Technical Hard topping a 1940 Plymouth coupe
Discussion in 'Traditional Customs' started by gasmonkeyrodder, Jan 2, 2017.
  1. gasmonkeyrodder
    gasmonkeyrodder
    from uk
    Hi, just wondering if anyone had hard topped a 1940 Plymouth coupe? And if so have you any pictures. I am thinking of chopping a 40 plymouth along the lines of a 39/40 mercury ie pillar less with raked rear quarter gl*** wrapped in a stainless frame, and the door/front quater windows the same. All advice appreciated. Thanks.
  2. CadMad
    CadMad
    Trickier than it sounds. Google the 1940 Mopar convertibles and compare the door differences. Best case get a pair of conv doors. You will need to also consider a pivoting or slide in and out side rear window (unless it is fixed).
    For that you may be best looking at early hardtops. Starting at 49 is about the earliest.
    Perhaps even graft an early hardtop roof rails to your roof. I would start from the A pillar and work back.
    Or. . . Maybe just find an early hardtop and graft the whole roof (with cut and shut.). Luckily it's a custom. Lots of thinking before you cut.
  3. 'Mo
    'Mo
  4. gasmonkeyrodder
    gasmonkeyrodder
    from uk
    Thats the vision i had. Thanks for the link. As CadMad has said there is a lot of work in that roof to get it to this point. I was thinking maybe just cut the raked pillars and weld in the gaps using the same profile cut off the pillar. Cut the Door upright and replace with stainless trim cut to the same arch as the new gl*** to support the top of the doors, Maybe Hardtop is not the correct term more like chopped and pillar less.
  5. plymouth1952
    plymouth1952
    that roof cut is perfection
  6. Besty34
    Besty34
    I've done one hope this helps I was saving for the art show on Friday but hey your needs are greater IMG_1483978615.498246.jpg
    kidcampbell71 likes this.
  7. gasmonkeyrodder
    gasmonkeyrodder
    from uk
    I see Chip Shop is back. HA HA.
  8. gasmonkeyrodder
    gasmonkeyrodder
    from uk
    Did you take a look at the link ?
  9. Besty34
    Besty34
