Hot Rods Started spec'ing out parts
Discussion in 'The Hokey Ass Message Board' started by Mr T body, Oct 11, 2012.
  1. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Brakes are leak tested and bled (glad I have the proportioning valve to tune them). Fabbing the fuel line for the firewall tomorrow morning, then finish welding the recess. Ordered the primer and more catalyst...... weather willing I can get the firewall painted in a couple weekends.
  2. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Firewall's done! Arrows are the welding I was a bit apprehensive about. Next is prime and paint and the weather's going to determine if I stay on schedule.
    Let me tell anyone reading this and contemplating building your own..... your brain makes it harder than it actually is. Dive in knowing you'll find a way and build the experience as you go. 90% of the battle is getting past thinking you can't do it.
  3. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    S****e, sand, s****e, sand. 86 year old paint ****s......
    loudbang and bct like this.
  4. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Just need a couple days at 70 or warmer to prime, block and paint.
  5. loudbang
    Better 86 year old paint it could be 86 year old RUST :rolleyes:
    kidcampbell71 likes this.
  6. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Not warm enough to prime and paint yet, but there's a a couple things I have to do before the body goes back on.
    Believe it or not, this has taken 3 days to make...... 2 days staring at it and a day to bend it. I made life more difficult 2 ways..... mount the fuel block on the firewall and go for a "factory" look with an inverted flair instead of AN. Didn't want hose, and sure didn't want it just hanging out there looking ugly. Couldn't drop it down the drivers side since there's no clearance for the brake pedal or the column linkage. Had to move it 3" into the tunnel to clear the bellhousing when the body's back, too. I've bent a lot of tube and though this looks rather simple, it was one of the more difficult lines I've made.
    kidcampbell71, charleyw and loudbang like this.
  7. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Slow night. When I make a line that will have hose going on it, I bead the end to help seal it (especially on the pressure side). Spent 45 minutes trying different ways of holding the line to the floor. I don't get a 2nd chance at this. The line will go on before the body goes back on the frame, so whatever retention method I decide on, it has to be from one side only. No through-bolting and since it'll be in the middle of the hump, it should be reasonably flat when the carpet is down.
    kidcampbell71 and loudbang like this.
  8. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Shifting gears a bit due to weather.
    Finished securing the fuel line in the tunnel with a rivnut so it can be serviced from one side.
    It'll be getting a new vinyl insert, but first all new top wood is in order.
  9. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    When I was a kid, they called this...resto-rod
  10. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    I just call it my idea of a hot rod.
  11. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Waiting on top wood, gl*** and warm weather so thought I'd finish up the tank/dash. Cut out the gauge depression and fitted the panel. Tack it in tomorrow night and cut out the gauge holes.
  12. Just Gary
    Just Gary
    Truth.
  13. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Looking kinda ugly, but the patch is welded in and it got a quick grind. More finishing tomorrow, but most of what I just welded in will be cut out again to mount the 3-3/8" in-dash tach and speedo.
    kidcampbell71, Just Gary and loudbang like this.
  14. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Here's where I need everyone's feedback. I'll be drilling the gauge holes in the dash, but am undecided on how to lay it out. The two in the center are in-dash 3-3/8" speedo and tach. The 2"ers on the left are spaced so they are centered over the steering column and visible through the steering wheel so I don't want to change that.
    The top view is with the gauges all on the same horizontal centerline. Having them on the same plane looks "normal", but the raised panels on the dash aren't symmetrical. That means the outermost gauges will look pinched against the dash rail.
    The middle view is with the gauges centered in the raised panels, but that means they are at a slight angle.
    Bottom is the four 2" gauges on the same horizontal centerline but below the center gauges.
    So which way looks the least odd?
    Chucky likes this.
  15. Chucky
    Chucky
    I'd do the bottom version, only slightly raised. How do you put that "bead" on your lines that will connect to rubber hose?
  16. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Earl's makes this bead tool for a variety of tube sizes
    bct, loudbang and Chucky like this.
  17. loudbang
    Add my vote for the bottom one.
  18. bct
    bct
    middle one caught my eye
  19. charleyw
    charleyw
    Bottom one
  20. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Odd how just these minor changes in placement affect the look, isn't it? Keep the input coming... I have until Wednesday night to make up my mind.
  21. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Added the dash rail to give it a bit more perspective
  22. bjinx
    bjinx
    Definitely the center layout. More pleasing to the eye IMHO.
  23. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    One of the cool thing about old cars (other than finding loose change) is discovering what happened to it in the past. Some things are obvious, some you find as you peel away the layers.
    The left rear corner of the roof was caved in and I knew I'd have to remove the wood to get it back into shape. The header was rotted, so with new wood on the way, it's the perfect time to do a little hammer and dolly work.
    Got the wood out of the header and left side and started to m***age it. With the wood out, it was obvious the corner took a decent enough hit to bend the rear bracket. With the wood out it also made it obvious the driver's door sticking had to do with the hit and the wood shifting. Nice wake up call that I will need to watch the position of the side wood to the header when tacking in the roof sheet metal. Bracket's straight and the corner's close. I will need to shrink it at some point in the future, but if I do it now it'll kill the finish. If that happens, I'm at risk of painting complete.
    Good thing I'm not in a big hurry.....
  24. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Thanks for all the responses and PM's. Finally came down to a simple thing..... I like the way the panels were pinstriped before and want to do it again. Pretty much had to do them this way to be symmetrical when it's striped.
  25. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Got wood! Started fitting up the new top wood and so far it's only needed minimal t*******. Amazing how the driver's belt line lines up and the door closes properly. Once I get everything fitted, it'll be cleared before the new top goes on.
  26. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Finally a day above 65 degrees! Got the epoxy primer/sealer down.... time to block it and see what I have to skim.
  27. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Here's the downside to waiting on parts. The original plan for the wood was after fitting to use a clear urethane on the pieces. Got some Varathane, coated 2 pieces and hated the look. That's when things went sideways (again). I stripped one piece but left the Varathane on the header (won't be seen). Starting thinking about what look I wanted for the wood and dug in the cabinet and found some old Watsco Danish wood stain. The wood has really cool grain, so stained the wood and like the furniture-ish/aged look, but want more protection, so dug around a little more and found some Spar varnish. The inside sheetmetal will be painted with Por15, so the contrast of black background and finished wood should look cool. The top brackets will go out for metallic black powdercoat this week, so I have a few days to kill waiting for that and the gl*** from Bob's.
    I try not to think about this all being covered up when I put the headliner in...
    kidcampbell71, loudbang and OFT like this.
  28. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Ordered the headliner material, so it's guaranteed the woodwork will be hidden. Regardless, I found a very cool vinyl pattern that should add a little interest to what would otherwise be a boring headliner. I can't sew, so gonna have a friend do it for me. Another thing being farmed out....
  29. jimz31
    jimz31
    from PA
    Really liking where you are going with this!
  30. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Powdercoater got the top brackets back fast! Fitting everything (again) 'cuz 4 more holes need to be drilled but it has to be in it's final position to align. The quarter window wood is being replaced but it's nice using the original to make sure everything's happy. Decided not to paint the inside with Por15 since I'll be heat shrinking the roof at some point and don't need a fire or noxious fumes. Used it on the nailing surface that'll be hidden by the top and welt and it should work great.
    kidcampbell71, OFT and loudbang like this.
