Projects 1949 Plymouth build thread
Discussion in 'Traditional Customs' started by bartikus, Jan 9, 2016.
  1. gimpyshotrods
    gimpyshotrods
    I think that the stock compression ratio is 7 or 7.1:1. Nice if you want to put a blower or a turbo on....[emoji12]
    I did this with a '49 for a customer. Made a nice improvement. Pretty cheap, too.
  2. bartikus
    bartikus
    I've only had a chance to talk to one machine shop and they want $130 to mill the head.
  3. gimpyshotrods
    gimpyshotrods
    Call around. Make sure they know there need be no dis***embly.
  4. bartikus
    bartikus
    Yeah I will l only had the chance to call one shop yesterday
  5. bartikus
    bartikus
    The last couple of nights has been clean the motor and get ready to reseal it. It has been fun having my 5 year old and 3 year old helping me. There was a some sludge under the valve covers which I was expecting. It will need a new timing chain. I was able to order one in tonight. The bearings look decent enough to rerun them. I'm not pulling the pistons. I'm just going to clean the motor the best I can and throw it back together. I want it in the car this weekend.
    1952B3b23 likes this.
  6. Earlybird
    Earlybird
    from pittsburgh
    So how well do the tires clear the sway bar when turning lock to lock? after upgrading to the jeep cherokee swaybar upside down. when you say cherokee you mean mid sized small cherokee not a grand cherokee?
    thanks,
    John
  7. gimpyshotrods
    gimpyshotrods
    Both the Cherokee (XJ) and the Grand Cherokee (WJ, ZJ) have the same front suspension, in that era (pre independent front), and thus have the same anti-sway bar. There were a couple of different ones, but by far the most common one was 1-inch in diameter. That's the one you want.
    I do not recall the steering being affected in any way.
  8. COCONUTS
    COCONUTS
    OK, now with the new job, I think early HEMI.
  9. bartikus
    bartikus
    Oh I sold the car, had the opportunity to buy an off topic car that I have always wanted. Wife said one had to go.
  10. Jonnie King
    Jonnie King
    from St. Louis
    I've always had a soft-spot in my heart for '49-'54 Plymouths. My Dad own a maroon '49 Club Coupe, and I learned to drive in a '54 Belvedere, powder blue & white...exactly like this one...and, yes, it had Hy-Drive !
    Jonnie
    www.legends.thewwbc.net
  11. plymouth1952
    plymouth1952
    I like the way you think look thru my albums I built a 52 plymouth some years ago using yard parts. my master was used mopar/the rearend and drive train all stock mopar to the drive line a Valory/Diplomat is a great donner car. my 318 /904 trans did a great job. I have a 48 Ply I will be starting soon and its getting a used slant six and a 4 speed overdrive I have it Lol Do the shock mount its day and night also the sway bar makes a real diff. cheap and have fun.
  12. plymouth1952
    plymouth1952
    I have been schooled nice work all of you !!!!!
  13. plymouth1952
    plymouth1952
    Change the water tube while out of the car much easyer
  14. Jeff J
    Jeff J
    Have this one and it's a driver rust free no patch panels New Brakes, Hoses New tires .Upgraded to 12 volt system camera plymouth 034.JPG
