Technical homeade modal a front shock brakets
Discussion in 'Traditional Hot Rods' started by 410merc, Jan 19, 2017.
  1. 410merc
    410merc
    hello everyone , I been messing around getting ready to build some lower front shock brackets , I know I could just buy some ,but I like doing things like this , so I could use some ideas ,I'm using a 32 ford front axle and tradional steering , like I said some ideas would help , thankyou in advance
  2. dana barlow
    dana barlow
    from Miami Fla.
    front axle 32? you talk tube or H,both were used. H is like most ,I like the spring forword 48 my self best. But lower for eye/tube shocks can be very simple,just drill hole in too beam center rib,add blot an spacer,on any H type can just. If needed a offset can be added like I did so I could used a little longer shocks. This is best photo I have from the last restore I did too my own 48axle in 28A. With tube you can make"L" bracket that goes on bone bolt.
  3. texkbc
    texkbc
    I used 50's dodge truck-modified.
  4. scrap metal 48
    scrap metal 48
    Home made on "MR 800"...**clic pic for larger image** engine 001.JPG DSC_0646-vi.jpg
  5. hotrod harry
    hotrod harry
    from wisconsin
    Made my own, shock and light mounts , might redo ended up being short on travel 1485312938077.jpg
    Sent from my SM-G920R4 using The H.A.M.B. mobile app
  6. Combined shock/headlamp/indicator mount on my Modified;
