Technical Leading stainless headlight bezels
Discussion in 'Traditional Customs' started by RICH B, Jun 28, 2015.
  1. RICH B
    RICH B
    I am going to french the headlights on my '47 Ford using the original bezels and for some reason I began to wonder if lead will adhere to the original stainless bezels.
    Will this work? or do I need to find some regular steel bezels (or use bondo :( on the
    on stainless rings).
    Thanks
  2. chrisp
    chrisp
    The FASTIN flux is used to lead over aluminum and stainless, regular flux will not work.
    But Fastin isn't sold in the US, can't be shipped by air mail and since USPS doesn't do ground shipping any more "to serve you better" as they say ... You need somebody to smuggle it in the country.
  3. RICH B
    RICH B
    Any more ideas on accomplishing this? Maybe some ideas on alternative headlight bezels.
  4. chrisp
    chrisp
    As you said regular steel bezel will solve your leading problem. If you don't find any that suits you: build them.
  5. RICH B
    RICH B
    Anyone know if the "imported" repop chrome plated steel '47-'48 headlight rings are anywhere close enough to fitting to be worthwhile stripping and using.
  6. lurker mick
    lurker mick
    You're going to weld them to the fender anyway, right? So if the repop steel ones are close you should be able to make them work.
    Mick
  7. See if you can find out what the goo in Fastin flux is- it usually says something like " active ingredient - phosphoric acid". I have gone out and bought the "active ingredient" and used it neat or watered down. Experiment on a s**** piece.
  8. buickvalvenut
    buickvalvenut
    from Rialto
    Look into the Eastwood lead kit
