32 Ford Experts (Early Vin)
Discussion in 'The Hokey Ass Message Board' started by IronFord, Jul 4, 2013.
  1. IronFord
    IronFord
    from NoDak
    I just lifted the body on my 32 Ford tudor, and found that the Vin number begins with AB******x. I thought that all the four cylinder cars began with B and the V8's began with 18. Is this an early 32? I can read the number on the back of the block and I thought it began with a B but upon closer inspection it begins with an AB. The engine number and the frame number match. Any thoughts?
    LOU WELLS, biggeorge and mgtstumpy like this.
  2. F&J
    F&J
    It's correct as is....now back to work :)
  3. HOTRODPRIMER
    HOTRODPRIMER
    The "A" was dropped from the prefix in April and at that time all 4 cylinders serial numbers had 7 digits,,all beginning with 5.
    BTW,,the car has a early model 14 front bumper.HRP
    LOU WELLS likes this.
  4. mickeyc
    mickeyc
    I think perhaps that you have opposite. The 4 cylinder cars began with an 18 and the v/8 cars began with 5's? I did look this information up
    when I recently bought a 32 ch***is with ***le. I may be mistaken.
  5. HOTRODPRIMER
    HOTRODPRIMER
    I NEVER PROFESSED TO BE A EXPERT.
    The early production of the 4 cylinder engines which begin in November 1931 and the prefixes were AB,ABB,ABF and ABBF,,this was dependent on the particular application,,commercial,p***enger car,RHD or LHD. HRP
  6. Fortyfordguy
    Fortyfordguy
    32 numbers in the USA were prefixed with 18- if the car had the V8 and either the B- or the AB- if it had the B four cyl motor.
    lurker mick likes this.
  7. IronFord
    IronFord
    from NoDak
  8. And I believe the letter C before both V8 and 4cyl pre fixes when the cars were made in Canada
  9. uncle buck
    uncle buck
    :confused: Do I sense a little sarcasm here? :rolleyes:
  10. Roger Roadster
    Roger Roadster
    I have a January built 4 cylinder the frame Is AB50019(**) And the engine is 50019(**)
  11. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    image.jpeg I have a 32 cabriolet(roll up windows with a convertible top) vin originally was F18****.I was told by those "in the know" that F meant rt hand drive,18 means v8,and the remaining 4 digits suggest it is a very early built car(possibly mar-April of 1932)
  12. deucendude
    deucendude
    from norcal
    Vanpelt is right Early 4 bangers were AB , soon they dropped the A.
  13. 2deuces64
    2deuces64
    AB numbers were used from Nov 1931 starting with 5,000,000 to April 1932 ending in 5,062386. All numbers after April are B numbers.
  14. Bruce Lancaster
    Bruce Lancaster
    An oddity is that since the B had none of the production problems the new V8 had, they went right into manufacture as soon as Ford began finalizing the manufacturing system for complete cars. A large number of B engines were built and warehoused in anticipation of startup. Then Henry decided that no fours would be built until some V8's were ready to go to the line.
    The end result is that while you can spot an early B, you can't tell how early the car might be because the engines came out of the stockpile in whatever order they were grabbed. Usable V8s from the first runs were rare ( lots had to be s****ped before casting procedures were worked out) and any that survived run in went immediately into a car. By the middle or so of the model year, V8 production was under control and most cars were built as 8's, with B production falling off toward nothing.
    The 5,000,000 starting number was because the B was considered to be a continuation of the Model A engine family and a continuation of that serial number series. That was a generous rounding off of the nearly 5 million last A cars, leaving room for serials for the many A engines and A or AA vehicles still being built in Europe and the A engines still in production here for industrial users, replacement engines, etc.
  15. cjsavage
    cjsavage
    from eastern nc
    Anyone ever seen or heard of a 32 frame with (star)174***(star) stamped in the normal places?
  16. Bruce Lancaster
    Bruce Lancaster
    I was normal for ONE in Ford 1932 serials...any 6 or 9 should have a spine with no curve. A number between 1 and a little over 200,000 (is yours 174,**X, which would fit that) would be a proper '32 221 number.
    Since the main number with the 18 would have been on the transmission, it was not unheard of for the frame to carry just the serial with no prefix. The stampings farther back on the frame were apparently always just the numerals.
    Since the B was above 5,000,000 and V8 was between one and a bit over 200,000 there's no question what the frame would have carried. This # isn't a problem at all as far as I'm concerned, but you mileage may vary with the DMV!
  17. cjsavage
    cjsavage
    from eastern nc
    Thanks for the reply, Bruce. Sounds like it is an early V8 car? It is a 3 window, originally with a rumble seat. There is a six, it has a straight spine, almost like a lower case 'b'. The numbers are irregular, not stamped squarely, out of alignment, almost running off the outer edge of the rail. I'm guessing hand stamped in a hurry. IIRC the front crossmember had motor mount holes. I know the V8 had mounts on the water pumps. Did the 4 cylinder have a different crossmember?
  18. The four and eight used the same crossmember but there was an early and a late crossmember (and maybe a few more).
    Charlie Stephens
  19. Corn Fed
    Corn Fed
    Since we're talking decoding stuff here, look at the body floor cross channel that the front of the seat would bolt to. In the middle or towards the driver side you should be able to find a stamping. It should have a letter or two followed by some numbers. The letters signify the manufacturing plant and the numbers are the number of that body style created. So if you had a tudor sedan with a "R4556" that would be the Rouge plant and the 4556th Tudor body made there. My 32 Coupe and 32 Truck are TC (Twin Cities MN) and my older bro has a 32 Tudor with DM (Des Moines).
  20. cjsavage
    cjsavage
    from eastern nc
    Unfortunately, the original floor and cross channels are long gone. When I found the car in 1969, it had been channeled over the frame by hacking out the floor and bolting the subrails to the bottom of the frame. The car had not been completed in this state and was setting with the subrails in the dirt for who knows how long, allowing the lower few inches of the body to slowly rust away. The front and rear rails had been torch bobbed.
  21. hotrodA
    hotrodA
    Here's mine. Jacksonville, #1117 Tudor
    (Coincidently the place and birthdate of my son!)
  22. Corn Fed
    Corn Fed
  23. jbussell
    jbussell
  24. jbussell
    jbussell
  25. jbussell
    jbussell
  26. jbussell
    jbussell
    Frame and trans match . Any one that can decode a Murray tag ? My car is a 190 that's a Vicky but is the next set just production?
  27. jbussell
    jbussell
  28. alchemy
    alchemy
    The next number on the tag is the number of vicky body built. Does it say it's the 140th (hard to read)?
    Your V8 is really early. I have a frame from a V8 in the 5,000 range.
    biggeorge likes this.
  29. jbussell
    jbussell
    It says 1140 .. so that's the production number.[emoji106]
