Projects Not Your Average Coupe Build: ‘37 Chevy Unearthed
Discussion in 'Traditional Customs' started by oneratfink57, Jan 31, 2017.
  1. 38Chevy454
    38Chevy454
    Lot of potential there, and a lot of work! 37-38 Chevy coupes make great customs and hot rods, either way the end results are nice.
    oneratfink57 likes this.
  2. jvpolvere1
    jvpolvere1
    I owned two 40 Chevrolet coupes. Ten years ago I was searching for a body to put on a cherry frame that was under a Car Craft cover car. That's how my build began. I landed up bidding on two bodies and scored both.
    One was a pristine, original body that was in a ba*****t in Connecticut for 27 years.
    The second was modified, new firewall, floors and Nova clip along with receipts for 11k to a hot rod shop in Rhode Island. Real questionable work, but I bought it right.
    So here I am with two bodies, side by side. Took a tape measure to both. Differences were between1/8 to 3/8". I guess they did not adequately brace the car before cutting out the floors and firewall.
    Moral of the story. If you can find an original car and the owner let's you measure, it may be time we'll spent, especially if you source new doors down the road.
    But don't listen to me. I am slower than a turtle. Still have both cars. LOL.
    Sent from my SM-T377V using The H.A.M.B. mobile app
    kidcampbell71, brEad and oneratfink57 like this.
  3. brigrat
    brigrat
    from Wa.St.
    The '37 Chevy Coupe is to Chevy lover's what the '36 Ford Coupe is to Ford lovers, IMHO..................................................
    LTM75110, TagMan and oneratfink57 like this.
  4. oneratfink57
    oneratfink57
    from Wisconsin
    Well said!
  5. rusty1
    rusty1
    ...those hood side louvers are still upside down!...dang.
  6. oneratfink57
    oneratfink57
    from Wisconsin
    I'll surely be messing around with that once the cars back together
    brEad likes this.
  7. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I bought extra hoods and pieces to do the vent flip. But, the more I looked at it, the more I came to believe that the original was not the famous 'mistake' that has been sited many times before.
    Flipping them side to side does situate the louvers in a more traditional orientation. But then the feature line is at the top and does not mimic the side of the doors.
    They look good either way, but I'm not sure it was a 'mistake'. The factory slant of the louvers picks up the angle of the windshield post.
    Will be watching. I may do something a little different with my spare hood and parts. If so, I'll post it.
  8. 1blown57
    1blown57
    from Florida
    Great Work.
  9. 1blown57
    1blown57
    from Florida
    I found some parts you forgot in little Rho IMG_0180.JPG dy. I will mail them to you !;):cool:
    kidcampbell71 likes this.
  10. 1blown57
    1blown57
    from Florida
    nice score ! Bet Guys a swap meet gave you funny looks walking away with that.. I found the clock !
  11. TFoch
    TFoch
    37 Chevy, one of my favorite years! Looking forward to watching your build. Probably past by you at some point at the Amherst Flea Market. Loved going there hunting for deals!
    tb33anda3rd and oneratfink57 like this.
  12. raymay
    raymay
    Much of the design work on the 37 Chevy belonged to GM designer Jules Agromonte. The head of the design group back then was the legendary Harley Earl who's designs were very much non-traditional and usually way ahead of their time. The hood lines flow nicely from front to back complimenting the new body line that fades into the door. The redesign in 37 was introduced by Earl as "Diamond Crown Speed Line Styling". I think the end result was one of the nicest looking car designs to come out in the 1930's.
    Paul B and oneratfink57 like this.
  13. oneratfink57
    oneratfink57
    from Wisconsin
    Looking forward to seeing what you come up with!
    I think Keith's looks so good is because by dropping the headlights and the louvers you break them away from needing to match up with the body lines.
    I'm a ways away from messing with the details but I'll be looking for some guidance when it comes to those touches
  14. oneratfink57
    oneratfink57
    from Wisconsin
  15. oneratfink57
    oneratfink57
    from Wisconsin
    Made some more progress this afternoon. Turns out the bottom of the drivers door opening spread open about 3/4" past what it should be during transport. Before I made too much progress on the floor I pulled the geometry back to where it should be with a ratchet strap accross the two cross supports. Then tacked in a door opening support of the correct length
  16. oneratfink57
    oneratfink57
    from Wisconsin
    Now that the coupe was relatively square again. I started to work on planning the floor. I realized the 4 corners of the body where the the floor would essentially attach to the body was roached.
