Technical 1928 coupe license plate and tail light ideas
Discussion in 'Traditional Hot Rods' started by flyn schlosser, Jan 3, 2017.
  1. flyn schlosser
    flyn schlosser
    from Elko,NV
    Looking for ideas for my 28 coupe .As of now the license plate hangs under the body and it has a single model a tail light mounted in the middle .I would like to use the stock spare tire bolts to mount the plate does any one make a plate mount using these bolt holes .Any pictures suggestions is appreciated
  2. Model A Gomez
    Model A Gomez
    Made a real simple bracket for my coupe. Took two bolts that fit the mounting holes, drilled and tapped them for a 10-32 screw. Then used counter sunk screws in a 3/16 strap the right width to mount the tag with nuts welded to the back of the strap.
      170.2 KB
      168.3 KB
  3. flyn schlosser
    flyn schlosser
    from Elko,NV
    Thats a great idea .Thank you
  4. flyn schlosser
    flyn schlosser
    from Elko,NV
    Any tail light ideas ..Pictures would be awesome ..Thank you
  5. upspirate
    upspirate
    Maybe some pics of the car so we can see what to work with?
    lothiandon1940 likes this.
  6. lothiandon1940
    lothiandon1940
    .......You'll never go wrong with '39 teardrops.:D 038-vi (1) (1).jpg 20151126_0923432_zpsuspeggab.jpg
  7. Canuck
    Canuck
    Tail lights are 47 Chevy. Tag light is 53 Lucas. Plate mounts are 4 raised bosses pressed into the panel to lift the plate off the panel. Not show is a steel plate backer for the plate to prevent it getting bend and a thin chrome surround trim.
    Ends up looking like this
    Good luck
    Canuck
  8. scrap metal 48
    scrap metal 48
  9. flyn schlosser
    flyn schlosser
    from Elko,NV
    Thank you .. some great ideas
  10. flyn schlosser
    flyn schlosser
    from Elko,NV
    s**** metal 48 any pics of your gas tank and filler tube im thinking of relocating mine in the similar are ..
  11. bangerbob
    bangerbob
    By license plate lite
  12. flyn schlosser
    flyn schlosser
    from Elko,NV
  13. Binger
    Binger
    from wyoming
    Some one beat me to the '54 buick lights. I also used an vintage plate light i found at a swap meet.The wire for the plate light goes through the big spare tire hole and the plate covers the lower holes.
    Jet96 and lothiandon1940 like this.
  14. mike bowling
    mike bowling
    '50 Pontiac and an old flea market plate light
    Piedmont likes this.
  15. mike bowling
    mike bowling
    Sedan, but it could work on a coupe too. '39 teardrops and a recessed plate ( light in the top recess)
  16. james lakes
    james lakes
  17. james lakes
    james lakes
  18. Hombre
    Hombre
    I must say I pretty much like all of the taillight ideas on here. Don't forget the stock Model A lights as well, while these in Mix 028 (Small).jpg this picture of my old Model A are surface applied they look good as well molded into the sheet metal.
    flyn schlosser likes this.
  19. scrap metal 48
    scrap metal 48
  20. sloppy jalopies
    sloppy jalopies
    Still a month away, but a pair of '50 pontiacs, '47 ford parking lights as back ups, and this coke bottle opener as plate light...
    going to weld most of a used harley davidson handle bar upside down as a front spreader bar and plate / club plaque mount... '30 A pix to come.... pic of a front plate mount i did years ago...
  21. mike bowling
    mike bowling
    Stock "drum" tail light with plate light in the bottom. Added a couple of Harley "bullets" for outside marker/ running lights
    pecker head and Never2low like this.
  22. pecker head
    pecker head
    image.jpg . 49 Ford in 28 Special Coop.
    mike bowling and scrap metal 48 like this.
  23. Binger
    Binger
    from wyoming
    I like the early stock drum taillights better than the later teacup ones you see a lot of. A lot of prewar builds use them. Ford ran the drum taillight in 28 and the teacup ones came in late 28 or very early 29. I am not too sure exactly. Not that the history matters when building a hot rod. [emoji12]
  24. flyn schlosser
    flyn schlosser
    from Elko,NV
    This is the same set up I have now but mine tail light has a rear back up light .I need to get a picture posted
  25. Donut Dave
    Donut Dave
  26. flyn schlosser
    flyn schlosser
    from Elko,NV
    I like the clean simple license plate holder
  27. b-bob
    b-bob
  28. jazz1
    jazz1
    Not tail but front signal lights on my truck. The idea was to find a "bucket" that would work as a light housing. A larger "bucket" could work for tail lights. Found the lights at Restore for $10.
    dwollam likes this.
