Projects Insane 58 Chevy (build)
Discussion in 'The Hokey Ass Message Board' started by Insane 1, Dec 8, 2008.
  1. RaginPin3Appl3
    RaginPin3Appl3
    yeah it's weird there is a general lack of 58 sheet metal. you can't get full quarters either
  2. Insane 1
    Insane 1
    from Ennis TX
    Agreed, If not for the fact that I had access to, two parts cars I would not have even attempted this.
  3. RaginPin3Appl3
    RaginPin3Appl3
  4. Insane 1
    Insane 1
    from Ennis TX
    Thanks, might be a good source for parts.
    I believe I've made up my mind to put a 64 full floor pan, and braces in. My plan all along was to run a set of 63/64 buckets with console, and by running the 64 pan the seats should bolt in as factory?
    From what I can tell the 64 pan should go in with out much issue.... If anyone has done this I'd like to hear from you.
    koolkemp likes this.
  5. junkyardjeff
    junkyardjeff
    It has basicly the same frame so it should not be that bad to put the 64 floors in.
  6. Vintage Amercian Iron
    Just read through this thread, great work!!! Tagging along to see what is next...
  7. RaginPin3Appl3
    RaginPin3Appl3
  8. Insane 1
    Insane 1
    from Ennis TX
    Ok decided that no one knows how 64 floors are going to fit into a 58, so there is only one way to find out..... so here I go!
    Bought the 2 piece since I figured I would have to make some mods, or build a new trans tunnel for the Ford trans anyway, but to my surprise the trans looks to clear for the most part. Just laying the floors in it's not too far off other that the toe board, but I knew that going in. so with a bit of t******* got that out of the way. Still going to have to nip and tuck, here and there but they will work.
    Will have to use the 64 bracing which I figured would be the case, but it actually will work better than the 58 as it gives more clearance over the tail of the ******. So for now the floors are laying in place till I get the bracing. Will follow up soon......
  9. RaginPin3Appl3
    RaginPin3Appl3
    Wow that actually fits a lot better than i thought it would. I guess i always figured that the 58 was a lot narrower inside than the 59-64.
  10. ffr1222k
    ffr1222k
    It is good to see you are back on this project. Your engine and transmission put this build over the top.
    That is really thinking outside the box.
  11. 62hotcat
    62hotcat
    Its only metal. Cut grind weld. Awesome job BTW.
  12. Insane 1
    Insane 1
    from Ennis TX
    Thanks, guys..... agree it's only cut and weld.... just a lot of welding so far......
  13. Insane 1
    Insane 1
    from Ennis TX
    The 64 front x-member came in so got it installed, had the move the two mounts, but not a bad fit otherwise. Got both floors welded in today, still have a little to do at the toe boards. DSC_6067.JPG
  14. Insane 1
    Insane 1
    from Ennis TX
    Also got the rear quarter completely striped and the first coat of prime on...starting to look like a car..
  15. Vintage Amercian Iron
    That is some very creative thinking and nice work, good job!!
  16. Harland grunder
    Harland grunder
    Looks like a hardtop to me.
  17. Insane 1
    Insane 1
    from Ennis TX
    Thanks.
    Got the 64 shifter mounted today and built a new linkage rod to connect to the Ford trans. The console is just sitting in place.
  18. phat rat
    phat rat
    It's a 2dr sedan not a hardtop. Look at the first two pictures on post #1
  19. Squablow
    Squablow
    I love this build because of the huge level of commitment, really shows what can be done when a builder is willing to put in the work, and very nice looking work at that.
  20. push_rod
    push_rod
    I used to work wth a guy who claimed he had a 1958 Chevy Tudor Wagon "Yeoman"? He bailed on the project because it was too rusty. He said he did some research and found that in 1958 GM experimented with a new type of rust proofing... IT DIDN'T WORK!!!
  21. 1lowbuckrodder
    1lowbuckrodder
  22. Insane 1
    Insane 1
    from Ennis TX
    To be honest it was too rusty for a car that really isn't that desirable for a practical restoration, or even something to just throw together, but I figured I could put it on the back burner, and whittle away at it a little here and there over time it wouldn't be that bad, but at this point I need some room in the shop, so I will put a little more heat under it at this time.
  23. Insane 1
    Insane 1
    from Ennis TX
    Been busy, but here are a few random pics to show what has happened lately.... As of right now it is blown apart to get final clean up underneath, fame is headed to powdercoat, and engine is about to get torn down....still aways to go, but getting closer... kinda thinking outside the box on this one, so bare with me till it's done, before p***ing final judgement.....also if you want to see daily pics follow Insane Designs on Instagram...
    20170516_211450.jpg 20170519_202824.jpg 20170531_165940.jpg 20170529_234657.jpg 20170603_152233.jpg 20170609_015029.jpg 20170611_165527.jpg 20170617_020606.jpg 20170618_210540.jpg 20170619_204915.jpg
    jhughes76 likes this.
  24. BJR
    BJR
    Get some fake Olds valve covers to go with the fake paint and you will have a real fake car!
  25. RaginPin3Appl3
    RaginPin3Appl3
    Looking good! I'm still very impressed at what you're doing!
  26. Insane 1
    Insane 1
    from Ennis TX
    LOL..... no thanks... I'll run real Ford valve covers....
  27. 65pacecar
    65pacecar
    from KY, AZ
    Nice work, can't wait to see it finished. A 392 Hemi would be fun in there.
