Technical A question for your upholstery experts, or wannabes
Discussion in 'The Hokey Ass Message Board' started by southerncad, Jan 10, 2017.
  1. southerncad
    southerncad
    Can the "dents" or depressions in these seats be eliminated without tearing them apart?
    ANY info will be greatly appreciated.[​IMG]
  2. Leakie
    Leakie
    Steaming them may help
  3. Worst case replace the foam padding.
  4. stanlow69
    stanlow69
    Do not use a heat gun. Sometimes it will ruin the leather. Put them in the sun if you don`t have a steamer.
  5. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I'm guessing the foam underneath has taken a set. If you don't want to replace the foam you might try to overlay a slab of foam to restore the profile.
  6. john worden
    john worden
    from iowa
    vinyl or leather?
  7. southerncad
    southerncad
    Yeah, the seat is leather....hope I can save it without too much grief!
  8. BOBCRMAN
    BOBCRMAN
    from Holly
    ***uming these marks were caused by something pressed against them. Wipe the seats down with a conditioner. Leave them in direct sunlight on a hot day. The foam/cover will return to original shape.. It might take a couple times.. Just keep surface from drying out.
    Flathead Dave and loudbang like this.
  9. wheeler.t
    wheeler.t
    Worst case scenario take the covers off nicely and steam the foam out with a clothing steamer, it will help push it back to its original shape. Then reinstall the covers, may have to steam those too. Late model seats are relatively easy and quick to **** around with.
  10. Flathead Dave
    Flathead Dave
    from So. Cal.
    Was something leaning or sitting on the seat? Set them in the hot sun when you can get the sun or place them in a warm room for a few days. But do not use direct heat on them from a heat source such as a heater, blow gun, etc...
  11. southerncad
    southerncad
    Thanks for the info guys!
