Missouri
    Is this going to be a drag race only engine?
    May not be a big problem.
  14. loudbang
    Man that ****s big time.
  15. fiveoh108
    fiveoh108
    Yes drag race only, I think it can be welded.
    DFWSteveFoster and loudbang like this.
  16. fiveoh108
    fiveoh108
    Heads are repairable, block is good, now working on cam specs!
    Gammz, powrshftr and Johnboy34 like this.
  17. loudbang
    Well that is welcome news. Roy must be working in your corner from above. :)
    1947knuck, powrshftr and fiveoh108 like this.
  18. fiveoh108
    fiveoh108
    Made some progress today[​IMG]
    [​IMG][​IMG]
    Now I have a rear engine falcon LOL
    loudbang, saltflats and Gammz like this.
  19. fiveoh108
    fiveoh108
    Gammz, porkshop and loudbang like this.
  20. loudbang
    Tell Dale we miss his posts on the HAMB hint hint :rolleyes:
  21. fiveoh108
    fiveoh108
    Opening up the rear wheel wells for some more tire, Dale also added a metal plate as a jacking point for lifting the car .[​IMG][​IMG][​IMG][​IMG][​IMG]
    saltflats, loudbang and Gammz like this.
  22. Gammz
    Gammz
    from Lincoln Ne
    Did your move your leaf springs inside the frame rails?
  23. fiveoh108
    fiveoh108
  24. powrshftr
    powrshftr
    Holy cow those tires look tough all tucked in there.
    It's gonna look as mean as the Brannan car![emoji15]
    .....Maybe even a little meaner..[emoji41]
    Can't wait to see some more of it!:)
    Scott
  25. powrshftr
    powrshftr
    I keep forgetting to ask:
    Are you going injected with the 427 as well?
    That is going to be one nasty FE ****er punch stuffed into a compact Falcon package,no matter what you run for induction.
    Can't wait to see it run!
    Scott
  26. fiveoh108
    fiveoh108
    A factory dual quad high riser manifold will be the induction. I'm trying to get it to fit under the dual snorkel hood, we will see once it's all in there, if it will fit! I have the dual snorkel hood, lift-off injection hood and would really prefer not to have a third!
    loudbang, powrshftr and Gammz like this.
  27. fiveoh108
    fiveoh108
  28. powrshftr
    powrshftr
    That is a big old ***y slab of aluminum right there...[emoji16]
  29. powrshftr
    powrshftr
    Gene Cromer who's a die-hard Ford man since forever,has stated that he sometimes ran quicker times with a Hi-Riser than a Cammer,depending on track conditions,car setup etc,because the wedge motor made so much more torque,so much sooner in the power band,that it would just grunt a light little car (sort of like yours) right out of the hole,and pull like a freight train all the way through the lights,where the Cammer wanted a bunch more rpm to really work its magic.
    I think you're gonna have a pretty serious weapon on your hands,Brother.[emoji16]
    Scott
  30. fiveoh108
    fiveoh108
    Made a lot more headway today, got the shock towers cut back, interior gutted and some of the lettering removed. It's slow with 1200 grit and water! [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    loudbang, Gammz and powrshftr like this.
