Projects We build 'em twice, to make 'em nice...
Discussion in 'Traditional Hot Rods' started by flynbrian48, Jan 10, 2017.
  1. CraigR
    CraigR
    What steering set up are you using, and have you mounted a rear panhard yet?
  2. RainierHooker
    RainierHooker
    from Tacoma, WA
    I believe that, more than anything, over inflation is the problem. The repro tire companies suggest mid-30s PSI on their tires without any consideration for the weight of the car or the car manufacturer's recommended levels. I run 24 PSI in my daily-driven '39 Tudor's bias ply tires. I have had no issues with the bias tires, using the FORD recommendations rather than the Coker recommendations.
  3. flynbrian48
    flynbrian48
    Interesting. I ran just over 20 psi in the tires on my '36 (avatar). Any more and it was twitch, dart-y, and wandered. That has nothing to do of course with cross steering shoving the axle around in the shackles, but, yeah, tire pressure makes a big difference. And, Vega box, cross steer, and no rear bar.
  4. flynbrian48
    flynbrian48
    I made a new tab for the panhard bar and welded it on. While I had the torch and grinder out I trimmed center piece of X member to be able drop the transmission if needed without pulling the front sheet metal off.
