Technical Electrical question. Head light switch to guage lights
Discussion in 'The Hokey Ass Message Board' started by ChucksCrib, Jan 30, 2017.
  1. ChucksCrib
    ChucksCrib
    from Uranus
    I have a feed wire coming from my headlight switch to feed the lights in my gauges. I have 4 gauges, each with a separate wire that I need to feed. Since we dont use wire nuts in this type of application, What connectors are available to marry them all up......Searched summit, speedway and AAW and have come up blank. I probably just need the name/style of connector that would do this.
    Thanks,
    Chuck
  2. Use jumper wires from one gauge to another. The first gauge gets the wire from the headlight switch. Make sure each gauge has a good ground.
  3. ChucksCrib
    ChucksCrib
    from Uranus
    yeah.....thought about that...wondering if there was a connector which would accept all wires.
  4. Aussie A
    Aussie A
    In Australia I would use a "BP" connector that is designed for use with mains wiring. Here in the US the closest thing I found was an "ideal set screw wire connector". They come in a variety of sizes, so make sure you get the right size to fit the number of wires you want to join, or buy a range of sizes.
    You would strip and twist the wires together, then tighten the br*** set screw to clamp all the wires into the connector together. This forms a very good electrical and mechanical joint. The plastic cover then screws ver the top to provide insulation. I would then tape the whole thing anyway, starting by taping the wires together then continuing the tape tape up and over the connector.
  5. mrspeedyt
    mrspeedyt
    gauge to gauge to gauge. you don't need a connector. just wrap the bare wire around the post. and tighten the nut. cheap and easy.
  6. Gregg Pellicer
    Gregg Pellicer
    Gauge to gauge but you should use ring terminals to attach to gauge post
    Gregg
    upspirate likes this.
  7. squirrel
    If the wires are small, such as 22 AWG or similar, I would just put several of them together into the ends of a blue **** connector....maybe 3 gauges wires in one end, and one gauge wire and the wire from the headlight switch into the other end.
    or if you want to do it right, heat shrink and solder will work well
    Russ B and INVISIBLEKID like this.
  8. Hyvolt
    Hyvolt
    Since you probably don't want to mess with it again, I'd form a small harness, with a ground harness also. Solder is the only way, with heat shrink as insulation. Put insulated spades on the ends( opposite for each polarity) so if the gauge cluster has to be removed, you can disconnect quickly without the h***le of cutting and re wiring.
  9. ChucksCrib
    ChucksCrib
    from Uranus
    Thanks for the insight.....wire nuts it is
    belair likes this.
  10. ChucksCrib
    ChucksCrib
    from Uranus
  11. wutnxt
    wutnxt
    Greg Pellicer's response is good
  12. deathrowdave
    deathrowdave
    from NKy
    Ok , I guess call the local union hall for a couple IBEW workers they should be able to install wire nuts correctly ! Why ? Solder and heat shrink and don't look back
  13. You should become familiar with crimp connectors and shrink tube. I suggest buying a crimp tool and a selection of terminals ... and a heat gun and selection of shrink tube. Anyone working with automotive wiring should have this expertise, it's easily learned and well worth knowing.
    Crimp connectors are available in several styles which include push-on-disconnect which should work well for this application. The heat gun activated shrink tube allows a professional look as well as protecting the wires against abuse.
    Not expensive.
    i.rant and Cosmo49 like this.
  14. ChucksCrib
    ChucksCrib
    from Uranus
    Guys....I was kidding........did you miss the ":p". I wired the rest of the car myself using crimp connectors with a crimp tool.....geeez:rolleyes:
  15. Sporty45
    Sporty45
    These connectors work well, too. Similar to wire nuts, but crimp on
    belair and squirrel like this.
  16. squirrel
    Yeah, those connectors work too....although when you need to connect 5 wires together, they usually don't all fit. A **** connector gives you twice as much room for wires.
  17. BJR
    BJR
    Just don't google "**** connector"!:p
    Sporty45 and squirrel like this.
  18. 56shoebox
    56shoebox
  19. d2_willys
    d2_willys
    from Kansas
  20. belair
    belair
    If you ever need proof of entropy, most threads on the HAMB (**** connector) are proof it exists. You guys are crazy fun.
  21. Cosmo50
    Cosmo50
    I like to use these blocks when I need to do multiple connections. They are very versatile.
    Sporty45 likes this.
  22. Atwater Mike
    Atwater Mike
    Ring connectors a size designation of 14 ga. Use 18 ga. wire to form a 'Daisy Chain'. Power source to first gauge ring connector, insert power wire and next wire into connector and crimp. Next gauge do the same.
    There was a song, I think...
    "Daisy chain... DAISY CHAIN... Daisy chain for you and me..... Dope heads sang it in the '60s.
  23. I didn't miss the ":p" but have no idea what those cartoons mean. Sorry if I gave you an ulcer, but I only know English words and not many of them either.
