Astro's repair question
Discussion in 'The Hokey Ass Message Board' started by macs55, Mar 27, 2006.
  1. macs55
    macs55
    I have a set of 14x7 reverse supremes on my car and one of them has a leak in it. I put the rim in a bucket of water and found that the leak was coming from the middle of one of the spokes. So I packed up the rim and tire and drove to Stockton wheel last week to see if they could repair it. They said it can't be fixed, but I'm skeptical. :confused: WTF!! I checked on getting a new one but they said everyone has them on backorder. :( And I need one for VIVA comeing up. So my question is does anyone have any tips or seggestions on how I could fix it, or anyone got an extra wheel layin around they want to get rid of?
  2. 50dodge4x4
    50dodge4x4
    I spent several hours one day trying to fix a "pin hole" in an alumium mag, never got the job done. You might be able to get away with a bit of two part epoxy inside the wheel, but I suspect your best option is installing a tube in the tire/wheel. Gene
  3. Brandy
    Brandy
    from Texas
    Oh oh oh! Hahahahahaha!!
    *points finger and laughs*
    HAHAHAHAHA!
    You better have that car at Viva or I'll kick ya in the baby batter!
    =P
  4. LUX BLUE
    LUX BLUE
    Alliance Vendor
    from AUSTIN,TX
    Sci flyers were doin the same thing (old radir knock offs)
    we broke the tire down, slathered on some black sisicone,presto! no more leaks!
    just be sure to have it re-balanced afterwards.:D
  5. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    Mac im a dealer for astro supremes so i will call in the morning to see if i can get ya one...
    alex
  6. 39 Ford
    39 Ford
    Scuff it up at the leaking point and JB weld it, then forget it.
  7. Flathead Youngin'
    Flathead Youngin'
    i vote for tubes......but i like them for some reason...
  8. macs55
    macs55
    If I can't get a replacement in time then I'll try the scilicone route or just tube it. I have a standard offset astro on for now but not the same without the reverse.
    Alex let me know what you find out.
  9. RadirWheelsGuy
    RadirWheelsGuy
    if it was aluminum you can have it shotpeened to stop any leaks, or use a small peen hammer, i have a buddy who worked at a chevy dealer in the 80's who had to break down corvette wheels and peen the pinholes on the insides....
  10. chaco
    chaco
    from Modesto,CA
    Arent supremes steel, If so and its on the back side and not visable spot weld it with a mig or tig Hopefully its not cracked. Itll work might not be pretty though
  11. RadirWheelsGuy
    RadirWheelsGuy
    ya the ealry ones had CAST steel centers and steel hoops, later have stamped steel centers.
  12. wheelman
    wheelman
    If you have a leak in the rim shell odds are it is cracked or cracking. I would replace it not try to repair it. Cracking was quite common with early Supremes and still is with some of the bogus cheap copies claiming to be Supremes. Be careful after it is you safety when it comes to wheels. Check starwheel.com as they sell Supremes.
  13. Solder it or braze it and forget it.
  14. chromedRAT
    chromedRAT
    so how many companies are making supremes? i have a set of the stamped steel centered astros on the impala that i got from summit racing, US wheel is the company that made em. man, that'd **** to have the hoop crack...
  15. macs55
    macs55
    I haven't had a chance to take the wheel off and inspect the rim yet. I'm thinking I might be able to repair it and keep it for a spare at least.
  16. VonMoldy
    VonMoldy
    from UTARRGH!
    how bout paintin some POR15 or summpin like dat.
  17. monsterflake
    monsterflake
    i think i would spray a nice, even coat of rubberized undercoating all around the inside of the rim. a friend used mar-gl*** on a particularly stubborn leak on 2-piece ET...
