Technical Windshield measurements for chopped '54 Vicky
Discussion in 'Traditional Customs' started by Dixiesickboy, Feb 2, 2017.
  1. Dixiesickboy
    Dixiesickboy
    My club and I have chopped my '54 Vicky 3" and I'm wondering the best way to measure the windshield opening for custom gl***. Really want to get those measurements correct!
    Also, anyone know of a thread on "cutting" down windshield gl*** for a chopped car?
    I'll do it myself if it's not too risky but I may just order custom gl***. [​IMG]
    leadsled likes this.
  2. 302GMC
    302GMC
    from Idaho
    What you do, is you cut the gl***. Then, cut the car to match.
  3. BJR
    BJR
    As said, you did it *** backwards. You can't bend gl***, so you cut the gl*** and make the frame fit it, not the other way around. There are lots of chopped 50's cars unfinished, knocking around without windshields for that very reason. When it came time to cut the gl*** it didn't fit cuz the curve was off after taking the cut off of the top. With that said best of luck and hope you can get it finished.
  4. voodookustoms
    voodookustoms
    Look up Bernies custom gl***. If he's not local to you, he might be able to answer some questions.
    Dixiesickboy likes this.
  5. Dixiesickboy
    Dixiesickboy
    That would have been a great idea, except that I broke my old gl*** and my "new" roof is from a Lincoln (wider). So we're gonna have to reverse engineer a bit.
    RICH B and 302GMC like this.
  6. coupe33
    coupe33
    where would anyone get gl*** this way? Could a fibergl*** templant be made and have the gl*** made to the template? A few years ago I saw someone advertising can't remember where
  7. Chaz
    Chaz
    I'm working on a very similar situation. I don't have all the necessary info yet, but here's what I do know.
    There were two windshields on 52-54 models. A tall one 17 1/4 in tall, and a short one 15 9/16 tall.
    I'm not sure yet how much room the gasket takes up, but I've ordered one to check it out. Everything depends on how much room the gasket takes, and how flexible it is. If you're lucky, the short gl*** may fit your opening. If you are not lucky, start cutting some old laminated gl*** for practice. You'll need it!
  8. leadsled
    leadsled
    15 9/16 is real close to what you have. Bonnie Blue nice!
  9. 53Dave
    53Dave
    This. I learned that the hard way on my first chop. Had to cut the freshly painted car apart and make things work.
    For patterns, I use a thin cardboard, like cereal box type cardboard. Get it in big sheets from work.
    For cutting the gl***, I use a sandblaster with black slag media (coal slag maybe). Tape off cut with duct tape (couple of layers). When it's cut, take a 3" sanding disc and smooth things out as needed.
  10. Dixiesickboy
    Dixiesickboy
    Thanks 53Dave. Good advice. I'll be making a template soon.
  11. Dixiesickboy
    Dixiesickboy
    Thanks Chaz. We measured the opening yesterday (around 13") and it seems clear that the shorter windshield would be the one to get. The great thing is that there isn't much curve in a '54 Vicky windshield at all.
  12. fatty mcguire
    fatty mcguire
    good luck hope it goes well had a couple chopped 52-54 ford.mercs, personally I think the lincoln roof is more work than its worth, but will look good just looks similar to the stock roof, would love to do a 55/56 ford like the that crushed
  13. wbrw32
    wbrw32
    Be sure to come back and tell us your backwards engineering experiences..
