Hot Rods Aluminum Surfer Scoop!!
Discussion in 'The Hokey Ass Message Board' started by oldguard, Feb 6, 2017.
  1. laneracing
    laneracing
    I have see smaller ones but they here for one carb I might be able to cut one down before i weld one together if that would help. What were you thinking. Thanks Greg 319-310-4155
  2. laneracing
    laneracing
    Thanks Dave please share and p*** the word Greg
  3. mad mikey
    mad mikey
    I saw these scoops on EBay , they are very nice looking. Any other sizes ?
    lothiandon1940 likes this.
  4. mad mikey
    mad mikey
    Around 17 inch long for single blower carb, would work well on my coupe-see avatar.
  5. laneracing
    laneracing
    I have sever sets of older original M/T aluminum valve cover in satin and i have one pair of older Edelbrocks both for small block Chevy Maybe i could offer them in a package deal with the scoop $100.00 extra and there ready to dolt on Let me know Greg 319-310-14155
  6. El Hueso
    El Hueso
  7. mad mikey
    mad mikey
    ^^That is the surfers scoop^^
    Just Gary and lothiandon1940 like this.
  8. I think these scoops are awesome, I will post a pic of mine when we get it cut for the Dominators.
  9. lothiandon1940
    lothiandon1940
  10. mad mikey
    mad mikey
    Thanks Don.:)
  11. Chad Christensen
    Chad Christensen
    Hello! I own the foundry which has produced the castings for these surfer scoops. Greg sold the patterns to a couple gentlemen who, from what it sounds like, have ceased doing business and have the original patterns. Greg reached out to me recently to see if I had any extra castings laying around, but unfortunately, I do not. If you or anyone you know of has one you would consider selling back to Greg, he'd like to get one for his collection. You can call Greg at his number or you can call me at my foundry, Kloppenborg Foundry & Fan Co. in Davenport, IA. 563-322-0260 office or my cell# 309-721-5281.
    We've also replicated other antique car parts in aluminum, br*** and bronze, all sand cast. Hope we can find some scoops!
    Ned Ludd and 31Vicky with a hemi like this.
  12. lake_harley
    lake_harley
    I wanted a fibergl*** "surfer-style" scoop for the SBC powered FED I'm building. I saw the prices for scoops (aluminum and f-gl***) and thought I could probably do one for a lot less $$. I bought some epoxy fibergl*** resin and hardener, a friend had the f-gl*** cloth and expertise with fibergl***, and I made a shaped foam buck to gl*** over. Well, after hours and hours of fiddling around with every step of the process and then fabricating an adapter to transition from the carb to to the gl*** scoop I wish I had just spent the money to buy a scoop. I still have scabs on the back of my hand from digging and sanding the foam out of the inside of the scoop, but at least I have a scoop that has a nice shape and is of the physical size I wanted.
    Lynn
    quick85, swade41, Tman and 1 other person like this.
  13. A little acetone or gas usually disappears foam like magic
    egads likes this.
  14. lake_harley
    lake_harley
    Now you tell me! o_O I suspected something would dissolve it and let it be wiped out, but didn't want to take any chances of messing up after all of the effort. Live and learn I suppose.
    Lynn
  15. I will vouch for Chad, Kloppenborg has cast several parts for me and the work is top notch.
  16. I would have told you before But you didn’t ask then,,
    Budget36, 427 sleeper and lake_harley like this.
  17. swade41
    swade41
    from Buffalo,NY
    I had an original single four from the 60's then remade the lower half of mine to fit 2 bigger air cleaners and to sit right where I wanted it (like a shaker) on my 41, I ended up using printer paper as a form. Still a pain in the *** ! FB_IMG_1507746487427.jpg FB_IMG_1507746496236.jpg FB_IMG_1507746503367.jpg FB_IMG_1507746509030.jpg FB_IMG_1507746516164.jpg FB_IMG_1507746522907.jpg FB_IMG_1507746538719.jpg FB_IMG_1609691528822.jpg FB_IMG_1609691537377.jpg
    High test 63, catdad49, brEad and 8 others like this.
  18. Max Gearhead
    Max Gearhead
    from Wisconsin
  19. dreracecar
    dreracecar
    from so-cal
    This IS the "ORIGINAL SURFERS SCOOP" pattern. The guy holding it is Tom Jobe. and it has never left Calif. Since Toms p***ing it is now held in trust with the guy on the left Bob Higginsen. Any aluminum Surfer scoop out there now is a counterfeit/copy made off a original casting[​IMG]
  20. mad mikey
    mad mikey
    Yes sir. Was casted specifically for the Surfers, by a guy named Baily. He made several for them because some times the blower was sent into orbit.
    Just Gary likes this.
  21. Mike Rouse
    Mike Rouse
    I made a proto type from one piece of .060 aluminum sheet
    2OLD2FAST likes this.
  22. Bitchin' Scoops
    Bitchin' Scoops
    Chad, we purchased the company from Greg. We never stopped manufacturing the scoop. We put a TON of work into evolving the scoop. Making it a one-piece casting, symmetrical, and consistent thickness throughout. We enjoyed working with you, but moving the business to TN, we had to move to a foundry much closer to us.
    Check out our website for images of the new one-piece!
    *****inscoops.com
    drdave likes this.
  23. DDDenny
    Chad has been MIA for three years.
  24. Bitchin' Scoops
    Bitchin' Scoops
    When you search our brand on Google these threads still come up towards the top. Just updating the thread info about our brand and product. We weren't active on this forum previously, but we will be now!
  25. deathrowdave
    deathrowdave
    from NKy
    As good as it gets
  26. DDDenny
    An Alliance Membership could benefit you.
    gimpyshotrods and mad mikey like this.
  27. Bitchin' Scoops
    Bitchin' Scoops
    Thanks! I will look into it.
  28. Max Gearhead
    Max Gearhead
    from Wisconsin
