Let's Talk Cyclecars
Discussion in 'The Hokey Ass Message Board' started by Bigcheese327, Dec 4, 2007.
  1. Rolfzoller
    Rolfzoller
  2. Kume
    Kume
    Straight out of Wacky Races. Interesting story about the electric torpedo car. I wonder if anyone used the Naval whitehead torpedo compressed air motors of the 1880s to power a road vehicle. I think they were the first machines to work out that the pointy end of the teardrop should be at the back.
    Rolfzoller and motoklas like this.
  3. motoklas
    motoklas
    from Bern, CH
    Hello Rolf,
    the first one is Oldsmobile Pirate, quite strange racing car.
    As now we know what was the second one (thank you Kume!), just to find what is the third and the fourth?
    Ciao,
    Zoran
    Rolfzoller likes this.
  4. motoklas
    motoklas
    from Bern, CH
    Kume,
    Interesting idea! Probably that vehicle powered by torpedo's motor shouldn't be too heavy comapred with electric racer? Speed and endurance - good for short sprints, the same as electric racers?
    Porbably - unsolvable problem should be to find such torpedo-complete, if not be sponsored by Navy or manufacturers of torpedos.
    Z.
    Herb Kephart, Ned Ludd and Rolfzoller like this.
  5. jim32
    jim32
    ??????????? well at least it is historic.
  6. chrisp
    chrisp
    Their are a couple of concept compressed air powered cars maybe even one production car, were there any early cars powered like that?
  7. Ned Ludd
    Ned Ludd
    Recent ones were largely French experiments, I think? The problem remains pressure loss as heat.
  8. banjeaux bob
    banjeaux bob
    from alaska
    16105751_1229726680439307_8536600570654839455_n.jpg Darmont G.C.L.
    Herb Kephart likes this.
  9. motoklas
    motoklas
    from Bern, CH
    ...connection between cycle-cars and compressed-air motors?
    I am not sure if such combination as ever used in vintage era, but now it could be done, converting small 4-stroke engine in to compressed-air, similar to steam-powered conversions.
    Is it possible in DIY workshop - YES! But, is it practical - NOT quite! Power isn't significant and range is symbolic. However, who want to play with that - it isn't too complicated and expensive. Just to reconstruct camshaft to have two strokes: intake (pressurized working cycles) and exhaust... and, to buy big bottle(s) and workshop compressor to fill it/them with a lot of compressed air!
    Ciao,
    Zoran
  10. noboD
    noboD
    How about a two cylinder engine? One to pump air to fill the tank and the other to use the air to power the cyclecar? smileyface!
    motoklas likes this.
  11. Kume
    Kume
    The brotherhood 3 cylinder radial engine used in thousands of torpedos from 1880s to WW2 was quite light 30 - 40 lbs. early ones ran at 1200 psi (to begin with). I understand many were sold for s**** or utilized as stationary engines or used to power capstans etc.
  12. motoklas
    motoklas
    from Bern, CH
    ... or, to move money from one pocket to another, and becoome rich?
    ... or more techical solution: to use diesel engine to propel electric-generator of 220 volts and convetor to 12 volts to produce electrictiy to fill ac***ulators, then convertor to 220 volts to give electrictiy for workshop-comperessor with big bottle to fill small bottles to propel air-compressed motor wich propel cyclecar?
    (all of that on cycle-car! with 200 kg total weight of my wife and myself)
    Z.
    P.S.: I would like to try simplest solution of small engine tranformed to compressed-air motor (working on workshop table)... maybe, next time!
  13. motoklas
    motoklas
    from Bern, CH
    P.P.S.: Serious problem is storage of big quan***y of compressed air, on relativelly small and light vehicle!
    Z.
  14. banjeaux bob
    banjeaux bob
    from alaska
  15. Rusty O'Toole
    Rusty O'Toole
    Years ago I read a 1903 book on the latest inventions. One of them was a compressed air powered car. It was a typical 1900 'gas buggy', powered by liquid air. Ordinary air compressed to 600PSI becomes liquid. An insulated tank contained the liquid air which powered a steam engine.
