Identifying engine.
Discussion in 'The Hokey Ass Message Board' started by Sunnfjordingen, Jan 21, 2017.
  1. Sunnfjordingen
    Sunnfjordingen
    from Norway
    I bought this crate engine 6-8 years ago. It's been in storage since then but now it's going into my Nova. Was told it was a 350/290 but it can't be..[emoji853] After a week on internet I think it's a 90's truck/van engine..
    Anyone able to identify it?
    I would like to know what cam is in it and the compression ratio. It has a roller cam and mechanical fuel pump.
    IMG_1485040244.076287.jpg IMG_1485040284.329665.jpg IMG_1485040314.918964.jpg n IMG_1485040341.494614.jpg IMG_1485040367.877375.jpg IMG_1485040400.675228.jpg IMG_1485040422.394839.jpg IMG_1485040449.513372.jpg IMG_1485040473.138603.jpg IMG_1485040492.828422.jpg IMG_1485040516.539182.jpg IMG_1485040541.129658.jpg
  2. Jalopy Joker
    Jalopy Joker
    try: nastyz28.com for info on how to decipher the engine ID code info - front p***enger side - maybe is a '81 C10-1500 motor
  3. one piece rear seal and center bolt heads...i wonder if it's a ZZ3 or ZZ4?
  4. TLDLTD
    TLDLTD
    86 or 87 truck or Camaro engine according to my books. Same engine that I had in my 60 Chevy. Mine had 4 bolt mains and was out of a 3/4 ton truck originally.
    Sent from my LG-H636 using Tapatalk
  5. what was i thinking....those had aluminum heads
  6. Moriarity
    Moriarity
    SUPER MODERATOR
  7. mgtstumpy
    mgtstumpy
    Casting # 14093638 is a 1986 - 1994 350.
    Being a crate engine I gather that numbering does not match a normal production car sequencing.as UZB is a 1981 suffix code and a 165hp, 4 bolt C-10 & 1500 truck code.
    Casting # 10110810 are 1991 350 heads with 65cc chambers.
    I have a friend with a similar crate engine in his car, I should check his engine number as it's probably similar as he said it was 290hp. I'm sure someone else can decode the engine # coding, V1004UZB and determine compression ration given the chamber volume.
  8. arkiehotrods
    arkiehotrods
    block casting 14093638 was 350 '87-'95 (or '88-'94 in some sources)
    date code j030 would likely be October 3, 1990
    V stamp is Flint, 1004 would be October 4
    Sunnfjordingen and mgtstumpy like this.
  9. squirrel
    it has a 1 piece rear seal, so it's not from 1981. arkiehotrods probably has it right.
  10. Sunnfjordingen
    Sunnfjordingen
    from Norway
    Yes, I guess so. And the #810 heads are used on trucks/vans and other big vehicles?.. Was thinking TBI but it has a mechanical fuel pump....?
  11. squirrel
    the TBI engines had the hole in the block for a mechanical pump pushrod, for a few years. Then they quit drilling it.
  12. Sunnfjordingen
    Sunnfjordingen
    from Norway
    Ok, I have had a 87' 305 and a 90' 350 TBI's and they did not have the hole. Maybe some had and some not?
  13. squirrel
    I have an two 87s and a 94 right now, they all have the hole.
  14. let me ask while we are on the subject......if the block has the fuel pump pushrod hole does it also mean it has a lobe on the camshaft ? i've heard some don't
  15. Sunnfjordingen
    Sunnfjordingen
    from Norway
  16. Sunnfjordingen
    Sunnfjordingen
    from Norway
    ...and by the way it's the cam.spec. I'm interested in, maybe I should get another one before installing it.
  17. Flathead Dave
    Flathead Dave
    from So. Cal.
    This is why I like this forum from the others. No one is afraid to jump and answer a legit question. A ton of knowledge in here even if it is looking up provided numbers. This is the way to ask a question and this is the way to give an answer. Perfect pics go a long way. Good job, SUNN!
    Sunnfjordingen likes this.
  18. s55mercury66
    s55mercury66
    from SW Wyoming
    I have a 95 tbi in the garage that has the pushrod hole and the drive lobe on the cam. Not all tbi engines are like that, some are drilled for the pushrod and do not have the drive lobe, eccentric or whatever you want to call it, on the cam.
  19. Gray Ford
    Gray Ford
    from Illinois
    My '89 TBI engine has the plate & hole but no lobe on the cam.....
  20. Sunnfjordingen
    Sunnfjordingen
    from Norway
    Just checked mine and it has the "driver lobe" for the pushrod.. [emoji1303]
  21. Sunnfjordingen
    Sunnfjordingen
    from Norway
    I removed the oilpan today, trying to id. the camshaft but could not find much. Where should I look?
    The crank says: #14088526. 4 bolt main.
  22. metalman
    metalman
    I'd pull the timing gear and see if there are any markings on the cam under the gear. Most aftermarket cams I've seen have them. Just did that to my Nova, Had CC and a number, found it in a Comp Cams catalog, now I know!
  23. Sunnfjordingen
    Sunnfjordingen
    from Norway
  24. Sunnfjordingen
    Sunnfjordingen
    from Norway
  25. Sunnfjordingen
    Sunnfjordingen
    from Norway
    Well now no one knows, it ended up with a new Comp Cams roller 218/224, redone/ported Camel Humps from my old 327, old Weiand Stealth(ported to heads), underdrive pulley+++.... [emoji849][emoji38]
    kidcampbell71 and blowby like this.
