Technical 1939 Mercury Build
Discussion in 'Traditional Customs' started by swissmike, Jun 28, 2015.
  1. King ford
    King ford
    from 08302
    Nice worksmanship, very educational....thanks for sharing!
    swissmike likes this.
  2. swissmike
    swissmike
    Moving on to the other side. Replacing the leading edge of the fender.
    Shaping the flange where it bolts to the body
    cretin likes this.
  3. swissmike
    swissmike
    With reinforcement backer in place. It is plug welded around the entire perimeter every 3/4" or so.
    Bolted on. The running board will have a rubber piece between the fender and edge of running board. It will be flush once the lower mounting bolts are installed.
    There are still a few bumps and dips , but I'll leave that for later.
    All for today!
    koolkemp, brEad, biggeorge and 6 others like this.
  4. HayesDesign&Restlying
    Nice, looks great. You've done alot! Where's the car from, alot of rust. Gotta repair all the structure. Before customizing, is it gunna get chopped eventually?
    Sent from my SM-G360T1 using The H.A.M.B. mobile app
  5. swissmike
    swissmike
    The car is from upstate NY. It looked better because some of the rust was covered up with fibergl*** mat and bondo and primered.
    The immediate goal ist to do the major rust repair, then get it blasted and primered, and then chop it.
    rodncustomdreams and el Roach like this.
  6. Awesome. I can't wait to get back to working on my 40 Merc. Are you Swiss btw? I am. Born and raised there.
  7. swissmike
    swissmike
    Thanks Chris! I borrowed your idea of opening up and reshaping the wheel opening. Worked great and leaves a stock looking rolled edge.
    Born and raised in Switzerland (SZ) as well. Florida now for 17 years now.
    I am looking forward to seeing more progress on your 40. I will be spectacular like all your cars. Have you decided on a color?
  8. CadMad
    CadMad
    I've been lurking here and there whilst my Cad is stalled. Always enjoy seeing what you are up to. You are getting close to the exciting stuff. Glad you have methodically done the "mundane" stuff first. It just gets better and better.
  9. swissmike
    swissmike
    I appreciate the kind words. Your Cadillac has been my favorite project on the H.A.M.B. for a while. First rate style, engineering and execution.
    lowcoe and jakespeed63 like this.
  10. Cool, 23 years in the US for me. From Bern.
    The idea about the larger wheel openings came from Lee Pratt. We where brainstorming on how to get the wheels out in case of a flat tire and he suggested to open the wheel openings. He hadn't done this before either. I initially thought it would look stupid but with skirts you could never tell.
  11. patterg2003
    patterg2003
    Still really enjoying the craftsmanship and your ability to rebuild a car with a minimum of tools. Learning a lot watching your thread and appreciate the thought process given to each repair. There was a 40 Mercury when I was a kid that was on my way hunting in the mid sixties. The owner parked it so it was a big tease. & would not let anyone near it. The 39 & 40 Merc's are are great looking car and it is good to see life being returned to your car.
  12. swissmike
    swissmike
    Interesting! I actually never like the look of the small wheel opening in addition to the fact that the skirts would have required more modification. I chose to give the rear edge of the opening a little bit of a slant rather than keep it circular and I believe most people wouldn't know if it was factory or not.
    Chris Casny likes this.
  13. swissmike
    swissmike
    So this happened last night...
    I love the small Eastwood English wheel. I bought the additional lower wheels recently.
    The upper edge is still not trimmed to fit. I will tack the other two edges first and then trim it.
    Uribe, DirtyNapkin, biggeorge and 3 others like this.
  14. CURSED GEARS
    CURSED GEARS
    It never ceases to amazed me what a English wheel, and a man who knows how to use it, can produce.
    Looks great. I really enjoy this thread.
  15. swissmike
    swissmike
    Welded in. This gave me fits after I had it perfectly aligned and tacked. I started welding on two sides only and didn't noticed it had pulled away from the tacks on the third side. Anyway, had to cut some of the welds and do some in situ hammer work to get it back to align.
  16. CURSED GEARS
    CURSED GEARS
    I'm anxious to see it metal finished.
  17. adam401
    adam401
    Awesome metal work! For all the patches you have to make I gotta say I wish my new project was half that solid. Its coming out great keep the updates coming
  18. swissmike
    swissmike
    It's never going to be metal finished without primer. I want to get it blasted and primered before it starts to get humid again. I'm wiping the new patches down with Ospho to keep the rust off.
    lowcoe likes this.
  19. swissmike
    swissmike
    Thanks. It would be nice to sometime just order a repair patch from the catalog. At least with this car I'm not tempted, ha!
  20. jakespeed63
    jakespeed63
  21. Pete
    Pete
    Awesome work Mike! You make it look easy.
    Asphalt Demon likes this.
  22. swissmike
    swissmike
    After welding and grinding, I had to use the mallet and sandbag to correct the overall shape.
    There are still a few lumps, but I'll save those for later.
    Kage, koolkemp, biggeorge and 2 others like this.
  23. swissmike
    swissmike
    Same as on the other side. The lower edge had multiple splits and repairs and is replaced with new metal.
  24. alchemy
    alchemy
    Just when you think you're getting done, there's a whole other side to fix!
  25. swissmike
    swissmike
    When you post in detail and people start knocking **** off...
    Hey Kim, this will still need a p*** or two in The English wheel! Ha
  26. swissmike
    swissmike
    He fender shape is quite different when unbolted from the body and would have made it difficult to align the panel on the workbench. I tacked the panel with the fender bolted on. There is still a 1/4" overlap of the panels at this time, then take it off the car and start cutting along the edge up to the next tack, then aligning the cut portion and replace it with a permanent tack.
    The lower half has been cut and permanent tacks placed. The tacks have to be spaced far enough to allow the panels to be aligned where the permanent tacks are placed.
    Kage and jakespeed63 like this.
  27. swissmike
    swissmike
    A little crowded in the shop. I had an issue with the mechanical tach making a ruckus in the roadster lately and decided to pull it for a servicing. Of course we had the first rain day in I don't know how long. Anyway the guy who "rebuilt" the tach only did a cosmetic restoration and never bothered to even clean the lube p***age and fill it with new grease. Anyway, it's lubed, cleaned and back in the car.
    Maybe I forgot to mention next weekend is our annual Misfires Groundhog gala?
  28. X38
    X38
    Um, that doesn't look like Florida:p
  29. HayesDesign&Restlying
    Uribe likes this.
  30. lomofo1949
    lomofo1949
    from Georgia
    Haven't been on an awhile..Looking Awesome Mike!!!
    Sent from my SAMSUNG-SGH-I337 using The H.A.M.B. mobile app
