Customs Is this Gasser front straight axle SAFE for the street??
Discussion in 'The Hokey Ass Message Board' started by justadream, Jan 15, 2017.
  1. justadream
    justadream
    from Vermont
    I was serching around on the web and came across this front axle setup on an old 57 chevy g***er and I was wondering if this would be possibly to do but have it SAFE enough to drive on the street. Screenshot_2017-01-15-09-49-20.png
    Unkl Ian likes this.
  2. What,s that old saying ???
    If you have to ask , you probably already know the answer !!!
    I would have a hard time crawling under it to work on it!!!
    Let alone climb in it to drive it !!!!
  3. khead47
    khead47
    I don't think so !
    lemondana likes this.
  4. If done right yes, but that looks sketchy as hell!
    And why would you? There's better options that are tried and true.
  5. A lot of them have been run. I don't like a cross leaf on a heavy car like a tri five chebby. But that is possibly just me. I may run that setup if I was running coil overs and just use the cross leaf and radius rods for locators.
    dana barlow, bschwoeble and mad mikey like this.
  6. RMR&C
    RMR&C
    from NW Montana
    It'll be fine...just don't go around any corners!:eek:
  7. squirrel
    On a positive note, it looks like no one ever tried to drive that car with that axle under it.
  8. squirrel
    On yet another note, think about the car you're building, and how you are planning to attach the axle to the "frame". Does that transverse leaf spring look like it will fit your plans?
  9. jeepsterhemi
    jeepsterhemi
    1957 Chevy.jpg Not as scary as this one..........
    dana barlow, fol, clem and 5 others like this.
  10. Hnstray
    Hnstray
    from Quincy, IL
    :eek: I think cars like those pictured were the inspiration for the term POS !
    Ray
    justadream and bobg1951chevy like this.
  11. saltflats
    saltflats
    from Missouri
    Looks like done properly it should work.
  12. CalGasser
    CalGasser
    I think they were going 4X4 Off Roading...
    kiwijeff likes this.
  13. chevy57dude
    chevy57dude
  14. saltflats
    saltflats
    from Missouri
    I am sure Ric's car isn't a death trap.
  15. chevy57dude
    chevy57dude
  16. squirrel
    heh...the fun thing about all these pics of 57 chevys is that he's building a Comet.
    czuch, Moriarity and X38 like this.
  17. saltflats
    saltflats
    from Missouri
    Is this a Chevy truck axle and what year?
  18. fast30coupe
    fast30coupe
    from Illinois
    Second generation axle 55-59 works best. The spring perches are straight and fit perfectly under the frame. Earlier axles were had tapered perches which makes it more work. Drill some holes and send it to chrome.
    mad mikey and saltflats like this.
  19. saltflats
    saltflats
    from Missouri
    That would be my luck.....I have a 47 axle.
    fast30coupe likes this.
  20. Mr48chev
    Can't say one way or the other if that mess in the first post ever ran but a hell of a lot of tri 5 Chevys got hacked up in the mid and late 60's when the g***er look was the hot lick and the cars were cheap. I doubt if the majority of them ever got driven as the projects usually failed before they got finished or got hauled off to the junk yard after the owner got drafted and the parents got tired of having "that junk" in the way. Local guy had a 55 with probably a 55/59 truck suspension, a 364 Buick set back 10 percent and I don't know what for a trans. he worked on it all the time at the gas station he and his bud ran in town but I don't ever remember seeing it run on the street or track.
    Unkl Ian, X38 and 302GMC like this.
  21. DDDenny
    Normally a response to a photo like this (not closeup), would be "It's kinda hard to tell from here", but in this case it's pretty clear (to me), that looks pretty iffy.
  22. trollst
    trollst
    Simple, if it don't look right, it isn't, no I wouldn't run that. It shows how the rest of the car is built.
  23. metalman
    metalman
    I personally wouldn't have a problem running that axle, looks to be a stock 35 up Ford axle setup. I do have issues with how it's installed however, particularly the front cross member/ lift block spring mount and the right bone is bent. Angle of the draglink looks sketchy. In general I think the problem comes in with too much lift. I like the straight axle "g***er" look myself but don't believe they have too sit sky high to be cool.
    Don't understand your questain however, are you thinking of buying the axle setup (or whole car) you've pictured or just wondering if a Ford axle can be used under a Chevy?
    Hackerbilt likes this.
  24. mad mikey
    mad mikey
    With that block on top of the spring and long bolts that look like twigs, its pretty SCARY looking.:eek:
    Hnstray likes this.
  25. dirty old man
    dirty old man
    Personally, I like the concept of a transverse spring and either radius rods, wish bones, or 4 bars way better than paralell springs for controlling the front axle, but also with a panhard bar. But maybe that's because I have way more experience with the transvrse Ford setupo than I do with the paralell setup.
    The rest needs to be carefully thought out with regard to heighth, shocks, and steering, and the example provided by the OP looks to have be n planned and built by the 3 stooges with ***istance from Cheech and Chong:eek:
  26. squirrel
    the car he's building is a Comet, with no substantial frame crossmember to attach a transverse spring to.
    Unkl Ian, gimpyshotrods and X38 like this.
  27. chevy57dude
    chevy57dude
    MAS axle and springs
    mad mikey likes this.
  28. Rusty O'Toole
    Rusty O'Toole
    Compared to what? No straight axle g***er is safe. I can show you videos of them rolling over on the drag strip, not even trying to corner. The best of them may be almost as good as a stock front end with worn out shocks and no sway bar but I doubt it.
    The transverse leaf front end is particularly scary. Even in the 30s and 40s they were known to be inferior to other designs. Ford only kept it because Henry insisted. As soon as he was dead and under the sod they designed an IFS with coil springs like everyone else.
    Unkl Ian and 302GMC like this.
  29. 302GMC
    302GMC
    from Idaho
    This current re-fadding of the "g***er" "straight axle" trends has lasted many years longer than it did in the '60s
    Unkl Ian and Montana1 like this.
  30. squirrel
    I had fun driving home last night in my straight axle car, my wife kept falling behind me, in her Dart, on the twisties from Sahuarita to Sonoita.
    I also saw a picture yesterday of the straight axle Rambler wagon that rolled on the way to Tucson Friday. but he was driving on slicks, in the rain.
    kiwijeff and saltflats like this.
