Projects Home or hand made Parts, no price tags
Discussion in 'The Hokey Ass Message Board' started by topfuel55, Jan 10, 2013.
  1. 117harv
    117harv
    I wish you would have done some tech. threads on your parts, outstanding. Thanks to all who have posted, good stuff.
  2. 19Fordy
    19Fordy
    Coil bracket for flathead engine that remounts the coil. Bolts to the water pump so as to "clean up" the head. Also tool to remove and install Ford torque tube center bearing, oil fill tube with screw on cap and fuel filter alum fittings, upper and lower aluminum radiator hose pipes, adjustable alum. fan hub pulley.
  3. oj
    oj
    My gas tank, a little further along, the tag is one layin around, its' not a '34 DSC00177.JPG DSC00178.JPG
    Just Gary, Ron Funkhouser and Stogy like this.
  4. cretin
    cretin
    Thank you.
    Those are some parts that I made at work, so I didn't do***ent the process.
    I have a Model A roadster project that I'm going to start in on once my current lower budget Model T project is done, that I have plans for a lot of hand made parts. So when I get going on that, I'll start a build thread and show the process in there.
    rod1 and 117harv like this.
  5. cretin
    cretin
    Thank you.
  6. 117harv
    117harv
  7. HOTRODPRIMER
    HOTRODPRIMER
    I'm not a machinist but I do have a imagination so all I can offer is a real low tech idea of using a piece of a JIF peanut ****er jar lid for the missing high beam indicater on a 1954 Ford.:rolleyes: HRP
    rwrj, mgtstumpy, Sporty45 and 3 others like this.
  8. made the floors lower qtrs. wheelhouses and qtr extension for a friends 33 Ply
    mgtstumpy, Baumi and Stogy like this.
  9. Rocky
    Rocky
    Classified Editor
    Old lug wrench for an offset column drop....column didnt' line up under holes in bottom of dash.
  10. Rocky
    Rocky
    Classified Editor
    Made the steering wheel from a 40 Buick wheel...cut the original rim off and bent the spokes up to fit the smaller diameter tubular hoop sourced from HAMB cl***ifieds. 34dashNwheel.JPG
    mgtstumpy, LOST ANGEL and Stogy like this.
  11. Rocky
    Rocky
    Classified Editor
    Made dash from a 34 ford upper rail and a 34 chevy bottom half. cluster is an aftermarket "champion" piece turned upside down to fit the chevy inset.. 34dash.JPG 34dashpainted.jpg
  12. Stogy
    Stogy
    29 Model A Coupe/36 Ford dash/No Glovebox
    Fabbed from Aluminum
    This item is very low in cost so why go through an extensive aluminum
    exercise to make one...because it goes with the wartime aviation theme of the Hotrod
    The notched section in the corner of the box is to clear the curved upper tank panel
    common to 28/29 Fords...Next challenge Get it in!!!Stogy :eek:
    Honestly it was a challenge and fun at the same time.
    1) Visual from internet image
    Interior theme below...
  13. Work4it
    Work4it
    Some great stuff here! Here is a couple of things I have pictures of. A wheel truing rig for putting wider outers on wide fives. DSC_0462.JPG
    A tube beading machine.
    Heater parts using my tube beader.
    Thermostat housing for a Packard straight eight.
  14. brEad
    brEad
    Great thread, glad it resurfaced!
  15. henry's57bbwagon
    henry's57bbwagon
    I needed a fuel fitting for my 57 and did not want to wait so I took some round aluminum and machined it.
    mgtstumpy and Stogy like this.
  16. Great thread keep the info coming.
    Stogy likes this.
  17. k32t
    k32t
    from Hog town
    made some seats
  18. Max Gearhead
    Max Gearhead
    from Wisconsin
  19. LOU WELLS
    LOU WELLS
    from IDAHO
    Just a simple plate to mount my H.A.M.B tag 2017 015.JPG H.A.M.B. plaque where the 3 holes were left by the extinct generator regulator.....
  20. Kato Kings
    Kato Kings
    from Minnesota
  21. RichFox
    RichFox
    External oil pump mount for 28 Chevy converted to pressure. Uses Honda Gold wing pulleys and shaft bearing DSCN0015.JPG
  22. k1w1rodder
    k1w1rodder
    built an easy lift. Pardon my ot Duster:oops:
    Stogy likes this.
  23. Stogy
    Stogy
    Update...
    Procrastinator Stogy finally got the Glovebox prepped and installed into the ole Hotrod...All that remains is a latching system. 36 Fords had a spring system and that is long gone...it is available repro but I am going to add a latch of some kind...for now its just a temporary spring...
    The literally quick n' dirty modified former tank complete with sharp edges everywhere...
    note 4 mounting holes with two hidden in hinge area...
    I pre installed the box where I wanted it and marked all the holes and opened 4 for riv nuts...and two clearanced holes for hinge area. Riv-nuts are super cool and come in many sizes...I chose 8/32UNF riv-nuts with pan head slotted screws which p*** for the look...
    Minus the latch (TBI) I'm pretty happy with it...I may fab a covered pad to sit and cushion the goodies
    such as...
    :rolleyes: Latch option 1
    (I have but it is sorta to modern...ish)
    pcs-cabi-closers-xmm-magic-closet-door-catches-cabinet-doors-with-glass-cabinet-doors-unfinished.jpg
    :rolleyes: Latch option 2
    (I think this looks old...er)
    I will post a follow up when latch is installed...;)
    brEad, LAROKE, fauj and 2 others like this.
  24. brEad
    brEad
    Nice job @Stogy on that glove box!
    Stogy likes this.
  25. manyolcars
    manyolcars
    charleyw and TagMan like this.
  26. 41rodderz
    41rodderz
    from Oregon
  27. 19Fordy
    19Fordy
    Wow! There really are some talented "metal head" HAMBers.
  28. 41rodderz
    41rodderz
    from Oregon
    brEad likes this.
