Projects My Av8 Roadster Build
Discussion in 'Traditional Hot Rods' started by lodaddyo, Sep 17, 2016.
  1. louisb
    louisb
  2. lodaddyo
    lodaddyo
    Been working on setting the steering up. Im running an f-1 box and model a sector housing bolted in the stock location. Im using a set of 33-36 exhaust manifolds. I got about 3/4" clearance betweeen the box and manifold without having to move the box. Chucked up the cut down model a sector in the lathe and made a cut for the f-1 seal
    Also found a piece of oak dowel rod and cut it to fit the model a side and the cut down f1 box to act as an alignment tool to tack it and weld it. Once its welded ill knock out the wood and push in the new bushings and hone them to size
    Bolted the box in and used a piece of tubing to figure out where i wanted the steering wheel. Next i gotta figure out some sort of column drop
  3. Loving this.
    brEad and lodaddyo like this.
  4. 1-SHOT
    1-SHOT
    from Denton
    I like this too and have been following.
    lodaddyo likes this.
  5. lodaddyo
    lodaddyo
    Thanks guys, progress has slowed up lately. Gave most of my money to than damn mouse in florida. And the holidays got me all messed up. Will get back on it soon!
  6. 1-SHOT
    1-SHOT
    from Denton
    Who is the mouse in Florida?
    Jeff Pandora and Stogy like this.
  7. jhexide
    jhexide
    Mickey Mouse.....!!!!
    Stogy and lodaddyo like this.
  8. 1-SHOT
    1-SHOT
    from Denton
    Been there done that. It's fun to watch the kids enjoy themselves.
  9. Matlack
    Matlack
    great build. it's giving me inspiration.
  10. Rickybop
    Rickybop
    I love traditional roadsters.
    Glad I stopped by tonight and had the pleasure and privilege of seeing your build, LDO.
  11. 1935ply
    1935ply
    from peyton,co
    Great looking build. I like how this is coming together. What are you using for a seat?
  12. lodaddyo
    lodaddyo
    Bengels seat frame for a model a roadster. Theyy advertise here on the hamb. Great guys to deal with, seat fits perfect
  13. lodaddyo
    lodaddyo
    Little update, started working on getting my banjo together. Got the pinion assembly in the housing, set the pinion pre-load and got it locked down. Takes about 15in lbs to move it. Next up is to put it all back together and set the back lash.
    Also been working on a buddys 49 f-1. Swapped out the front axle for a nostalgia sids 3" drop axle. Installed some posies drop leaf springs. Gave it a nice stance
    Pulled the flathead out to freshen it up a bit. Its a good running motor. The plans are new navarro heads and intake. Dual 97's, fresh coat of paint , a t5 swap, and a whole bunch of other polished goodies
  14. lodaddyo
    lodaddyo
    Got the banjo together and ready to go back under the car, anxious to see how it sits with the new reversed eye rear main spring
    True 7 leaf roadster spring with reversed eye main spring from A-springs and dummy plate
  15. 383deuce
    383deuce
    Man you are moving right along on this build....Thanks for posting all the great photos..
  16. louisb
    louisb
    Good job on the banjo. I just got my new 7-leaf spring as well.
    --louis
  17. lodaddyo
    lodaddyo
    Thanks! Its not moving as fast as id like, but thats life sometimes. It will get done!
    Thanks man, they arent as difficult as i thought.
    1947knuck and Stogy like this.
  18. lodaddyo
    lodaddyo
    Got to the point where i needed to get the body off to do some things on the frame. Cobbled together a cart out of wood to roll it around.,
    My neighbor helped me get the body off, hopefully it will be the last time it comes off.
    Got the rear end hung back under and back on all fours. Next step is to do some finish welding on the f1 crossmember, motor mounts, and some other things. Gonna work on shortening my torque tube and driveshaft
  19. lodaddyo
    lodaddyo
    Been working a shutdown at work, everyday, 12 hours a day for the last 15 days. Finally got a day off. Mangaged to get a couple things done. I go back to work tomorrow for another 15 days.
    Cut out and moved the pedal mount inboard on the f1 crossmember. Got the clutch linkage hooked up.
    Also whipped up a parking brake mount that bolts to the trans.
    Next up is shortening the torque tube and driveshaft.if i remember Ill try to get alot of pics when i do it. Back to work
  20. GordonC
    GordonC
    Lodaddyo, just fyi, I think the handle is normally mounted with the lip/overhang to the front although you can do it anyway that makes you happy!:)
    oliver westlund, Stogy and lodaddyo like this.
  21. lodaddyo
    lodaddyo
    Yeah i was wondering if anybody would notice i bolted it on backwards. I realized it after i took the pic. Its now orientated the correct way.
    Thanks!
  22. Dapetruz
    Dapetruz
    Awesome build!!
  23. lodaddyo
    lodaddyo
    Thanks!
  24. fastmike
    fastmike
    from Mesa AZ
    Looking great!
  25. lodaddyo
    lodaddyo
    Thanks!
    wish i could get some time off to work on it. 20 days in a row at work Is killing me. I had moose over on the photoshop thread fix me up.
    Any thoughts?
    The car is actually a little lower since this pic was taken, i put in a super low reversed eye front spring and a reverse eye rear main spring in the rear
  26. waxhead
    waxhead
    from West Oz
    Looks good to me.
  27. Never2low
    Never2low
    Definitely digging it! Is it an OE flat gray?
    Stogy likes this.
  28. lodaddyo
    lodaddyo
    1963 VW anthracite gray
    1947knuck, Stogy and brEad like this.
  29. Never2low
    Never2low
    VW had some great early colors. Met a guy with and A coupe in a late 50's VW medium blue.
    Stogy likes this.
  30. YJ4000
    YJ4000
    Looks great!
    Ryan.
