Projects The LITTLE KAISER HENRY J Build
Discussion in 'The Hokey Ass Message Board' started by Clik, Feb 16, 2017.
  1. Clik
    Clik
    20170215_030020.jpg Got the engine and trans mounted.
    els, kidcampbell71, kiwijeff and 5 others like this.
  2. Clik
    Clik
  3. Clik
    Clik
  4. Clik
    Clik
  5. Clik
    Clik
  6. Max Gearhead
    Max Gearhead
    from Wisconsin
  7. henryj1951
    henryj1951
    from USA
    OK that s it...
    I wish it was mine and you had a better one...
    els and AVater like this.
  8. earlymopar
    earlymopar
    Looks good. What % of engine set back do you have?
    - EM
    els likes this.
  9. Clik
    Clik
    There is probably 14" or so of set back and I sat the engine down between the frame rails to get a straighter drive-line. I suppose the set back would have taken it out of the G***er cl*** back in the day because it's more than 10% of the 100" wheelbase. I guess that would make it an Altered, huh?
    els and henryj1951 like this.
  10. earlymopar
    earlymopar
    Per the rules I recall in the early to mid-60s, yes. BTW, you have a great looking shop to build your Henry J in!
    - EM
    els likes this.
  11. Clik
    Clik
  12. swade41
    swade41
    from Buffalo,NY
    Hey, nice to see some build photos of it. What's next on the list ?
  13. Duellym
    Duellym
    I feel you with the no heat thing, always fun trying to bolt things together when your fingers are numb.
    Ch***is looks really good.
    els likes this.
  14. ***Area-51***
    ***Area-51***
    from Ohio
    COOL !...you will be sitting in the back seat:D
    els likes this.
  15. AHotRod
    AHotRod
    Yes .... it's a Altered .... not a g***er. Or it qualifies as a Street-Freak too !
    Looks like a hoot :)
    els likes this.
  16. Jalopy Joker
    Jalopy Joker
    well built project, and well stocked shop
    els likes this.
  17. Clik
    Clik
    I guess I'll mount the radiator next and decide if I'm going to use the long ladder bars I fabbed up or re-do them. They came out sort of heavy. I need heat or warm weather to paint brackets and stuff.
  18. swade41
    swade41
    from Buffalo,NY
    That's my down fall too, I keep it at 40 degrees but to paint anything I have to start a day ahead with the furnace plus a torpedo heater. That was the main reason I just had my axle and springs powder coated, because of temps, in fact I just brought my spindles in the house to paint them last week.
  19. Clik
    Clik
    My pole barn is 48'X80' and about impossible to heat, up on this windy mountain. I went with powder coat on my frame because of the cold, like you did. My panel truck frame is at the powder coaters as we speak.
  20. Clik
    Clik
    Little Kaiser henry J Build 2-27-2017.jpg Little Kaiser Henry J Build Three 2-27-2017.jpg Ran the rear brake line through the boxed frame using 1/4" fuel line to prevent abrasion on the 3/16" NiCop brake line. A little silicon sprayed in the 1/4" hose allowed the 3/16" to slide through. I couldn't get the hose and brake line through the driver side due to through-frame steering box bolts so when I drop the body on I'll run it across the firewall under the cowl lip that Henrys have.
  21. Clik
    Clik
    I mounted the radiator. I used a couple of stake pockets made for the sides of trailers from Tractor Supply. I welded a flat bar to them and drilled it to use the existing former engine mount holes in the shock towers. The stake pockets with the foam tape inside fit nice and snug. I welded up a T using flat bar. The radiator sits on it with foam tape and EPDM rubber siliconed on the bottom of the radiator. The T-bar mounts in two existing holes, front and back of the cross member. It's snug and with hose sure isn't going anywhere but I'll fab a couple of small diameter pieces of all thread to pin it down in case of a roll over. Henry J Build 5-28-2017 B.jpg
  22. Clik
    Clik
    Pinned the radiator down with some stainless all thread and stainless hardware. I left room for a future electric fan just in case the mechanical six blade doesn't work out.
    els, swade41 and UNSHINED 2 like this.
  23. loudbang
    Looks GOOD
    els and enloe like this.
  24. Clik
    Clik
    20170621_215840.jpg I didn't like the billet style Wilwood split system master cylinders and I couldn't find an adapter to convert the verticle hole Wilwood pedal to a cast iron horizontal hole master cylinder. I had to make one.
    els and loudbang like this.
  25. Clik
    Clik
    20170622_174827.jpg 20170622_181046.jpg Throwing the freshly drilled adapter into my home made deburring and slag removing machine.
    els, zzebby and loudbang like this.
  26. Clik
    Clik
    Got some more done on The Little Kaiser Henry J. Early Mustang gas tank fills the area nice and they are cheap to buy new repro. Nice flat shape too. Fabbed a steel frame that goes under the entire edge of the tank. Scuffed the tank and coated with bed liner. Yes the trans cooler would be in a vulnerable place but I'll be fabbing some drive-shaft loops.
    Little Kaiser Henry J Build - August 24 - 2017 Trans cooler & Mustang Gas Tank.jpg Little Kaiser Henry J Build - August 24- 2017 'stang tank.jpg
  27. az426hemi
    az426hemi
    Very nice!
    Mike
    loudbang and els like this.
  28. enloe
    enloe
    from east , tn.
    Cool I love me some Henry Js
