Technical Mystery 327 what is it?
Discussion in 'The Hokey Ass Message Board' started by henryj1951, Feb 15, 2017.
  1. henryj1951
    henryj1951
    from USA
    Hint ,
    Aluminum retainers in/on a stock never been taken apart 327
    picture shows them on the intakes only.
  2. tfeverfred
    tfeverfred
    WITCHCRAFT! Change them out or the Gods of the under world will seek you out!
    LOU WELLS and henryj1951 like this.
  3. steinauge
    steinauge
    from 1960
    I am pretty sure those were not OEM.
    henryj1951 likes this.
  4. henryj1951
    henryj1951
    from USA
    Very much original
  5. Wyld Deuce
    Wyld Deuce
    from ...
    A: is for Aluminum and Aftermarket.
    Sorry, that motor has been apart before.
    Rcraft and henryj1951 like this.
  6. henryj1951
    henryj1951
    from USA
    You MAY be suprised
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    Did you buy the car new and this is the first time the valve covers have been off? otherwise how could you possibly know?
  8. badshifter
    badshifter
    Why would they put aluminum retainers on the intakes and leave heavy rotators on the exhaust? As to whether it's original not I have no clue it just doesn't make sense
    302GMC and henryj1951 like this.
  9. tfeverfred
    tfeverfred
    And they are SHINY. Look at the gunk everywhere else........ C'mon, man.
    sunbeam, reagen and henryj1951 like this.
  10. henryj1951
    henryj1951
    from USA
    It may just be a feeling ,but one knows if he's the first, in the ***embly phase then the dis***embly , when things are NOT disturbed , with EVERYthing in its virgin place.
    falcongeorge likes this.
  11. henryj1951
    henryj1951
    from USA
    They wiped off easy, there aluminum.
  12. henryj1951
    henryj1951
    from USA
    will up load head markings here in a sec
    falcongeorge and timmy2times like this.
  13. squirrel
  14. Fedman
    Fedman
    Corvette........ 1966 1/2 Model Year.......... Fuel Injected Option, Only in California. :)
    henryj1951, afaulk, Xtrom and 3 others like this.
  15. henryj1951
    henryj1951
    from USA
    Jim might be onto something
    it might be a 350.?.?.?
  16. henryj1951
    henryj1951
    from USA
    No numbers on pad (what!!!)
  17. DDDenny
    Never heard of a hecho in Mexico 327!
  18. I've been in GM dealers parts departments since 1970 and never seen a mix either of aluminum and steel in any production motor. And never seen an aluminum retainer used on any production motor either, serious durability issues on those too.
  19. henryj1951
    henryj1951
    from USA
    They said it was 1968/69 before your time. (just havin fun).
    How bout this oil filter pad (area)---> pic
    timmy2times likes this.
  20. badshifter
    badshifter
    The springs and rotators are shiny as well on the last set of pics. That isn't consistent with ANY old engine I've ever taken apart. The crud does not "just wipe off" and old engine I've ever dealt with either. Let's see the intake, it looks like a standard cast iron piece with a choke stove? So you only "think" you're the first to have it apart? Do you know the history and it's a guessing game for us, or are you looking for help I.D.ing what you think is a factory valve train? Looks pretty rusty on the outside. Marine application? Double grove water pump pulley, not a deep groove, kinda excludes performance duty?
    Solarman and henryj1951 like this.
  21. squirrel
    they didn't use that short pad on the deck (where the engine number should be stamped) when they were making 327s, it's a later thing (late 70s? 80s?)
    I don't see any clues that would make me think it had never been taken apart, or that it is a production engine.
    henryj1951 and Moriarity like this.
  22. henryj1951
    henryj1951
    from USA
    Hard to see them (never been apart clues) unless you , were there i guess, no offence,it just had ALL the signs of NOT played with (EVER) , you know EVERYthing in its place , no modern use of gasket goop OF any kind , and the way it came apart,
    NOT a single thing OUT of place , no and i do mean NO messed up nuts and bolts.
    That may just be conjecture on my part NO BIG deal.
  23. checkedgoldtop
    checkedgoldtop
    rjones35 and henryj1951 like this.
  24. tb33anda3rd
    tb33anda3rd
    studebaker?
    mr57 and henryj1951 like this.
  25. badshifter
    badshifter
    You could speed the process by posting casting numbers. Or bore. Or stroke. Or info on where you got it. Checker? Avanti II? Holden?
  26. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Rare Australian build 327 for even rarer Holden SS!
    KK
  27. henryj1951
    henryj1951
    from USA
    down the cyl 3.995
    010 rear of block casting number
  28. squirrel
    4 bolt 327? huh?
    redlineracer42 and henryj1951 like this.
  29. squirrel
    Did it have the thin steel shim head gaskets?
    Ragmanray and henryj1951 like this.
  30. henryj1951
    henryj1951
    from USA
    So is more likely to be just a 350.?.
