Projects A Speedster Comes Out of the Weeds—Build Thread
Discussion in 'The Hokey Ass Message Board' started by ClarkH, Dec 25, 2015.
  1. JOYFLEA
    JOYFLEA
  2. ClarkH
    ClarkH
    Good to know this horn's pedigree, and that it's of the era. And yes, "sick cow" is a fair description.
    I've seen those Python horns in museums. They are the cat's pajamas, to use terminology of their day. Here's the closest ever I've come across at a sale:
    It's a basic br***-era horn, but my wife deemed it worthy of a place on our mantle. Sometimes when I'm working upstairs she honks it to let me know dinner's ready. It's surprisingly loud.
    Those fenders are nice--and apparently available. More food for thought. Thank you!
  3. BuiltFerComfort
    BuiltFerComfort
  4. Stogy
    Stogy
  5. JOYFLEA
    JOYFLEA
    Those springer fenders are the front fender .
    Hotdoggin DaddyO, ClarkH and Stogy like this.
  6. 55willys
    55willys
    When I shortened and narrowed a model T box for my dads servicar I ended up using sidecar fenders on it. One side skirt is deeper than the other so I trimmed the long one on each fender and rehemed the edge so they matched from side to side.
  7. 28dreyer
    28dreyer
    from Minnesota
    Here's another Mercury body.
    Look closely at the engine and read the placard
  8. Hitchhiker
    Hitchhiker
    I have tons of horns dude.
    Sent from my SM-G900T using The H.A.M.B. mobile app
    ClarkH likes this.
  9. ClarkH
    ClarkH
  10. ClarkH
    ClarkH
    I’ve been immersed in wiring for a couple months now. As with everything else, wiring was something I had to research and figure out as I went. It’s been a series of decisions and small tasks that didn’t seem to warrant individual posts. But now that I can see the “light” at the end of the tunnel, I thought folks would appreciate a collective update.
    This is a 6-volt system with the battery in the rear, so I started with some big-*** 00 battery cables.
    Next up, installation of the usual firewall suspects. Usual-firewall-suspects.JPG
    Replaced the rotten taillight sockets with NOS Cole-Hersee units; made the brackets out of s**** stainless (an old kitchen ****e rack).
    Gritted my teeth and drilled a hole on each side of the freshly painted radiator shell for where the headlight wires exit the shell and enter the stainless conduit. Didn’t have a big enough drill bit, so finished with a die grinder. Fortunately, grommets cover all sins.
    Then it came time to make the wiring harnesses. Again, it’s six volt, so I used 10 and 12 gauge wire fished through asphalt coated loom (I was amazed they still stock that stuff at NAPA). Man, it took a lot of trial fitting to determine where the wires should exit the harnesses. Thankfully I have fish tape from when I rewired my first house (which, by the way, didn’t seem to take as long as this car has). The front harness is high and low beam only. The rear harness is tail, brake, fuel pump and horn.
    I’ve got everything roughed in now, as you can see from the extra wire hanging everywhere. After reading a number of HAMB troubleshooting threads, I kind of went crazy on grounds—there’s two straps body to frame, and two straps frame to engine. I ran a separate 10-gauge ground to each light and component. Man, I probably added 25 unnecessary pounds to the sprung weight of the car!
    At this point I still need to install the switches and get the under dash routed. Then I should be ready for my Big Day of Crimping.
  11. timwhit
    timwhit
    Your getting there! Bet your anxious to go for a ride heh?
    loudbang and ClarkH like this.
  12. ROADSTER1927
    ROADSTER1927
    Clark, everything you are doing looks Great! As far as wiring I hope you mean you are going to Solder and shrink tube the conections, Gary
    volvobrynk, loudbang and ClarkH like this.
  13. The37Kid
    The37Kid
    Congratulations on the wiring start, I give up and sell my projects when that is the next step. Get an onboard fire extinguisher placed in the car before you light it. Bob
    kidcampbell71, loudbang and ClarkH like this.
  14. 55willys
    55willys
    I have wired many cars, you could have asked me. Looks like you are doing well at it.
  15. ClarkH
    ClarkH
    You better believe it. I figure it should be on the road mid-to-late spring. Once I'm finished it's seat, doors, done...until I find a windshield...
    Some will get soldersed some will get crimped, some will get both; depends on the application and stresses. All will get shrink wrapped. To be honest, I'm going to call in a favor and have my brother do that part--professional mechanic, he's been doing it for years. Trust me, I understand where you're coming from: When my brother came by to check out progress, he laughed at my old ****py crimpers and connectors with plastic covers and threw them all in the trash. Now I have heavy duty connectors and his set of backup crimpers...he thinks he's getting them back...ha! crimpers.JPG
    One step ahead of you, Bob. I've been trying to figure where in the ****pit to keep a fire extinguisher. And there's a heavy-duty cutoff for the battery, in case the worst happens. I'm not letting all this work go up in smoke. Even though this thing is 6 volt, I added a fuse block. And in one of my rare modern concessions, everything feeds through this: fuse.JPG
    It's hidden well.
