Hot Rods "The Creeper"
Discussion in 'The Hokey Ass Message Board' started by mike bowling, Jan 17, 2017.
  1. Sporty45
    Sporty45
    This will be fun to watch! Leaving the bullet hole in it??? :cool:
    bondolero and mike bowling like this.
  2. Thor1
    Thor1
    Mike,
    My grandparents grew up during the depression and the "make it do or do without" mindset was instilled in me as I grew up. I appreciate your build and your approach to it. I am really looking forward to watching your car come together.
    Steve
    AHotRod and mike bowling like this.
  3. mike bowling
    mike bowling
    Hey, "Sporty 45",
    Nope, but it was full of them! Go back to the first page and check out the back window ( Looks like Melvin Purvis used it for target practice)
  4. Are these the rails you got from me?
  5. mike bowling
    mike bowling
    Those rails ( boxed with 1/4 " plate) are indeed imported from your NY Emporium, Robert.
    Front X-member is an aftermarket item I got to put in my roadster but didn't.
    Didn't use the rear X-member I got at Fitchburg so I could use old "Ch***is Engineering" coil overs I got from Timmy Carroll's barn ( local Hot Rod hero and Madman - RIP) DSCN2556.JPG
    mad mikey and AHotRod like this.
  6. mike bowling
    mike bowling
    This "build thread" is going to be kinda all over the place because , as you all know, these things go together and come apart MANY times during the process. And **** happens in between.
    Ryan has outlawed naked women ( on a car site????), but between photo sessions of this meticulously put together future cl***ic ( that my kids have to download for me), I will attempt to keep you entertained. Thankyou for your support and understanding.
    loudbang, enloe, gas & guns and 6 others like this.
  7. That reminds me, who needs what brought from New York to Fitchburg this year?
  8. mike bowling
    mike bowling
    mad mikey likes this.
  9. mike bowling
    mike bowling
    Re- designed ladder bars to lock in the axle (along with the panhard bar).
    Axle brackets for them (hand carved) DSCN3040.JPG DSCN2987.JPG DSCN2988.JPG DSCN3043.JPG
  10. mike bowling
    mike bowling
    DSCN2222.JPG DSCN1592.JPG View attachment 3431106 Also seen in the last post^^^^^
    '68 Mustang steering box with shortened, reversed pitman arm
    Drag link made from an old tie rod
    Handcrafted (?) upper mounts for the tube shocks
    "Hoop" steering arm, shortened 1.5" for clearance
    checking to see if running board brackets will fit ( of course they will, after I remodel them!)
    I'd like to run full fenders , splash aprons and running boards ever since I built this roach a couple of years ago--- ( another erector set, chopped 3", channeled 4")
  11. I LOVE IT!!!!
    mike bowling likes this.
  12. mike bowling
    mike bowling
  13. mike bowling
    mike bowling
  14. mike bowling
    mike bowling
    Old PG ****** to gut and use for mock-up to locate ****** X- member DSCN3049.JPG
    mad mikey, Dino 64 and Stogy like this.
  15. mike bowling
    mike bowling
    Finally starting to look like something. Once the ****** mount is located, I'll have to work on the steering column and brake pedal- 10 pounds of **** in a 5 pound bag! Plywood blocks are centering the motor in the frame ( not structural). DSCN3053.JPG
  16. biggeorge
    biggeorge
  17. mad mikey
    mad mikey
    Damn it , it is about time you build this beast! LOL. I have said it before , and I will say it again, I LOVE THIS CAR!!! Great work Mike, another bad *** hot rod being born.:D:D
  18. mike bowling
    mike bowling
    Appreciate it, Brother- lots of inspiration from YOUR car!
    This is an exercise in going outside the norm--from the mundane to the insane!!
    Just because.
    biggeorge likes this.
  19. mike bowling
    mike bowling
    To be honest, I cheated a bit- I've been pecking at this for a while, but didn't have pictures and hesitated to post a**** all the excellent builders and projects on the HAMB.
    But finally decided WTF, why not! ( turning 69 this year and needed SOMETHING to do!)
    Thanks for your encouragement; I shall Forge On!
    cactus1, Stogy, Dino 64 and 1 other person like this.
  20. biggeorge
    biggeorge
    I understand what you mean. I haven't posted any on my 30 Buick I'm building for the same reason. I'll be 68 next month so maybe when I'm 69 I'll do a do a build thread on mine. Besides I can't keep up with that youngster Flavin [emoji850]
    mike bowling and AHotRod like this.
  21. TFoch
    TFoch
    I like where this is going. Looking forward to watching the progress. Got to have something to keep you busy during these New England winters!
  22. gonzo
    gonzo
    Mike what steering box are you using, also what's your plan for exhaust, headers or manifolds?
    I've got a small pile of extra SBC stuff I can raid if you need something.
  23. mike bowling
    mike bowling
    Hey, John,
    Box is late '60s Mustang ;I've got to figure the exhaust out later ( I have the original ram horn cast ex. manifolds and some Mr. Gasket header flanges if I decide to do something different ( and probably very noisy).
    (maybe fender well headers ?)
    Thanks, I appreciate the offer and will keep it in mind.
    gonzo likes this.
  24. mike bowling
    mike bowling
    Not even in the equation!!! (file photo- he was a lot younger here) HaHa
    kidcampbell71 and biggeorge like this.
  25. mike bowling
    mike bowling
    Hockey puck motor mounts, bolted to a Hurst style front engine mount;
    ****** mount from the New England Dragway Swap (20 bucks, new, love it!)
    Angle iron rear X-member to figure out coil overs- decided to take off stock x-member and fabricate a new one and redo the torsion bars to ladder bars. More better. DSCN3043.JPG DSCN3063.JPG DSCN2964.JPG
    TFoch, gonzo and AHotRod like this.
  26. mike bowling
    mike bowling
    Going ***- backwards as promised, but thought I should fill in a few areas.
    '82 Camaro 10 b0lt posi rear with finned aluminum drums- woo whoo
    And the garage Attack Kat waiting for a victim.................... DSCN2897.JPG
    Stogy, AHotRod and biggeorge like this.
  27. mike bowling
    mike bowling
    Pulled the cover off the rear axle- clean as a pin. It will of course be getting all new brake components. DSCN3041.JPG
  28. mike bowling
    mike bowling
    *****in' 40 Ford dash I got from the HAMB cl***ifieds a few years ago. It needs to be sliced and diced to fit, but it's getting used! I've got some nice gauges to put in after the re-model.
    Runnin shine, adam401, gonzo and 2 others like this.
  29. Thor1
    Thor1
    Hey Mike,
    I was looking at the "Got Creeper? thread a few minutes ago and it got me to thinking - why do you call your coupe build "The Creeper"? I may have missed it but I didn't see an explanation anywhere in this thread. I am just curious.
    Steve
  30. gonzo
    gonzo
    Oh man now you're going to have to find some finned Buick drums for the front to match those s****y aluminium rear drums.
    biggeorge, mike bowling and Stogy like this.
