Projects So here we go on the 60 Comet project
Discussion in 'The Hokey Ass Message Board' started by justadream, Nov 27, 2016.
  1. squirrel
    that's words of wisdom, right there.
  2. gimpyshotrods
    gimpyshotrods
    I need to follow my on advice too, so don't any of you get the idea that I think that I am, or that I am somehow above this. It has taken me 47-years to get the number of good things that I do in a day to eclipse the number of things that I do wrong. I am trying. Every day I reveal more of the big picture, only to discover that it is even yet still far bigger than I expected.
    Life can be an humbling experience.
  3. What's with the mouth ?:mad:
  4. justadream
    justadream
    from Vermont
    Heres a night pic of my garage (Mess), with my work in progress 20170119_170504.jpg
    Gammz and rjones35 like this.
  5. justadream
    justadream
    from Vermont
    Nothing.
  6. If that windshield is still good, you'd better cover it real well with all that welding and grinding going on. It will get peppered
    loudbang and BradinNC like this.
  7. justadream
    justadream
    from Vermont
    Ok, now back to the program...... Can somebody please help me out on how I should repair the sheet metal that I ripped and cut out not thinking about how flimsy the fender wall is without the shock tower flange, so im going to try and work it back in but not sure what to do with the missing **** that I cut out so the hole in one area is now larger then the flange so it cant be welded back in. The largest area is near the 3 holes which is about 2in. Thanks with any help. photostudio_1484869166712.jpg photostudio_1484869429677.jpg
  8. gimpyshotrods
    gimpyshotrods
    Are you planning on running fenderwell headers (go through these panels), or ones that go between the rails?
    justadream likes this.
  9. Gammz
    Gammz
    from Lincoln Ne
    What type of welder do you have? If your good you might be able to s***ch weld it back together. Paying very good attention to your heat. Or ya could cut some filler pieces out of the same gauge sheet metal for the really wide gaps.
  10. First !!!!
    Figure out your headers exit path
    gimpyshotrods and Gammz like this.
  11. Gammz
    Gammz
    from Lincoln Ne
    gimpyshotrods likes this.
  12. justadream
    justadream
    from Vermont
    I am planning on running fenderwell headers.
  13. justadream
    justadream
    from Vermont
    I just have a small Lincoln pro 125, but im no pro, haha. It has the settings A,B,C and D with wire speed 1 -10. I have only welded on thick stuff with the 1/8 plate being the smallest, never done any sheet metal, at least not yet.
    Gammz likes this.
  14. justadream
    justadream
    from Vermont
    This is why I have been trying to find a good close up pic of a Comet or Falcon to see where abouts they dump out through.
  15. Gammz
    Gammz
    from Lincoln Ne
    Get some practice pieces and get plenty in before ya go after it on your car.
  16. gimpyshotrods
    gimpyshotrods
    I'd get the actual ones, before working the inner fenders.
  17. For sure!
    It could get all patched up then cut and filled again.
    Double job - great for practice but not so good for progress and budgets.
  18. justadream
    justadream
    from Vermont
    20170121_161749.jpg 20170121_161836.jpg 20170121_161900.jpg 20170121_161932.jpg 20170121_175357.jpg 20170121_175443.jpg 20170121_183235.jpg 20170121_183504.jpg 20170121_184502.jpg 20170121_184528.jpg Been out in the garage most of the day today, got the p***enger front side done on the frame, all plated up and decided to hit the inner fender by getting down to bare metal and get some primer on it. I did weld the back ends of the plating yet because I might just cut the sub frame out and weld in some tubing instead.
    Gammz likes this.
  19. justadream
    justadream
    from Vermont
    Me, lol
    Gammz likes this.
  20. justadream
    justadream
    from Vermont
    20170123_205108.jpg Another day out in the garage. Got the drivers side shock tower cut out and this time I left the flange spot welded to the inner fender well and just cut the tower itself out. Also got the other brackets, plates and the steering column and WHAT A *****, lol. Didnt have a steering wheel puller so I made a makeshift one out of C channel and a few bolts and 2 welded nuts, looks like **** but worked perfect. 20170123_133343.jpg 20170123_133402.jpg 20170123_133255.jpg
    Gammz likes this.
  21. justadream
    justadream
    from Vermont
    1485223011323.jpg One more.....
    Gammz likes this.
  22. Gammz
    Gammz
    from Lincoln Ne
  23. justadream
    justadream
    from Vermont
    Damn right, and ALOT cheaper, lol. Going to build a spot welder next, just have to find a free microwave, SERIOUSLY.
  24. Gammz
    Gammz
    from Lincoln Ne
    Get a tech thread going to give details.
  25. squirrel
    I have a microwave in my s**** pile....hmmm.....
  26. justadream
    justadream
    from Vermont
  27. gimpyshotrods
    gimpyshotrods
  28. justadream
    justadream
    from Vermont
    Just curious........ Has anyone, or know of anyone that when they built the motor mounts, or even kept the stock ones, ever made them so the motor sits a little higher the stock mounts do? Or not a good idea?
  29. Raising the engine could affect your transmission output shaft angle, which may/could affect how you obtain the correct pinion angle, which will affect overall driveshaft inclination.
    A domino affect.
    loudbang, Gammz and justadream like this.
  30. squirrel
    If there's a reason to make it sit higher, you could. I kind of like keeping it all where it was originally, but I'm kind of weird.
    Make sure it's straight (left to right), and the drive line angle is set right. The rest really isn't too picky,
    you can set the driveline angle when you install the new rear end, if you're installing a new rear end
