Projects 5wKy33: another coupe build thread
Discussion in 'Traditional Hot Rods' started by ls1yj, Jan 15, 2017.
  1. ls1yj
    ls1yj
    from Kentucky
    What is most folks' preferred method to conceal wiring in frame from front crossmember to behind firewall? Drilled hole w grommet? Small plate w fitting?
  2. alchemy
    alchemy
    How are you going to protect the wiring from bouncing around inside the rail, s****ing against those standoff plates, the pointy side of bolts, and the backside of weld beads?
    My preferred method is to NOT make things harder to get at and fix.
    Stogy likes this.
  3. ls1yj
    ls1yj
    from Kentucky
    Alchemy,
    I figured I'd only have to run headlight wires, and I'd make a small bundle, and shrink wrap. The small plates are beltsanded and deburred, but the pack would still have a tendency to bounce a little. I suppose I could run them down outside, in box plate corner...
  4. ls1yj
    ls1yj
    from Kentucky
    Stogy likes this.
  5. Kan Kustom
    Kan Kustom
    I'm liking it !
    ls1yj likes this.
  6. 383deuce
    383deuce
    I like the direction you are going with this.....So I signed up for the ride with ya.
    ls1yj likes this.
  7. ls1yj
    ls1yj
    from Kentucky
    Thanks guys... it's kind of a long story on the direction I'm taking on ch***is, especially since you won't see much of it later once it's covered up... but I've always wanted to do one this way
  8. ls1yj
    ls1yj
    from Kentucky
    I got the corner welded, and trimmed out... 1st plate is fitting pretty decent. Also tacked the cups in rear DS plate [​IMG]
    Stogy likes this.
  9. thirtytwo
    thirtytwo
    Street rod shops I have worked in make a tube on inside of boxing plate and weld the inlet under car somewhere and the outlet by the front crossmember
    Stogy and golferforpar like this.
  10. fuel10922
    fuel10922
    Looking good.....its about time!
    ls1yj likes this.
  11. ls1yj
    ls1yj
    from Kentucky
    Hahaha yeah yeah I know... we are rolling now... just gonna pick away a bit at a time
  12. ls1yj
    ls1yj
    from Kentucky
    Gonna pull a 33 front cross member out today, to mock front box plates around. [​IMG]
    Stogy likes this.
  13. ls1yj
    ls1yj
    from Kentucky
    Stogy likes this.
  14. ls1yj
    ls1yj
    from Kentucky
    Stogy and hipster like this.
  15. Itchy-Pit
    Itchy-Pit
    Watching with great interest. I like the dimpled box rail. Never seen or thought of such detail.
  16. 1-SHOT
    1-SHOT
    from Denton
    I am a long for the ride. Frank
    ls1yj likes this.
  17. ls1yj
    ls1yj
    from Kentucky
    hipster likes this.
  18. vtwhead
    vtwhead
    looks good, I am following along now. What part of KY are you in. My son is building an A in Lexington.
    ls1yj likes this.
  19. ls1yj
    ls1yj
    from Kentucky
  20. How far down from the top of the rails is the top of the crossmember middle section(center pin)?
  21. rpm56
    rpm56
    Very nice project. Instead of permanently welding the spacers, couldn't you attach a welding rod to one or two and pull it towards the end of the boxing plate as you weld outwards. With the cups the spacer would need to straddle them top and bottom to pull them along. Just a thought.
  22. ls1yj
    ls1yj
    from Kentucky
    I'm out of town for work. I'll check later this week and holler back
  23. flamedabone
    flamedabone
    Why are you going to rechop it? I dig the heavy chop, and the Caddie, and the quickie.
    Keep at it, -Abone.
    ls1yj likes this.
  24. el Roach
    el Roach
    What a great project! Can't wait to see the finish product!
  25. ls1yj
    ls1yj
    from Kentucky
    Abone,
    I wanted some lean on A pillars, and a little rake to the roof... it's decent now, but never suited me when Dad and his buddy did it long time ago
  26. ls1yj
    ls1yj
    from Kentucky
    I checked from top of frame down to top of front member= 3.060"
  27. milkweed
    milkweed
    from SLC UT
    When i want to hide wires in a boxed frame i weld in a piece of conduit that hides under the body and comes out under or right by the headlight stand...Hell sometimes i put conduit in the inner structure of my bodies cause i hate seeing wiring...
    kiwijeff, ls1yj and birdog like this.
  28. ls1yj
    ls1yj
    from Kentucky
    Thanks for tips, Milkweed, and others
  29. Thanks. Will jot it down on my drawing in the garage.
  30. ls1yj
    ls1yj
    from Kentucky
    Doin a little grinding and welding today...it's slow goin, but at least I'm goin...:)
    Stogy and brEad like this.
