Hot Rods The Rouster Indy Roadster
Discussion in 'The Hokey Ass Message Board' started by cornfieldcustoms, Dec 27, 2016.
  1. Speedwrench
    Speedwrench
    There's always Toledo although my preference would have been New Bremen.
    s55mercury66 likes this.
  2. cornfieldcustoms
    cornfieldcustoms
    been finishing up some smaller things on the car, radiator hard lines upper coolant manifold, dash, radiator mounts ect. here are some pics of that progress. the car will be on display at my booth at the Cincinnati Cavalcade of customs this weekend.
    the top 2 pics is of where we were 38 days ago from today, and the bottom pic is as of today. i still cant get over the amount of progress me and Ryan ( my employee) have made on this car in that time as well as keep the shop running as smoothly as we can on other cars and projects.
  3. JOYFLEA
    JOYFLEA
    Beautiful work . Love the torsion bar suspension . Blue
  4. spurgeonforge
    spurgeonforge
    Just plain Bad ***! Mike you guys amaze me the talent you have. Are you planning metal cl***es anytime in the near future? Thanks for sharing. Bill
    JOYFLEA likes this.
  5. 48 Ragtop
    48 Ragtop
  6. gnichols
    gnichols
    from Tampa, FL
    Looking good. One thing I've never figured out... why have a shiny dash, and / or, one mounted at an angle that will only help reflect sunlight back into the driver's eyes? Hopefully, the body / cowl flare will help cover it up, eh? Gary
  7. Speedwrench
    Speedwrench
    Will you also be fabricating the body?
    You do extremely impressive work.
  8. loudbang
    Man that is some "Good stuff" really like your work.
  9. cornfieldcustoms
    cornfieldcustoms
    yes i will be making the aluminum body as well
    JOYFLEA likes this.
  10. cornfieldcustoms
    cornfieldcustoms
    it has been a while since i updated this thread. we have had all kinds of things going on with this car and others in the shop so i have just been busy.
    the shocks on the front were going to be an issue with the front end area being as busy and close as it was. so i moved the shocks in board and designed bell cranks to run them as a cantilever to tuck them into some open space. everything cycles as it should, no binding, rubbing or hitting. and keeping the lever arms 1:1 the shock dampening rate stays the same
    with the drive shaft we also had to get creative. i wanted to keep the open trans look of an original indy roadster. since we are running a T5 and winters rear end i had to come up with something to cover the drive shaft. i decided to mimic a torque tube. it is a 2 piece cover that has a front and rear pivot point. the pivot points are in the center line of the universal in the drive shaft. this allows the cover to travel on the same plane as the drive shaft. we can cycle the suspension fully with no rubbing issues so it should work out well
    got the steering box mounted, pitman arm machined and the drag link made. the steering box is an F100 box converted to side steer by Jokerr
    made a pedal box ***embly, the owner of the car wanted all wilwood parts on the brakes and clutch. we mounted everything on the engine bay side of the fire to mimic a real watson car, and help with leg room. the pedal extions and pads are also meant to mimic watson
    then was onto fuel lines, brake lines, oil lines, shifter and other smaller pieces in the **** pit area
    designed a fuel tank. had to make a wood buck to shape the pieces to
    started roughing out the aluminum
    got the final rendering in from the Root Bros.
    then sent the body station files to water jet, and got all the buck profile stations cut out. ***embly going on well with the buck. the buck looks super long, but over all it is only 17 inches longer tip to tail over a stock 1963 watson car, that is from us stretching the wheel base 10" for comfort as a street car, and the other 7" is to keep the proportions where we widened it to fit 2 seats.
    chriseakin, Woogeroo, zzford and 18 others like this.
  11. loudbang
    Masterpiece as usual.
  12. Pete
    Pete
    Oh my **** stains!!!! Wow, I can't wait to see the body take shape
    cactus1 and loudbang like this.
  13. Amazing!
  14. GASSERBOB
    GASSERBOB
    from USA
    BEAUTIFULL WORK, MY WORD. Bob.............................
  15. The 39 guy
    The 39 guy
    Amazing work as always! I appreciate your time and effort in sharing your projects with us on the HAMB!
  16. The 39 guy
    The 39 guy
    Are there any bearings used on that drive shaft cover gizmo?
  17. cornfieldcustoms
    cornfieldcustoms
    there are oiled bronze bushings and grease fitting on both pivot points
  18. The 39 guy
    The 39 guy
    Thanks! Pretty ingenious idea:)
  19. Hotdoggin DaddyO
    Hotdoggin DaddyO
    from Hays, Ks
    Your skills makes a Man jealous.
  20. BCCHOPIT
    BCCHOPIT
  21. cornfieldcustoms
    cornfieldcustoms
    thanks guys
  22. rd martin
    rd martin
    from indiana
    really great work!!! cant wait to see the finished product!!!! outstanding!
  23. jimmy six
    jimmy six
    With all that engine room it needs a Novi....
  24. cornfieldcustoms
    cornfieldcustoms
    started getting some of the body panels roughed out
    at this stage all the panels need refining and finishing, but they are getting there
    Stogy, cactus1, mgtstumpy and 4 others like this.
  25. gnichols
    gnichols
    from Tampa, FL
    Gawd I love this build... Just wonderful work. Gary
  26. brEad
    brEad
    It's always nice to see one of your threads appear in my watched list. Beautiful work - thanks for sharing it.
  27. rd martin
    rd martin
    from indiana
    apparently the customer wants a flatty!
  28. woodbutcher
    woodbutcher
    :D Now that`s some sweet looking craftsmanship.Would love to hear that sweety at full song.What`s wrong with a flatty?Has just as much cool as a hemi.Hemi?Now THERE`S a thought.:rolleyes::D:eek:
    Good luck.Have fun.Be safe.
    Leo
  29. cornfieldcustoms
    cornfieldcustoms
    a little more progress for the past few days
    got the external oil tank shaped, and all welded up
    more fine tuning on the tail section pieces, working to get the light lines all squared away and wavy spots worked out
    got another low crown panel roughed in, this one is the hood area of the car
  30. Offset
    Offset
    from Canada
    Talent? I think so.
    Very nice workmanship.
