I need to remove the driveshaft/torque tube from my '37 Ford rearend.... The rear axle/drive ***embly is already out of the car... Is there more involved than just removing the (tube to rear housing) bolts? The radius rods have been removed... and I have removed the bolts...but the torque tube only moves away from the housing about 1/2".... Not forcing or prying anything till I can find a definitive answer..... I have searched, but nothing found. Any help appreciated...
There is a seal,snap ring bearing and speedo drive on the front (transmission) end.Pull all that stuff out and the tube should slide off w/o too much effort
Excellent... once the tube is off....is there a pin or clip to release the driveshaft from the rear? Thanks