  16. ROADSTER1927
    ROADSTER1927
    Nothing stopping you! Fuses are good! Gary:)
  17. rob-redm
    rob-redm
    looking good !
  18. Totally OT--- but in the 3rd picture on the shelf looks A Lot like a bottle of my wine. White label with gold foil top, and I see you're in WA. Just curious..
    I haven't read the entire thread but very cool car. Congrats.
    Greg
  19. The37Kid
    The37Kid
    That looks like a nice item. I could take this thread sideways with a question but I wont. Bob
  20. ClarkH
    ClarkH
    Could be. What's your label? Wine making was kind of a thing in my family; Dad was periferally connected with the ***ociated Vintners group--they were old school Washington winemakers. We wound up with a lot of their castoff equipment.
    Mum's the word, Bob. Let's agree that post didn't happen. :rolleyes:
  21. Last edited: Mar 5, 2017
  22. Last edited: Mar 5, 2017
    ClarkH likes this.
  23. ClarkH
    ClarkH
    Hey, Late to the Party, thanks for providing that link to the Mercury Sportster at the Detroit Autorama. (Also a shout-out to timwhit, who sent me an alert when it was first posted.)
    That reminds me, I also have an update on my quest for the perfect horn. As seen in my January post, the cool old EA motorcycle horn I wanted to use turned out to be a dud, so I went with a big long trumpet style horn—the one Late to the Party very-accurately described as sounding like “a sick cow.” It wasn’t near a cool as the EA, but did the job.
    Flash forward a bit, and there I am having a beer in the garage watching a not-very-good football playoff game. It occurs to me I might as well pull the EA horn apart to see if it could be saved. As I suspected, not a hope—guts all crusty and rusted solid. But as I’m sitting there savoring my “thinking juice,” it dawns on me that these two horns were ***embled with near-identical bolt patterns. It was one of those "well-I'll-be-danged" moments. I popped them apart, reamed out the holes a little at the back, switched faces, and problem solved.
    The end result looks cool mounted to the frame horn. Still sounds like a sick cow, but a it’s a really bad-*** sick cow.
  24. That looks much kooler than the long-nose version. :cool:
  25. loudbang
    Really like these covered cable ends they help prevent unwanted sparks and smoke leaking out LOL :rolleyes:
  26. The37Kid
    The37Kid
    How are the fenders doing, can't look at wires too long makes me crazy. Bob
    tb33anda3rd, volvobrynk and ClarkH like this.
  27. mlake01
    mlake01
    12 years after he p***ed away, I'm now cleaning out my Dad's shop as Mom has moved off the home place and into town. This picture was hanging on the wall in the shop - no notes or anything, just a boattail speedster...
    Sorry about the rotation, it's the best I could do with my phone.
  28. The37Kid
    The37Kid
    7b66ff021bef8b8d6af36a6b54f8ab8d.jpg I don't own a cell phone, too old to figure out if I know anyone to call. Bob
    kidcampbell71, Stogy, ClarkH and 2 others like this.
  29. That is a WAY cool picture. We don't often see pics of those cars intermingled with other typical cars of the day. Remember, those Speedsters were built in the 1920's, and those are other 1920's (or maybe late 'teens) cars in the pic. This clearly shows how very different from the norm the Speedsters were. Great pic!
  30. ClarkH
    ClarkH
    Well, just letting everyone know I’m not dead or in a mental ins***ution—and I can now attest that wiring could drive you to the latter. Haven’t had much to report for two months beyond crimp, solder, wrap. The process isn’t especially photogenic, so no posts. Also, I was kind of worried Bob’s head might explode; the 37Kid clearly has a phobia when it comes to wiring. My final wiring report:
    Wiring is like wrestling an octopus. Here’s a mid-process shot of the tentacles, not yet restrained. Damn!
    Here’s the umpteenth time the dash had to come out; it was like a two-hour operation each time. Maddening.
    The dash is finally in for the last time with everything hooked up except speedo. I’m very happy with the look of it. The configuration has changed a little from my initial mockup. Had no room for a high-beam floor switch, so went with Bishop/Tardel method of putting both on a push-pull. This necessitated moving the light switch to a more accessible central location, and filling the original hole with a big high-beam indicator jewel sourced off ebay.
    With wiring done I moved on to something FUN: Seats! New post coming soon.