    So I pulled out the fabrication station and started making some panels. Since most of the steel was gone, some guesswork was involved
    Started the fab process again by planning the panel with masking paper.
    I used to let my daughter write on my coke cooler welder cart with paint marker, then I'd prime over it so she could start over. I don't think I'll ever prime over it again though. Memories!
    Chose the closest set of bead roller dies I could
    Then formed the offset needed to connect the panel to the rear quarter
    It's not perfect, but fits like a glove!
  17. oneratfink57
    oneratfink57
    from Wisconsin
    Then fabbed the drivers front Seen below
    P***enger front panel
    P***enger rear panel
  18. oneratfink57
    oneratfink57
    from Wisconsin
    The last step of the day was to weld some "new" angle iron where the original angles were.
    For those of you 37 guys out there. What the heck are the angles for? Are they gas tank brackets? It's my understanding the gas tank is behind the drivers seat in coupes
  19. oneratfink57
    oneratfink57
    from Wisconsin
    Now to reveal my floor plan!
    My daughter helped me sketch out the plans on her little white board
    I plan to weld a square tube frame shown in brown that welds to the four corner panels I made today. Then I'll continue the frame over the rear axle and into the trunk.
    Once the frame is done, I can start fabbing floor panels to weld them to.
    I'm planning to drill holes and weld threaded inserts or just pipe for the bolts to p*** through for the body mounts and the seat mounts.
    pivir123, Tim, kidcampbell71 and 5 others like this.
  20. oneratfink57
    oneratfink57
    from Wisconsin
    Forgot to post this little gem that my dad hooked me up with. 41 Cadillac front bumper. Planning to use it as the rear bumper on the 37
  21. Leakie
    Leakie
    Nice work , looks like an ambitious project!
    Not sure if those angle brackets are for the tank, I never had a coupe, but my 37 sedan does not have them. The tank is underneath in the sedan. You are probably right, hopefully a coupe expert will chime in. If not PM Raymay, he has had a bunch of 37s and is a very helpful knowledgeable guy.
  22. rusty1
    rusty1
    ..that angle was used to lay the plywood floor cover over the gas tank. The tank sat on these 2 wood supports shown in this pic, a piece of wood stood up along the front of the tank supported the plywood also.
    kidcampbell71 and oneratfink57 like this.
  23. oneratfink57
    oneratfink57
    from Wisconsin
    Thanks for the info and pic! I made sure to save that one. Not too many 37's floating around to reference. Especially this time of year in Wisconsin lol
  24. oneratfink57
    oneratfink57
    from Wisconsin
    Actually if you have any other pictures of the factory floor (and trunk floor) that would be appreciated!
  25. leadfootloon
    leadfootloon
    Haha not here most the stuff you buy around here is like that.
  26. rusty1
    rusty1
  27. oneratfink57
    oneratfink57
    from Wisconsin
    Thanks for the pictures rusty1! They will certainly come in handy
  28. chopolds
    chopolds
    from howell, nj
    Looking good, can't wait to see more!
  29. oneratfink57
    oneratfink57
    from Wisconsin
    I was able to get the outer most portion of the floor structure done today, but I ended up running out of square tube so I didn't get a whole lot of progress.
    For the couple of bends I needed, I went with the notch and weld method
    Below is where it mounts to the new patch panels I made last weekend up front.
    To give the main rear mounting points a little more support. I welded some vertical square tube up to the gas tank cover angle iron
    Once I get some more square tube, I should be able to complete the floor structure in just a couple of hours
  30. oneratfink57
    oneratfink57
    from Wisconsin
    Another Sunday in the books!
    I ended up raising the floor 2-1/2", but the body will only be dropped half that because of the tube structure.
    So at the end of the day the coupes got a 3" chop and a 1-1/4" channel.
    Got my square tube on Friday and was able to finish up the p***enger compartment floor structure this afternoon. Welded 3/4 of the way around. I'll wait to do the overhead welding for a rainy day
    Then I moved on to the driveshaft tunnel so I can tie the two halves together.
    I had this old empty oxy bottle my dad gave me, and I planned the floor dimensions around the 3.5" radius to form the tunnel
    Formed the radius
    Formed the legs
    I bought a cheap planishing hammer at northern tool that I'll use to smooth out the imperfections. Once I cut the legs down to the 1-1/4" length of the tube, I'm going to chase the perimeter with the bead roller to add a little rigidity
    tb33anda3rd, brEad, mgtstumpy and 5 others like this.
