Projects 1950 moredoor shoebox completed!
Discussion in 'Traditional Customs' started by Tom. C, Jan 16, 2017.
  1. Tom. C
    Tom. C
    IMG_20160710_174147.jpg This project started in July when I found this car in a shed and it has been their for 50 yrs. I bought the car mostly for the flathead but after I seen what a chopped shoebox looked like
    I thought I'd give it a shot. I am a State Corrections Officer and Prof. Taxidermist. My hotrod building experience none. Everything I've learned, I've learned from this sight and a couple others so I will thank you now for all your experiences and recommendation to other builders. I was given a f150 with a 302 (powerplant). I was also given an s-10 frame(front clip to gain power steering disc brakes etc. This is a budget build. I purchased a T5 ****** and at this point I'll be mocking up motor/******/power steering before separating body from frame. Any good info on the motor mounts ****** cross member.
  2. manyolcars
    manyolcars
  3. Latigo
    Latigo
    Like he said, Bold. Looks like you're on your way. Quite a first project. Good job!
  4. Toqwik
    Toqwik
  5. Good job. I'll be watching this.
    Keep us posted.
    I have a recurring fantasy to chop our 49......
  6. steinauge
    steinauge
    from 1960
    Looks mighty good so far! I understand the 302,the flathead will be pricey to rebuild ,but have you considered not cutting up the stock ch***is? It didnt cost me much to rebuild the brakes on my shoebox .
    flatheadpete likes this.
  7. laidbackluis
    laidbackluis
    from Sachse Tx
  8. Tom. C
    Tom. C
    The S-10 clip is already on and welded. This clip was more sweat equity but I cant fork a lot of money to rebuild original and still not have disc brakes or power steering. I have $275.00 in every component to redo the hole front end of S-10. Thanks for your comments I am a rooky and learning as I go and cant get enough, Loving every challenge in this build.
  9. Toqwik
    Toqwik
  10. Rocky
    Rocky
    Classified Editor
    Yeah, I was wondering the same thing. Last shubox I did was using the original ford stuff with flipped spindles and cut coils. Would have loved something a little more modern but didn't...... Rockybox.jpg
  11. Cool project. Are you keeping the flathead, or going with the 302? I'm curios, because I'm looking to get a T-5 to go with my flathead.
    I'm gonna watch this show either way.
    Way to go on the chop!
  12. Tom. C
    Tom. C
    I didn't test fit yet, Ill try tomorrow and post a few pictures
  13. Tom. C
    Tom. C
    Putting 302 in as the flatty is locked up. When I tore the motor apart their were mice nestings clean done in the crank. Anybody got any concoctions to put flatty in while I work on this project. Maybe it will free up if I soak it for a while.(That's what she said). I appreciate all the comments and questions Thank you
  14. Jalopy Joker
    Jalopy Joker
    Great work so far - possibly look at sites like speedwaymotors.com for universal engine mounts - maybe hit the wrecking yard for a 5 speed crossmember out of a S10 - I know that a S10 rearend bolted in to a '51 Ford - be sure to get rearend out of truck that still has the id code sticker on the glove box door for rear gear ratio
    Sent from my SM-G930V using The H.A.M.B. mobile app
    Jonnie King likes this.
  15. Tom. C
    Tom. C
    Is the s10 rear strong enough for the 302/t 5 ******? I was thinking of putting a 90-92 ranger 8.8 but if the s10 rear is strong enough and the right width I might put it in instead.
  16. dwollam
    dwollam
    That looks like it may be a Merc Flathead. If it is it is a 255 w/4" stoke crank. Be sure to save that. Heads will have 8CM or similar for Merc. 4 bolt carb and intake is Merc. All good stuff.
    As far as something to soak in, animal food grade mol***es mixed with water makes a good soaking solution. Non toxic and can be re-used over and over. Get a big tub of some kind. Mine sits outside and water evaporates so every now and then I add water. Get a 5 gal. can of mol***es at a feed store. Last one I got was about $25. Google it for mix ratio and directions. Doesn't matter if you forget and leave something in there, no damage. I have used it on gas tanks, rusty stuff, you name it. Did a motorcycle gas tank for a friend that was clear full of gunk, weighed a ton! Cleaned it all out like new and didn't touch the factory paint!
    Dave
    gearheadwelder likes this.
  17. Tom. C
    Tom. C
    Thanks for the info Dave, I have a feed mill less than a mile away, probly get mol***es fairly cheap.
  18. coupe33
    coupe33
    Nice chop and did you say your a rookie?
  19. If you are keeping the ch***is stock use Trans dapt motor and transmission mounts, they are inexpensive and fit well.
    If it were me I would sell the S-10 clip and buy a '50 Ford specific disc brake kit if I was after disc brakes. Well I probably wouldn't personally but that is what I would suggest. The difference being is that I don't stuff birds but I can build a car from a lug nut. No offense intended.
  20. HOTRODPRIMER
    HOTRODPRIMER
    With no experience it sure looks like the work of a old pro.HRP
  21. pumpman
    pumpman
    Great job Tom C, got ta give you credit to have the guts to go for it. I'd still be thinking about it.
  22. I never understand why guys are in such a hurry to clip a shoebox, but it's not my car so go for it. Chop looks good, keep us posted.
  23. Tom. C
    Tom. C
    Rocky and Toqik I'm glad you asked yesterday about front sheet metal. I fitted the inner fender today it needed a little trim at the bottom to clear the upper control arm. here are few pictures before and after.
  24. Tom. C
    Tom. C
    THANKS FOR ALL YOUR HELP AND IF I WERE YOU I WOULD STAY CLOSE TO THE PHONE BECAUSE WHEN NASA OR PLAYGIRL FINDS OUT WHAT YOU CAN DO WITH NUTS THEY WILL LIKELY BE OFFERING YOU A JOB.
  25. Tom. C
    Tom. C
    no offense intended
  26. Already done work for the FED couldn't for the life of me tell you what it was, just part numbers and extremely close tolerance ***anium. The machining was easy enough but being locked away for 12 hours at a stretch was a pain in the ***. :) I guess you are familiar with the being locked away part of it. It paid OK but I'm probably not any more interested in working for the fed again than I am high maintenance broads.
    Good luck with the more door. looks like you got it handled.
  27. Tom. C
    Tom. C
    Ive been working on the clutch/brake pedals. The f150 I got the motor out of also had a pedal ***embly.
    I adapted this to my shoebox firewall as I will have power brakes and a hyd. clutch. Believe it or not the f150 steering shaft and the s10 steer shaft fit right together. Look at pictures it went together fairly well but I wish I new whether or not their is a smaller brake booster with the same bolt pattern as the f150. This one will work but I'll have to trim the inner fender a little.
  28. Tom. C
    Tom. C
    Whoops hit wrong ****on
  29. I agree with HRP , he may be a rookie but that looks like the work of an old master (i.e. Gene Winfield, George Barris, **** Dean etc..). Great job [emoji106]
  30. critchdizzle
    critchdizzle
    from Owasso, OK
    Looking good so far.