    If you wanted to build one today you can buy cylinders of compressed nitrogen @ 2000PSI very reasonable. They are sold by welding gas dealers. This is the same nitrogen that tire dealers have been promoting for the last 10 years.
    A simple uniflow engine can be made from a 2 stroke modified to admit steam or compressed gas through the head, and exhaust through the crankcase.
    Kume and motoklas like this.
  16. Herb Kephart
    Herb Kephart
    The crate cargo says "speed". I'll bet, with that lawnmower engine it must get up to 12, maybe 15 MPH!
  17. rooman
    rooman
    Actually that is a sign on the property fence--maybe an early iteration of Speedwell Engineering? Nope, maybe not. I just checked and the basis of the most recent iteration of Speedwell was started in 1957 and this photo looks earlier than that (although you never know with the Brits) :)
    Roo
  18. motoklas
    motoklas
    from Bern, CH
    Herb,
    With such construction - I would be satisfied with lower number and higher speed use just to show-off!
    ..and, that above could be three-wheeler hot-rod gang, good for speeding and frightening of people?
    ... and, that bellow a SUV (sport-utility-vehicle):
    ... above: off-road, edventure three-wheeler with front-wheel drive? (as all other)
    Zoran
    banjeaux bob and Herb Kephart like this.
  19. banjeaux bob
    banjeaux bob
    from alaska
  20. Bluto
    Bluto
    If we are going to talk about trucks.......
    This is our Solyto New Map "Camping" It's a deluxe meaning it has a p***enger seat!
    banjeaux bob likes this.
  21. motoklas
    motoklas
    from Bern, CH
    Hello Bluto,
    Nice photo indeed, with two cars on oposite scale of size and style! Maybe Rolls-Royce has more space, even for camping, but for practical reasons I would take Solyto New Map "Camping"! Maybe too small for me (for camping), but could be good for short cruising across and around Bern, with excursions to nearby rivers and lakes, smaller hills, too!
    Again we have front-wheel drive on three-wheeler!
    Ciao,
    Zoran
  22. banjeaux bob
    banjeaux bob
    from alaska
  23. Bluto
    Bluto
    Zoran
    "Camping" is just the model name.....
    This on has very very few... less that 1000 kms from new. When I got it they had pulled the rope starter just make sure no one could get it going. My thought is the first owner must have scared himself and stuck it in the garage We went thru the engine and just replaced the crank seals (a good idea on any old 2-stroke). I got a Briggs rope starter to fit. Even have a spare engine.
  24. banjeaux bob
    banjeaux bob
    from alaska
    5715_938281676250477_4286927117090445628_n.jpg 1914632_938281772917134_7372063892780771095_n.jpg 10653451_938281469583831_5157743628190991262_n.jpg 12507405_938281532917158_2039571337827360255_n.jpg 1012582_938281572917154_3072885396284031602_n.jpg 10338874_938281626250482_6056479190984443095_n.jpg 12376396_938281709583807_2769408042351640193_n.jpg 12510262_938281749583803_8868565777036589115_n.jpg Riley powered Amilcar special . images by G.C.L. ....
    Jacketch, Ned Ludd, Kume and 2 others like this.
  25. noboD
    noboD
    Is that like a shooting brake has nothing to do with brakes or shooting?
  26. banjeaux bob
    banjeaux bob
    from alaska
  27. banjeaux bob
    banjeaux bob
    from alaska
  28. rooman
    rooman
    A Russell Brockbank cartoon. He was the absolute best.
    Roo
  29. brg404
    brg404
    um: "Shooting-brake originated as an early 19th century British term[1] for a vehicle used to carry shooting parties[2] with their equipment and game."
  30. Rolfzoller
    Rolfzoller
